    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 105.2k Views 43 Watching
    • B
      boilingsnow
      Hi,tak2hata.
      Your Multi Hole Tool is very interesting and useful. But with Multi Hole I can only make holes into a solid using faces as definition of the form for the holes, with a component or group it fails to make holes into any solid...I can see in your video that you are using a group or component. Can you tell me how you can make it?
        jorge2011
        excellent and thank you very much.
        Two requests for future versions.
        You can add a function: projecting faces in a solid?
        You can add a function to hole or project a face, in multiple solid?
        • T
          tak2hata
          Hi,I did not change title of topic in Jan 03,2012.I modeified title.
          Hi,boilingsnow.
          hole of component
          The componet for hole must have cut openning option.
          Reference about component here. http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114526
          Hi,jorge2011.
          I will consider your Proposal.
          Thanks.
          by TAK2HATA
          • guanjinG
            guanjin
            Creating the Component Selection cutting openings, holes can not be achieved? ? ?
            • T
              tak2hata
              [attachment=1:1jixhd7j]<!-- ia1 -->rrrrrrrr.gif<!-- ia1 -->[/attachment:1jixhd7j]
              Hi,XIAOLONG.
              Outline for cut openning must be drawn on X-Y Plane( Red and Green axis).
              When the component is already existed,You rotate axis in that component.
              And outline must be placed in the root of that component.
              [attachment=0:1jixhd7j]<!-- ia0 -->outline_must_be_on_xyplane.jpg<!-- ia0 -->[/attachment:1jixhd7j]
              Watch for reference to create cut openning option.
              http://youtu.be/0g6irIj---w
              [flash=640,480:1jixhd7j]http://www.youtube.com/v/0g6irIj---w[/flash:1jixhd7j]
              Thanks.
              outline must be on xy-plane
              by TAK2HATA
              • guanjinG
                guanjin
                @tak2hata said:
                [attachment=2:24c8pe63]<!-- ia2 -->rrrrrrrr.gif<!-- ia2 -->[/attachment:24c8pe63]
                Hi,XIAOLONG.
                [attachment=1:24c8pe63]<!-- ia1 -->outline_must_be_on_xyplane.jpg<!-- ia1 -->[/attachment:24c8pe63]
                Thanks.
                Thank you! Have learned to see demo:
                [attachment=0:24c8pe63]<!-- ia0 -->LLLLL.gif<!-- ia0 -->[/attachment:24c8pe63]
                • charly2008C
                  charly2008
                  Hello tak2hata,
                  Your tool is impressive. I've done some experiments with it. It works really well. One question I have is it possible a component that contains some single solids to cut completely into the wall.
                  Charly
                  example001-1.skp
                  • T
                    tak2hata
                    Hi,everyone.
                    I update in jan 09,2012.
                    Its version is 1.63.
                    Bug fix.The hole from polygon mades smoothed side faces. it's improved.
                    I found from dave's post,and irwanwr's message.
                    Thanks. Dave and irwanwr.
                    Hi,Charly2008.
                    That problem is not solved yet.
                    I will improve it,when I find the solution in future.
                    Thanks.
                    by TAK2HATA
                    • irwanwrI
                      irwanwr
                      hi tak2hata,
                      😍 thank you thank you very much for your generosity
                      • charly2008C
                        charly2008
                        @tak2hata said:
                        Hi,Charly2008.
                        Thanks.
                        thank you very much for your answer
                        Charly
                          jorge2011
                          Thank you. Excellency update.
                          Only a small error.
                          It does not work the command "Ctrl + Z". deleted one by one holes
                          • U
                            urs0815
                            Great plug in 👍
                            an option to set the depth of the hole would be great...
                              jorge2011
                              tak2hata
                              See litle fix.you can fix that?
                              Thank you very much
                              01.skp
                              • T
                                tak2hata
                                @jorge2011 said:
                                tak2hata
                                Thank you very much
                                jorge2011.....
                                I try your model.
                                And I move the face for hole to very small distance.It succeed.
                                The hidden line in the curved face is intersected with the hole on touch.
                                I will inquire about it.
                                Thanks.
                                by TAK2HATA
                                • C
                                  carlm
                                  Hi-
                                  I've installed the 1.6.3 plugin, but when I first re-opened SU the little Hole on Solid toolbox was "in my way" so I closed it -- now I can't figure out how to get it back. I can choose the plugin from the Plugin menu and it works to make single holes, but I've no menu access to the Multi-Hole variant of the tool, and no obvious way to re-open the toolbox...
                                  Any ideas?
                                  Thanks, -carl-
                                  (SU8 amateur, MacOS 10.5.8)
                                    Menu > View > Toolbars > the_Tool's_Name
                                    On a MAC it might be called something like 'Tool-Palettes' ?
                                    • C
                                      carlm
                                      Doh!
                                      View>Tool Palettes
                                      And there's your 2D tools palette as well.
                                      Thanks, -carl-
                                        jgt1942
                                        @tak2hata said:
                                        The face and solid must be in same Group or Component or Model.
                                        And ComponentInstance for hole must have hole option.
                                        It is rule of this plugin.
                                        Sorry newbie question - It took me a few hours (OK I'm really slow) to realize that the face could NOT be part of the solid. I'm having a couple of problems (1) creating the face - every-time I attempt to create the face it becomes part of the solid (2) I copied in a test object for the face but I cannot get it accurately positioned. Example I'm drawing a woodworking object and I need to have the hold precisely positioned and sized.
                                        I've got to study a bit more to fully understand your statement in the above quote. If you have a reference video to explain what you have in the quote, for me that would be super helpful.
                                        The concept is super and in the example file I downloaded it works GREAT! I'm using SU 8.
                                        jgt
                                          Could you post a screen shot of your model? Or better, the SKP file? It would be more helpful to explain how to position the hole where you want it and to sort out why the face becomes part of the solid.
                                          • Gus RG
                                            Gus R
                                            Just discovered this plugin. Installed it and tested it with faces and components including multiple selections and it works like a charm. Thanks! It will come in very handy for window openings.
                                            www.instagram.com/gusrobatto/
                                            www.facebook.com/gusrobatto
                                            • 5 / 7
