    1.3k Posts 299 Posters 2.5m Views 297 Watching
      Thanks Jeff.
      Strangely I did use TIG EebyR it it worked perfectly. Though I used one shawty as both 'Profile' and 'Melding Profile'. Didn't try it with separate profiles.
      Anyway thanks for the fix ๐Ÿ‘
      • tibetT Offline
        tibet
        hi ,
        i have deleted curviloft icons by accident.
        could you please tell me how to restore them in sketchup 8 pro
        thanks
        SU 2015 Pro on Win10 x64
        • TIGT Online
          @tibet said:
          hi ,
          thanks
          Go to the first post in this thread and download the files and install them as instructed. The icons will be restored and some other scripts etc will be overwritten - but that doesn't matter... ๐Ÿ˜•
          However, if you don't mean you've actually thrown away the files but you mean you've 'closed the toolbar' or 'deactivated the extension' then simply reactivate the extension through Window > Preferences > Extensions and/or switch on the toolbar through View > Toolbars...
            @tibet said:
            hi ,
            thanks
            It's interesting what you can find on these forums.
              pythiaz
              Super LOL~!! ๐Ÿ˜Ž
              • 66searcher6 Offline
                66searcher
                thanks fredo6
                ๐Ÿ‘ one of the best of all su plugins ! well done!
                thanks Karl (Charly)
                ๐Ÿ‘ great works by you motivates me...good luck.
                http://hamidtoliat.deviantart.com/
                • fredo6F Offline
                  Joel,
                  Can you post the model or a typical case, because I am not clear on the issue you face
                  • jgbJ Offline
                    jgb
                    I may be doing something wrong, but there is a very simple curve that Curviloft (CL) seems to have a problem with.
                    If I have 2 surfaces that I punch a hole in, say a round airplane fuselage that I put a round window or door opening in, CL won't face the rim of the opening.
                    After I delete the 2 wall bits in the opening, I select the 2 perimeters and call CL to do its magic. In effect, create the rim or ring. All I get are magenta lines.
                    If I join 1 pair of verticies, still no go. I have to draw 2 joiners (close together), and deselect the lines of the perimeter between the 2 joiners and CL does its magic in a flash.
                    This happens even to 2 rings in free space, unconnected to anything. I have to break both rings, then rejoin them after CL makes the curve.
                    Yet yesterday I made a large complex curved door, and CL rimmed it perfectly in 5 seconds, compared to 20 minutes or more to my making the perimeter manually. So I'm NOT complaining.
                    Fredo, as requested. The model I discovered this is way too big to upload, so I made an example.
                    I drew 2 rings offset in X, Y & Z axis.
                    Select 2 rings alone and CL will not form a rim.
                    Join rings with only 1 line, select all and CL creates a twisted rim.
                    Join rings with 2 lines and select all, no rim forms.
                    Deselect 2 bits of ring segment and CL forms proper rim.
                    As explained above, 4 sets of rings
                    jgb
                    • H Offline
                      hygicell
                      I am getting a lot of error messages on the Fredo6 plugins at startup of Sketchup 8 Pro:
                      please help
                      Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb
                      uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftCurveMover.rb
                      uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftLoader.rb
                      uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftPalette.rb
                      uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftTool.rb
                      uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/__loader.rb
                      undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftAlgo.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftCurveMover.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftPalette.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftTool.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/bootstrap_Curviloft.rb
                      uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREDOSCALE_Dir_21/__loader.rb
                      undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREDOSCALE_Dir_21/bootstrap_FredoScale.rb (eval):1: uninitialized constant FredoScale::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/FreeScale_Common.rb uninitialized constant FreeScale::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/FreeScale_Tool.rb uninitialized constant FreeScale::SU_MAJOR_VERSIONError Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/GhostCompAlgo.rb
                      uninitialized constant GhostComp::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/GhostCompLoader.rb
                      uninitialized constant GhostComp::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/__loader.rb
                      undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/HoverSelect_Palette.rb uninitialized constant HoverSelect::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/HoverSelect_main.rb uninitialized constant HoverSelect::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/__loader.rb
                      undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb uninitialized constant RoundCorner::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/EraserOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/FreehandOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/LibOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/LineOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/OffsetAlgoOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/OffsetOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/PaletteOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/PolylineOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/bootstrap_OnSurface.rb
                      uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/arc.rb
                      uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/attributes.rb
                      uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/babelfish.rb
                      uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/bezier.rb
                      uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/binary.rb
                      uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/bounds.rb
                      uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/color.rb
                      uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ruby/singleton.rb
                      undefined method extend_object' for Singleton'
                      • TIGT Online
                        Frank
                        Sounds like you haven't got all of the files installed in the right places ?
                        Please reread the installation instructions.
                        Also see this thread for help on extracting zipped files and keeping their subfolder structure with Plugins etc http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                        Also if you have inadvertently put files directly into Plugins that ought to be within a subfolder, then please remove them as they might cause unexpected results as they will then auto-load at startup rather than when the main tool wants them to...
                        • jgbJ Offline
                          jgb
                          Joel,
                          I did! I appended it to my post, but so far no reply.
                          jgb
                          • jeff hammondJ Offline
                            @jgb said:
                            Joel,
                            i can skin that thing with zero problems.
                            i think you might be using the wrong tool.. i think you're trying to use curviloft's Skinning when you should be using regular Loft (the first of the 3 icons in the toolbar)
                            just select the two rings then click on the Loft icon.
                            • H Offline
                              hygicell
                              @tig said:
                              Frank
                              I have reinstalled everything as per the instructions
                              then ran duplicate cleaner 2.0 to find any .rb leftovers from the previous installation directly into plugins folder and erased them
                              the problem remains
                              should I be looking for other files than with the .rb extension and erase these duplicates too?
                              Frank
                              • TIGT Online
                                Please don't start removing files willy-nilly.
                                Only the the files inside the subfolders that have equivalents wrongly installed in Plugins are to be removed - it's recommended that these put into a 'disabled folder' [erasing them is a little drastic - especially when you are not sure what you are doing - at least that way they can be moved back if you've messed up !]. There will also be .rb files in Plugins installed by other tools that you still need! AND of course there are .rb files installed as 'loaders' to run files inside subfolders that come in the zip file 'loose' rather than in a subfolder of Plugins...
                                If you are getting similar error messages then are you sure the files and files in relative subfolders are installed properly. I noticed that you have a drive with an unusual path - H:/programmas/google/Google SketchUp 8/Plugins/ - the default is something like C:/Program Files/Google/Google SketchUp 8/Plugins/
                                Please type this in the Ruby Console + <enter> and post the results $LOAD_PATH
                                It should include your H: folder Plugins path.
                                With Vista/Win7 there can be a 'Compatibility Files' issue [ยฟArchivos de Compatibilidad?]... which happens if you don't have full security permissions to read/write/etc to the the Plugins folder and/or its subfolders and/or files. It looks like you have done it OK, and there are no error messages... but really the OS has put the new things in a separate subfolder to protect you from yourself! In these cases there's a 'Compatibility Files' button added to the top of the window of the affect folder[s] - you click on that to see what's messed up... Fix your permissions under properties, security as an admin...
                                Can you post a screen-shot showing your Plugins folder structure etc if none of this is working...
                                • H Offline
                                  hygicell
                                  I have installed Sketchup 8 pro on an external disk so I can easily take it with me
                                  my other plugins work fine
                                  ? Only the the files inside the subfolders that have equivalents wrongly installed in Plugins are to be removed ?
                                  would it not be the other way round?
                                  I removed the equivalents in the plugins folder and left the ones in the subfolders
                                  H;\programmas\google\Google SketchUp 8\Plugins\
                                  2DTools\
                                  AutoCenterPoint\
                                  clf_simple_loft\
                                  ctsMaker\
                                  CURVILOFT_Dir_11\
                                  DEFPARAM_Dir\
                                  Dom_brevenchatij\
                                  DoorTools\
                                  DWGExport\
                                  Examples\
                                  FREDOSCALE_Dir_21\
                                  FREESCALE_Dir_10\
                                  GHOSTCOMP_Dir_10\
                                  HOVERSELECT_Dir_11\
                                  JPP_Dir\
                                  JPP_Dir_15\
                                  Layer Manager\
                                  layers\
                                  ldd\
                                  LIBFREDO6_Dir_37\
                                  Ocean\
                                  Projection\
                                  RDE_Dir\
                                  ROUNDCORNER_Dir_23\
                                  ruby\
                                  skin\
                                  SoapSkinBubble\
                                  TIGtools\
                                  TOS_Dir_18\
                                  TT_Lib2\
                                  Utilities\
                                  WindowTools\
                                  0.skb
                                  1.skb
                                  2.skb
                                  2D#.rb
                                  3.skb
                                  AddVertex+.rb
                                  Align User Guide.pdf
                                  align_2D.rb
                                  align_tool.rb
                                  AllowDWGImportInSketchUp7.msi
                                  arc_centerpoint.rb
                                  auto_centerpoint.rb
                                  BzRoundEdge.rb
                                  cadspan.rbs
                                  calc.rb
                                  CenterPoint.rb
                                  Chamfer_Along_Path.rb
                                  clf_color_by_slope.rb
                                  clf_simple_loft_loader.rb
                                  closeopens.rb
                                  Cloud Quick Tutorial.pdf
                                  Cloud V6.pdf
                                  cloud_v6.rb
                                  co_tool.html
                                  co_toola.rb
                                  ComponentReporter+.rb
                                  ConstructFaceNormal.rb
                                  curve_maker.rb
                                  curvestitcher.rb
                                  deBabelizer.rb
                                  delauney2.rb
                                  demeter-main.rbs
                                  DoorTool.txt
                                  DoorTools.rb
                                  DWGExport.rbs
                                  engineeringtoolbox.rb
                                  examp_les.rb
                                  example.dat
                                  examples.rb
                                  extrudeEdgesByEdges.rb
                                  f2f.rb
                                  faceFlattener019.rb
                                  file.php
                                  FilletTool.rb
                                  fixSolid.rb
                                  flightpathtool.rb
                                  GetCentroid.rb
                                  GetDimensions.rb
                                  hide_faces_edges.rb
                                  hideall.htm
                                  hidetool.rb
                                  jf_follow_this.rb
                                  jf_spheretool.rb
                                  jointpushpull.rb
                                  kml_mesh_exporter.rb
                                  ky_Delete_Interior_Faces.rb
                                  ky_Group_PushPull_2DFaces.rb
                                  Layer Manager v6.pdf
                                  layer_manager_extension_v5.rb
                                  layer_manager_extension_v6.rb
                                  layer_manager_v5.txt
                                  layerbymaterial.rb
                                  layers.rb
                                  layers_materials.rb
                                  layers_show_hide_all.rb
                                  ldd.rbs
                                  LibFredo6.rb
                                  LibTraductor.def
                                  LibTraductor.rb
                                  Lines2Components.rb
                                  load_sketchapps.rb
                                  lsystem.rb
                                  makefaces(2).rb
                                  makefaces.rb
                                  makeNamedGroup.rb
                                  manifold.rb
                                  massmaterialimporter.rb
                                  Mirror_31.rb
                                  move_to_origin.rb
                                  move_to_origin_and_center.rb
                                  moveit.rb
                                  new.txt
                                  nudge.rb
                                  numbered_grid.rb
                                  ocean_extension.rb
                                  Organizer.rb
                                  organizerEdit.log
                                  pageLayers.rb
                                  Paint_back_faces v2.0.rb
                                  parking.rb
                                  pathcopy.rb
                                  perp_line_plane.rb
                                  PipeAlongPath.rb
                                  plugins_help.rb
                                  plugins_help_TIG.rb
                                  pnts2mesh.rb
                                  points_cloud_triangulation.rb
                                  ProgressBar.rb.htm
                                  Projection Documentation.pdf
                                  Projection.pdf
                                  projection_extension.rb
                                  PurgeAll.rb
                                  push_pull_vector.rb
                                  PutOnLayer_bmw.rb
                                  PutOnLayer_ForPublicRelease.rb
                                  read_me.txt
                                  reglue.rb
                                  rename_comp_inst.rb
                                  repaint_face.rb
                                  repair_broken_lines.rb
                                  Roof.rb
                                  roofplanfollower.rb
                                  rot90.rb
                                  rps_texturewrite.rb
                                  scene_rename.rb
                                  sceneExporter.rb
                                  screw_21.rb
                                  script_loader.rb
                                  SectionCutFace.rb
                                  simplify.rb
                                  SimplifyContours.rb
                                  skin.rb
                                  SmustardOrganizerExcludeFolders.txt
                                  SoapSkinBubbleTools.rb
                                  Srub.rb
                                  stair_maker062.rb
                                  stitcher.rb
                                  stock_maker.rb
                                  stray_lines.rb
                                  sublend.rb
                                  taper_maker.rb
                                  Terrain Reshaper User guide.pdf
                                  terrain_reshaper.rb
                                  TextTag14.rb
                                  tf.rb
                                  toolbar.rb
                                  trim_extend.rb
                                  tt_cleanup.rb
                                  tt_solid_inspector.rb
                                  unfoldtool.rb
                                  unhide_all.htm
                                  unhide_all.rb
                                  utilities.rb
                                  utilities_10.rb
                                  vector.flat_angle.rb
                                  viewMemory.rb
                                  VolumeCalculator21.rb
                                  weld.rb
                                  Win32API.so
                                  WindowTools.rb
                                  ZLoader__OnSurface.rb
                                  zone.rb
                                  zoom_selection.rb
                                  Zorro.rb
                                    WindowTools.rb
                                    zone.rb
                                    according to that list, all your other plugins aren't working fine..
                                    you're missing the ZLoader files that come with many of fredo's plugins.. the only one you have is tools on surface but i suspect your round corner, curviloft, and fredoscale aren't working either (amongst others?)
                                    • TIGT Online
                                      First:
                                      Only the the files inside the subfolders that have equivalents wrongly installed in the Plugins folder are to be removed... from the Plugins folder...
                                      What you did is correct.
                                      Second:
                                      You do seem to have several Zloader .rb files missing from that Plugins folder - like Zloader_Curviloft.rb - this might be the root cause of your problem - do you perhaps have them in another folder that might also be on your $LOAD_PATH ?
                                      And then they can't load other files are the paths gets tangled up...
                                      Did you get the $LOAD_PATH in the Ruby Console ?
                                      Mine says ["C:/Program Files/Google/Google SketchUp 8/Plugins", "C:/Program Files/Google/Google SketchUp 8/Tools"] yours should also include the H: path ?
                                      ..\Plugins\LIBFREDO6_Dir_37\Lib6Core_37.rb; line#225; txt = "T6 = Traductor::T6Mod.new(#{hmod}, '#{path}', '#{rootname}') "
                                      line#226; hmod.module_eval txt
                                      This is the code that sets the constant T6 to have a certain value and typing in the Ruby Console
                                      Curviloft::T6
                                      should show this, which is a Traductor::T6Mod object used to translate between languages; it is complex looking list of code, elements, hashes etc...
                                      It seems that ..\Plugins\LIBFREDO6_Dir_37\Lib6Core_37.rb is not being run properly...
                                      Does the file exist ?
                                      If so are it's properties set so 'you' can see it and read it etc...?
                                      Trying typing load LIBFREDO6_Dir_37\Lib6Core_37.rb + <enter> into the Ruby Console and see if it returns true and if CurviLoft then works... it'll only be a temporary fix but at least we then step on one pace...
                                      If you type this in the Ruby Console +<enter> what is returned ?
                                      Sketchup.find_support_file("Plugins")
                                      I get
                                      You must include the H: path to your Plugins... otherwise Fredo's LibFredo6.rb will fail at lines#26/27
                                      require 'LibTraductor.rb' if Sketchup.find_support_file( 'LibTraductor.rb', "Plugins" )#Compatibility require 'TOS_Dir_13/LibTraductor_20.rb' if Sketchup.find_support_file( 'TOS_Dir_13/LibTraductor_20.rb', "Plugins" )#Compatibility
                                      Otherwise when it doesn't find these files they are not loaded and so the T6 constant never gets defined...
                                      You could rewrite those two lines using a plain-test editor like Notepad[++].exe - as
                                      require 'LibTraductor.rb' if File.exist?(File.join(File.dirname(__FILE__), 'LibTraductor.rb'))#Compatibility require 'TOS_Dir_13/LibTraductor_20.rb' if File.exist?(File.join(File.dirname(__FILE__), TOS_Dir_13, LibTraductor_20.rb)#Compatibility
                                      I think the second one is not important as the first one gets loaded anyway...
                                      Now it will always load the files found relative to it even on some obscure drive, rather than the default C:...
                                      • H Offline
                                        hygicell
                                        WindowTools.rb
                                        zone.rb
                                        [attachment=0:ia8g6goq]<!-- ia0 -->screen 2011-06-25 at 10.54.52 AM.jpg<!-- ia0 -->[/attachment:ia8g6goq]
                                        I had those and the Fredo plugins did't work then
                                        as a test I removed them as I thought they were redundant
                                        I will have to reinstall
                                        have you seen any files I have to remove?
                                        Frank
                                        • TIGT Online
                                          Do you have another folder Sketchup with some stuff in it, say on the C:drive for example...
                                          Is Curviloft somehow trying to load even when its Zloader is removed ??
                                          Have you read through my last diatribe... โ“
                                          • jgbJ Offline
                                            jgb
                                            And Right you are! ๐Ÿ˜ณ
                                            I guess I was so used to skinning my constructs I just forgot about the other 2 functions.
                                            Thanks. ๐Ÿ‘
                                            jgb
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 65
                                            • 66
                                            • 58 / 66
