    1.3k Posts 300 Posters 3.3m Views 298 Watching
      @tibet said:
      hi ,
      i have deleted curviloft icons by accident.
      could you please tell me how to restore them in sketchup 8 pro
      thanks
      Go to the first post in this thread and download the files and install them as instructed. The icons will be restored and some other scripts etc will be overwritten - but that doesn't matter... ๐Ÿ˜•
      However, if you don't mean you've actually thrown away the files but you mean you've 'closed the toolbar' or 'deactivated the extension' then simply reactivate the extension through Window > Preferences > Extensions and/or switch on the toolbar through View > Toolbars...
        @tibet said:
        hi ,
        thanks
        It's interesting what you can find on these forums.
        • P
          pythiaz
          Super LOL~!! ๐Ÿ˜Ž
          • 66searcher6
            66searcher
            thanks fredo6
            ๐Ÿ‘ one of the best of all su plugins ! well done!
            thanks Karl (Charly)
            ๐Ÿ‘ great works by you motivates me...good luck.
            http://hamidtoliat.deviantart.com/
            • fredo6F
              Joel,
              Can you post the model or a typical case, because I am not clear on the issue you face
              • jgbJ
                jgb
                I may be doing something wrong, but there is a very simple curve that Curviloft (CL) seems to have a problem with.
                If I have 2 surfaces that I punch a hole in, say a round airplane fuselage that I put a round window or door opening in, CL won't face the rim of the opening.
                After I delete the 2 wall bits in the opening, I select the 2 perimeters and call CL to do its magic. In effect, create the rim or ring. All I get are magenta lines.
                If I join 1 pair of verticies, still no go. I have to draw 2 joiners (close together), and deselect the lines of the perimeter between the 2 joiners and CL does its magic in a flash.
                This happens even to 2 rings in free space, unconnected to anything. I have to break both rings, then rejoin them after CL makes the curve.
                Yet yesterday I made a large complex curved door, and CL rimmed it perfectly in 5 seconds, compared to 20 minutes or more to my making the perimeter manually. So I'm NOT complaining.
                Fredo, as requested. The model I discovered this is way too big to upload, so I made an example.
                I drew 2 rings offset in X, Y & Z axis.
                Select 2 rings alone and CL will not form a rim.
                Join rings with only 1 line, select all and CL creates a twisted rim.
                Join rings with 2 lines and select all, no rim forms.
                Deselect 2 bits of ring segment and CL forms proper rim.
                As explained above, 4 sets of rings
                jgb
                • H
                  hygicell
                  I am getting a lot of error messages on the Fredo6 plugins at startup of Sketchup 8 Pro:
                  please help
                  Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb
                  uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftCurveMover.rb
                  uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftLoader.rb
                  uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftPalette.rb
                  uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftTool.rb
                  uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/__loader.rb
                  undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftAlgo.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftCurveMover.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftPalette.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftTool.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/bootstrap_Curviloft.rb
                  uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREDOSCALE_Dir_21/__loader.rb
                  undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREDOSCALE_Dir_21/bootstrap_FredoScale.rb (eval):1: uninitialized constant FredoScale::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/FreeScale_Common.rb uninitialized constant FreeScale::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/FreeScale_Tool.rb uninitialized constant FreeScale::SU_MAJOR_VERSIONError Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/GhostCompAlgo.rb
                  uninitialized constant GhostComp::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/GhostCompLoader.rb
                  uninitialized constant GhostComp::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/__loader.rb
                  undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/HoverSelect_Palette.rb uninitialized constant HoverSelect::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/HoverSelect_main.rb uninitialized constant HoverSelect::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/__loader.rb
                  undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb uninitialized constant RoundCorner::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/EraserOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/FreehandOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/LibOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/LineOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/OffsetAlgoOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/OffsetOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/PaletteOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/PolylineOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/bootstrap_OnSurface.rb
                  uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/arc.rb
                  uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/attributes.rb
                  uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/babelfish.rb
                  uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/bezier.rb
                  uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/binary.rb
                  uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/bounds.rb
                  uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/color.rb
                  uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ruby/singleton.rb
                  undefined method extend_object' for Singleton'
                    Frank
                    Sounds like you haven't got all of the files installed in the right places ?
                    Please reread the installation instructions.
                    Also see this thread for help on extracting zipped files and keeping their subfolder structure with Plugins etc http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                    Also if you have inadvertently put files directly into Plugins that ought to be within a subfolder, then please remove them as they might cause unexpected results as they will then auto-load at startup rather than when the main tool wants them to...
                    • jgbJ
                      jgb
                      Joel,
                      I did! I appended it to my post, but so far no reply.
                      jgb
                      • jeff hammondJ
                        @jgb said:
                        Joel,
                        i can skin that thing with zero problems.
                        i think you might be using the wrong tool.. i think you're trying to use curviloft's Skinning when you should be using regular Loft (the first of the 3 icons in the toolbar)
                        just select the two rings then click on the Loft icon.
                        • H
                          hygicell
                          @tig said:
                          Frank
                          I have reinstalled everything as per the instructions
                          then ran duplicate cleaner 2.0 to find any .rb leftovers from the previous installation directly into plugins folder and erased them
                          the problem remains
                          should I be looking for other files than with the .rb extension and erase these duplicates too?
                          Frank
                            Please don't start removing files willy-nilly.
                            Only the the files inside the subfolders that have equivalents wrongly installed in Plugins are to be removed - it's recommended that these put into a 'disabled folder' [erasing them is a little drastic - especially when you are not sure what you are doing - at least that way they can be moved back if you've messed up !]. There will also be .rb files in Plugins installed by other tools that you still need! AND of course there are .rb files installed as 'loaders' to run files inside subfolders that come in the zip file 'loose' rather than in a subfolder of Plugins...
                            If you are getting similar error messages then are you sure the files and files in relative subfolders are installed properly. I noticed that you have a drive with an unusual path - H:/programmas/google/Google SketchUp 8/Plugins/ - the default is something like C:/Program Files/Google/Google SketchUp 8/Plugins/
                            Please type this in the Ruby Console + <enter> and post the results $LOAD_PATH
                            It should include your H: folder Plugins path.
                            With Vista/Win7 there can be a 'Compatibility Files' issue [ยฟArchivos de Compatibilidad?]... which happens if you don't have full security permissions to read/write/etc to the the Plugins folder and/or its subfolders and/or files. It looks like you have done it OK, and there are no error messages... but really the OS has put the new things in a separate subfolder to protect you from yourself! In these cases there's a 'Compatibility Files' button added to the top of the window of the affect folder[s] - you click on that to see what's messed up... Fix your permissions under properties, security as an admin...
                            Can you post a screen-shot showing your Plugins folder structure etc if none of this is working...
                            • H
                              hygicell
                              I have installed Sketchup 8 pro on an external disk so I can easily take it with me
                              my other plugins work fine
                              ? Only the the files inside the subfolders that have equivalents wrongly installed in Plugins are to be removed ?
                              would it not be the other way round?
                              I removed the equivalents in the plugins folder and left the ones in the subfolders
                              H;\programmas\google\Google SketchUp 8\Plugins\
                              2DTools\
                              AutoCenterPoint\
                              clf_simple_loft\
                              ctsMaker\
                              CURVILOFT_Dir_11\
                              DEFPARAM_Dir\
                              Dom_brevenchatij\
                              DoorTools\
                              DWGExport\
                              Examples\
                              FREDOSCALE_Dir_21\
                              FREESCALE_Dir_10\
                              GHOSTCOMP_Dir_10\
                              HOVERSELECT_Dir_11\
                              JPP_Dir\
                              JPP_Dir_15\
                              Layer Manager\
                              layers\
                              ldd\
                              LIBFREDO6_Dir_37\
                              Ocean\
                              Projection\
                              RDE_Dir\
                              ROUNDCORNER_Dir_23\
                              ruby\
                              skin\
                              SoapSkinBubble\
                              TIGtools\
                              TOS_Dir_18\
                              TT_Lib2\
                              Utilities\
                              WindowTools\
                              0.skb
                              1.skb
                              2.skb
                              2D#.rb
                              3.skb
                              AddVertex+.rb
                              Align User Guide.pdf
                              align_2D.rb
                              align_tool.rb
                              AllowDWGImportInSketchUp7.msi
                              arc_centerpoint.rb
                              auto_centerpoint.rb
                              BzRoundEdge.rb
                              cadspan.rbs
                              calc.rb
                              CenterPoint.rb
                              Chamfer_Along_Path.rb
                              clf_color_by_slope.rb
                              clf_simple_loft_loader.rb
                              closeopens.rb
                              Cloud Quick Tutorial.pdf
                              Cloud V6.pdf
                              cloud_v6.rb
                              co_tool.html
                              co_toola.rb
                              ComponentReporter+.rb
                              ConstructFaceNormal.rb
                              curve_maker.rb
                              curvestitcher.rb
                              deBabelizer.rb
                              delauney2.rb
                              demeter-main.rbs
                              DoorTool.txt
                              DoorTools.rb
                              DWGExport.rbs
                              engineeringtoolbox.rb
                              examp_les.rb
                              example.dat
                              examples.rb
                              extrudeEdgesByEdges.rb
                              f2f.rb
                              faceFlattener019.rb
                              file.php
                              FilletTool.rb
                              fixSolid.rb
                              flightpathtool.rb
                              GetCentroid.rb
                              GetDimensions.rb
                              hide_faces_edges.rb
                              hideall.htm
                              hidetool.rb
                              jf_follow_this.rb
                              jf_spheretool.rb
                              jointpushpull.rb
                              kml_mesh_exporter.rb
                              ky_Delete_Interior_Faces.rb
                              ky_Group_PushPull_2DFaces.rb
                              Layer Manager v6.pdf
                              layer_manager_extension_v5.rb
                              layer_manager_extension_v6.rb
                              layer_manager_v5.txt
                              layerbymaterial.rb
                              layers.rb
                              layers_materials.rb
                              layers_show_hide_all.rb
                              ldd.rbs
                              LibFredo6.rb
                              LibTraductor.def
                              LibTraductor.rb
                              Lines2Components.rb
                              load_sketchapps.rb
                              lsystem.rb
                              makefaces(2).rb
                              makefaces.rb
                              makeNamedGroup.rb
                              manifold.rb
                              massmaterialimporter.rb
                              Mirror_31.rb
                              move_to_origin.rb
                              move_to_origin_and_center.rb
                              moveit.rb
                              new.txt
                              nudge.rb
                              numbered_grid.rb
                              ocean_extension.rb
                              Organizer.rb
                              organizerEdit.log
                              pageLayers.rb
                              Paint_back_faces v2.0.rb
                              parking.rb
                              pathcopy.rb
                              perp_line_plane.rb
                              PipeAlongPath.rb
                              plugins_help.rb
                              plugins_help_TIG.rb
                              pnts2mesh.rb
                              points_cloud_triangulation.rb
                              ProgressBar.rb.htm
                              Projection Documentation.pdf
                              Projection.pdf
                              projection_extension.rb
                              PurgeAll.rb
                              push_pull_vector.rb
                              PutOnLayer_bmw.rb
                              PutOnLayer_ForPublicRelease.rb
                              read_me.txt
                              reglue.rb
                              rename_comp_inst.rb
                              repaint_face.rb
                              repair_broken_lines.rb
                              Roof.rb
                              roofplanfollower.rb
                              rot90.rb
                              rps_texturewrite.rb
                              scene_rename.rb
                              sceneExporter.rb
                              screw_21.rb
                              script_loader.rb
                              SectionCutFace.rb
                              simplify.rb
                              SimplifyContours.rb
                              skin.rb
                              SmustardOrganizerExcludeFolders.txt
                              SoapSkinBubbleTools.rb
                              Srub.rb
                              stair_maker062.rb
                              stitcher.rb
                              stock_maker.rb
                              stray_lines.rb
                              sublend.rb
                              taper_maker.rb
                              Terrain Reshaper User guide.pdf
                              terrain_reshaper.rb
                              TextTag14.rb
                              tf.rb
                              toolbar.rb
                              trim_extend.rb
                              tt_cleanup.rb
                              tt_solid_inspector.rb
                              unfoldtool.rb
                              unhide_all.htm
                              unhide_all.rb
                              utilities.rb
                              utilities_10.rb
                              vector.flat_angle.rb
                              viewMemory.rb
                              VolumeCalculator21.rb
                              weld.rb
                              Win32API.so
                              WindowTools.rb
                              ZLoader__OnSurface.rb
                              zone.rb
                              zoom_selection.rb
                              Zorro.rb
                              • jeff hammondJ
                                WindowTools.rb
                                zone.rb
                                according to that list, all your other plugins aren't working fine..
                                you're missing the ZLoader files that come with many of fredo's plugins.. the only one you have is tools on surface but i suspect your round corner, curviloft, and fredoscale aren't working either (amongst others?)
                                  First:
                                  Only the the files inside the subfolders that have equivalents wrongly installed in the Plugins folder are to be removed... from the Plugins folder...
                                  What you did is correct.
                                  Second:
                                  You do seem to have several Zloader .rb files missing from that Plugins folder - like Zloader_Curviloft.rb - this might be the root cause of your problem - do you perhaps have them in another folder that might also be on your $LOAD_PATH ?
                                  And then they can't load other files are the paths gets tangled up...
                                  Did you get the $LOAD_PATH in the Ruby Console ?
                                  Mine says ["C:/Program Files/Google/Google SketchUp 8/Plugins", "C:/Program Files/Google/Google SketchUp 8/Tools"] yours should also include the H: path ?
                                  ..\Plugins\LIBFREDO6_Dir_37\Lib6Core_37.rb; line#225; txt = "T6 = Traductor::T6Mod.new(#{hmod}, '#{path}', '#{rootname}') "
                                  line#226; hmod.module_eval txt
                                  This is the code that sets the constant T6 to have a certain value and typing in the Ruby Console
                                  Curviloft::T6
                                  should show this, which is a Traductor::T6Mod object used to translate between languages; it is complex looking list of code, elements, hashes etc...
                                  It seems that ..\Plugins\LIBFREDO6_Dir_37\Lib6Core_37.rb is not being run properly...
                                  Does the file exist ?
                                  If so are it's properties set so 'you' can see it and read it etc...?
                                  Trying typing load LIBFREDO6_Dir_37\Lib6Core_37.rb + <enter> into the Ruby Console and see if it returns true and if CurviLoft then works... it'll only be a temporary fix but at least we then step on one pace...
                                  If you type this in the Ruby Console +<enter> what is returned ?
                                  Sketchup.find_support_file("Plugins")
                                  I get
                                  You must include the H: path to your Plugins... otherwise Fredo's LibFredo6.rb will fail at lines#26/27
                                  require 'LibTraductor.rb' if Sketchup.find_support_file( 'LibTraductor.rb', "Plugins" )#Compatibility require 'TOS_Dir_13/LibTraductor_20.rb' if Sketchup.find_support_file( 'TOS_Dir_13/LibTraductor_20.rb', "Plugins" )#Compatibility
                                  Otherwise when it doesn't find these files they are not loaded and so the T6 constant never gets defined...
                                  You could rewrite those two lines using a plain-test editor like Notepad[++].exe - as
                                  require 'LibTraductor.rb' if File.exist?(File.join(File.dirname(__FILE__), 'LibTraductor.rb'))#Compatibility require 'TOS_Dir_13/LibTraductor_20.rb' if File.exist?(File.join(File.dirname(__FILE__), TOS_Dir_13, LibTraductor_20.rb)#Compatibility
                                  I think the second one is not important as the first one gets loaded anyway...
                                  Now it will always load the files found relative to it even on some obscure drive, rather than the default C:...
                                  • H
                                    hygicell
                                    WindowTools.rb
                                    zone.rb
                                    [attachment=0:ia8g6goq]<!-- ia0 -->screen 2011-06-25 at 10.54.52 AM.jpg<!-- ia0 -->[/attachment:ia8g6goq]
                                    I had those and the Fredo plugins did't work then
                                    as a test I removed them as I thought they were redundant
                                    I will have to reinstall
                                    have you seen any files I have to remove?
                                    Frank
                                      Do you have another folder Sketchup with some stuff in it, say on the C:drive for example...
                                      Is Curviloft somehow trying to load even when its Zloader is removed ??
                                      Have you read through my last diatribe... โ“
                                      • jgbJ
                                        jgb
                                        And Right you are! ๐Ÿ˜ณ
                                        I guess I was so used to skinning my constructs I just forgot about the other 2 functions.
                                        Thanks. ๐Ÿ‘
                                        jgb
                                        • fredo6F
                                          NEW RELEASE: Curviloft 1.1b - 27 Jun 11
                                          This is a small upgrade to handle the problem of mean curves between contours.
                                          Previous versions were only able to generate the junction curves. This one adds the intermediate curves. And you get the mesh by selecting both options.
                                          Thanks to Jeff Hammond for the suggestion to use Curviloft for generate mean curves between contours
                                          See also discussion at this post on the question of mean curves.
                                          See main post for download
                                          • GaieusG
                                            Thanks Fredo. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                            It seems to be such an important release however that it travelled faster than light and arrived the previous day... ๐Ÿ˜†
                                            (You are in the same time zone as me if I am not mistaken)
