    1.3k Posts 299 Posters 2.5m Views 297 Watching
      mac1
      See if this is close to what you want. I left portion for your exercise πŸ’š
      I put all your primitive geo back to layer 0, created faces for each of the profiles, intersected the center line ref with each of those and used Freedo's tool loft junctions. It looks like you need some more profiles aft ❓ ❓
      http://sketchup.google.com/3dwarehouse/details?mid=7da88c5f8c6cdc29427d16763a0ff49
      • jgbJ Offline
        jgb
        Thanks guys, and for the PM "solutions" as well. πŸ‘ I will look at them later this week, as I have no time just now.
        Actually I'm not looking for a solution. I have it in the rightmost copy, and it is good enough for my learning purposes. I will not use that particular duct in any model, as it was not to scale, nor to fit the actual airplane at this time. The "real" one will be shorter and the curves a bit more involved to avoid aircraft structure. It is simply a learning exercise for Curviloft using a shape I had difficulty creating using a mesh and tweaking it.
        The essence of my post was that it seems Curviloft tried to follow the original DIRECTION of the flipped copy of a curve in segments causing a twist in the surface, and was for Fredo to analyze. Once I welded the flipped curve segments, my duct formed correctly.
        jgb
          rock1
          wow,what a plugin fredo!
          I should have joined this forum earlier. πŸ˜„ I never knew about it. What a cool collection of plugins is present here!!
          Signature removed by SCF Admin
            Hi Fredo,
            Can you look at this file?
            CurviLoft_Helix.skp
            Using 'Skinning of Shapes' but slight errors appear?
            • jeff hammondJ Offline
              [attachment=2:o25qv8mt]<!-- ia2 -->CurviLoft_Helix.skp<!-- ia2 -->[/attachment:o25qv8mt]
              you have to switch the properties..
              for instance, try the same thing with tig's extrude edges by rails.. use the helix lines as the rails and the little shorties as profiles (well, make them curves first).. you'll see a similar though actually worse error.. then, do it again but choose the helix as profiles and the little lines as rails.. all is better.
              to do that in curviloft, click in a black area of the preview skin to bring up this dialog:
              [attachment=1:o25qv8mt]<!-- ia1 -->001.jpg<!-- ia1 -->[/attachment:o25qv8mt]
              then use the top left button to re-orient
              [attachment=0:o25qv8mt]<!-- ia0 -->002.jpg<!-- ia0 -->[/attachment:o25qv8mt]
                Thanks Jeff.
                Strangely I did use TIG EebyR it it worked perfectly. Though I used one shawty as both 'Profile' and 'Melding Profile'. Didn't try it with separate profiles.
                Anyway thanks for the fix πŸ‘
                • tibetT Offline
                  tibet
                  hi ,
                  i have deleted curviloft icons by accident.
                  could you please tell me how to restore them in sketchup 8 pro
                  thanks
                  SU 2015 Pro on Win10 x64
                    @tibet said:
                    hi ,
                    thanks
                    Go to the first post in this thread and download the files and install them as instructed. The icons will be restored and some other scripts etc will be overwritten - but that doesn't matter... πŸ˜•
                    However, if you don't mean you've actually thrown away the files but you mean you've 'closed the toolbar' or 'deactivated the extension' then simply reactivate the extension through Window > Preferences > Extensions and/or switch on the toolbar through View > Toolbars...
                      @tibet said:
                      hi ,
                      thanks
                      It's interesting what you can find on these forums.
                        pythiaz
                        Super LOL~!! 😎
                        • 66searcher6 Offline
                          66searcher
                          thanks fredo6
                          πŸ‘ one of the best of all su plugins ! well done!
                          thanks Karl (Charly)
                          πŸ‘ great works by you motivates me...good luck.
                          http://hamidtoliat.deviantart.com/
                          • fredo6F Offline
                            Joel,
                            Can you post the model or a typical case, because I am not clear on the issue you face
                            • jgbJ Offline
                              jgb
                              I may be doing something wrong, but there is a very simple curve that Curviloft (CL) seems to have a problem with.
                              If I have 2 surfaces that I punch a hole in, say a round airplane fuselage that I put a round window or door opening in, CL won't face the rim of the opening.
                              After I delete the 2 wall bits in the opening, I select the 2 perimeters and call CL to do its magic. In effect, create the rim or ring. All I get are magenta lines.
                              If I join 1 pair of verticies, still no go. I have to draw 2 joiners (close together), and deselect the lines of the perimeter between the 2 joiners and CL does its magic in a flash.
                              This happens even to 2 rings in free space, unconnected to anything. I have to break both rings, then rejoin them after CL makes the curve.
                              Yet yesterday I made a large complex curved door, and CL rimmed it perfectly in 5 seconds, compared to 20 minutes or more to my making the perimeter manually. So I'm NOT complaining.
                              Fredo, as requested. The model I discovered this is way too big to upload, so I made an example.
                              I drew 2 rings offset in X, Y & Z axis.
                              Select 2 rings alone and CL will not form a rim.
                              Join rings with only 1 line, select all and CL creates a twisted rim.
                              Join rings with 2 lines and select all, no rim forms.
                              Deselect 2 bits of ring segment and CL forms proper rim.
                              As explained above, 4 sets of rings
                              jgb
                              • H Offline
                                hygicell
                                I am getting a lot of error messages on the Fredo6 plugins at startup of Sketchup 8 Pro:
                                please help
                                Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftAlgo.rb
                                uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftCurveMover.rb
                                uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftLoader.rb
                                uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftPalette.rb
                                uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/CurviloftTool.rb
                                uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_10/__loader.rb
                                undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftAlgo.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftCurveMover.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftPalette.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/CurviloftTool.rb uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/CURVILOFT_Dir_11/bootstrap_Curviloft.rb
                                uninitialized constant Curviloft::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREDOSCALE_Dir_21/__loader.rb
                                undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREDOSCALE_Dir_21/bootstrap_FredoScale.rb (eval):1: uninitialized constant FredoScale::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/FreeScale_Common.rb uninitialized constant FreeScale::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/FreeScale_Tool.rb uninitialized constant FreeScale::SU_MAJOR_VERSIONError Loading File H:/programmas/google/Google SketchUp 8/Plugins/FREESCALE_Dir_10/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/GhostCompAlgo.rb
                                uninitialized constant GhostComp::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/GhostCompLoader.rb
                                uninitialized constant GhostComp::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/GHOSTCOMP_Dir_10/__loader.rb
                                undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/HoverSelect_Palette.rb uninitialized constant HoverSelect::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/HoverSelect_main.rb uninitialized constant HoverSelect::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/HOVERSELECT_Dir_11/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/__loader.rb
                                undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ROUNDCORNER_Dir_22/bootstrap_RoundCorner.rb uninitialized constant RoundCorner::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/EraserOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/FreehandOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/LibOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/LineOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/OffsetAlgoOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/OffsetOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/PaletteOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/PolylineOnSurface.rb uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/__loader.rb undefined method effective_load' for nil:NilClassError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TOS_Dir_18/bootstrap_OnSurface.rb
                                uninitialized constant SUToolsOnSurface::T6Error Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/arc.rb
                                uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/attributes.rb
                                uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/babelfish.rb
                                uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/bezier.rb
                                uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/binary.rb
                                uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/bounds.rb
                                uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/TT_Lib2/color.rb
                                uninitialized constant TTError Loading File H:/programmas/google/Google SketchUp 8/Plugins/ruby/singleton.rb
                                undefined method extend_object' for Singleton'
                                  Frank
                                  Sounds like you haven't got all of the files installed in the right places ?
                                  Please reread the installation instructions.
                                  Also see this thread for help on extracting zipped files and keeping their subfolder structure with Plugins etc http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                  Also if you have inadvertently put files directly into Plugins that ought to be within a subfolder, then please remove them as they might cause unexpected results as they will then auto-load at startup rather than when the main tool wants them to...
                                  • jgbJ Offline
                                    jgb
                                    Joel,
                                    I did! I appended it to my post, but so far no reply.
                                    jgb
                                      @jgb said:
                                      Joel,
                                      i can skin that thing with zero problems.
                                      i think you might be using the wrong tool.. i think you're trying to use curviloft's Skinning when you should be using regular Loft (the first of the 3 icons in the toolbar)
                                      just select the two rings then click on the Loft icon.
                                      • H Offline
                                        hygicell
                                        @tig said:
                                        Frank
                                        I have reinstalled everything as per the instructions
                                        then ran duplicate cleaner 2.0 to find any .rb leftovers from the previous installation directly into plugins folder and erased them
                                        the problem remains
                                        should I be looking for other files than with the .rb extension and erase these duplicates too?
                                        Frank
                                          Please don't start removing files willy-nilly.
                                          Only the the files inside the subfolders that have equivalents wrongly installed in Plugins are to be removed - it's recommended that these put into a 'disabled folder' [erasing them is a little drastic - especially when you are not sure what you are doing - at least that way they can be moved back if you've messed up !]. There will also be .rb files in Plugins installed by other tools that you still need! AND of course there are .rb files installed as 'loaders' to run files inside subfolders that come in the zip file 'loose' rather than in a subfolder of Plugins...
                                          If you are getting similar error messages then are you sure the files and files in relative subfolders are installed properly. I noticed that you have a drive with an unusual path - H:/programmas/google/Google SketchUp 8/Plugins/ - the default is something like C:/Program Files/Google/Google SketchUp 8/Plugins/
                                          Please type this in the Ruby Console + <enter> and post the results $LOAD_PATH
                                          It should include your H: folder Plugins path.
                                          With Vista/Win7 there can be a 'Compatibility Files' issue [ΒΏArchivos de Compatibilidad?]... which happens if you don't have full security permissions to read/write/etc to the the Plugins folder and/or its subfolders and/or files. It looks like you have done it OK, and there are no error messages... but really the OS has put the new things in a separate subfolder to protect you from yourself! In these cases there's a 'Compatibility Files' button added to the top of the window of the affect folder[s] - you click on that to see what's messed up... Fix your permissions under properties, security as an admin...
                                          Can you post a screen-shot showing your Plugins folder structure etc if none of this is working...
                                          • H Offline
                                            hygicell
                                            I have installed Sketchup 8 pro on an external disk so I can easily take it with me
                                            my other plugins work fine
                                            ? Only the the files inside the subfolders that have equivalents wrongly installed in Plugins are to be removed ?
                                            would it not be the other way round?
                                            I removed the equivalents in the plugins folder and left the ones in the subfolders
                                            H;\programmas\google\Google SketchUp 8\Plugins\
                                            2DTools\
                                            AutoCenterPoint\
                                            clf_simple_loft\
                                            ctsMaker\
                                            CURVILOFT_Dir_11\
                                            DEFPARAM_Dir\
                                            Dom_brevenchatij\
                                            DoorTools\
                                            DWGExport\
                                            Examples\
                                            FREDOSCALE_Dir_21\
                                            FREESCALE_Dir_10\
                                            GHOSTCOMP_Dir_10\
                                            HOVERSELECT_Dir_11\
                                            JPP_Dir\
                                            JPP_Dir_15\
                                            Layer Manager\
                                            layers\
                                            ldd\
                                            LIBFREDO6_Dir_37\
                                            Ocean\
                                            Projection\
                                            RDE_Dir\
                                            ROUNDCORNER_Dir_23\
                                            ruby\
                                            skin\
                                            SoapSkinBubble\
                                            TIGtools\
                                            TOS_Dir_18\
                                            TT_Lib2\
                                            Utilities\
                                            WindowTools\
                                            0.skb
                                            1.skb
                                            2.skb
                                            2D#.rb
                                            3.skb
                                            AddVertex+.rb
                                            Align User Guide.pdf
                                            align_2D.rb
                                            align_tool.rb
                                            AllowDWGImportInSketchUp7.msi
                                            arc_centerpoint.rb
                                            auto_centerpoint.rb
                                            BzRoundEdge.rb
                                            cadspan.rbs
                                            calc.rb
                                            CenterPoint.rb
                                            Chamfer_Along_Path.rb
                                            clf_color_by_slope.rb
                                            clf_simple_loft_loader.rb
                                            closeopens.rb
                                            Cloud Quick Tutorial.pdf
                                            Cloud V6.pdf
                                            cloud_v6.rb
                                            co_tool.html
                                            co_toola.rb
                                            ComponentReporter+.rb
                                            ConstructFaceNormal.rb
                                            curve_maker.rb
                                            curvestitcher.rb
                                            deBabelizer.rb
                                            delauney2.rb
                                            demeter-main.rbs
                                            DoorTool.txt
                                            DoorTools.rb
                                            DWGExport.rbs
                                            engineeringtoolbox.rb
                                            examp_les.rb
                                            example.dat
                                            examples.rb
                                            extrudeEdgesByEdges.rb
                                            f2f.rb
                                            faceFlattener019.rb
                                            file.php
                                            FilletTool.rb
                                            fixSolid.rb
                                            flightpathtool.rb
                                            GetCentroid.rb
                                            GetDimensions.rb
                                            hide_faces_edges.rb
                                            hideall.htm
                                            hidetool.rb
                                            jf_follow_this.rb
                                            jf_spheretool.rb
                                            jointpushpull.rb
                                            kml_mesh_exporter.rb
                                            ky_Delete_Interior_Faces.rb
                                            ky_Group_PushPull_2DFaces.rb
                                            Layer Manager v6.pdf
                                            layer_manager_extension_v5.rb
                                            layer_manager_extension_v6.rb
                                            layer_manager_v5.txt
                                            layerbymaterial.rb
                                            layers.rb
                                            layers_materials.rb
                                            layers_show_hide_all.rb
                                            ldd.rbs
                                            LibFredo6.rb
                                            LibTraductor.def
                                            LibTraductor.rb
                                            Lines2Components.rb
                                            load_sketchapps.rb
                                            lsystem.rb
                                            makefaces(2).rb
                                            makefaces.rb
                                            makeNamedGroup.rb
                                            manifold.rb
                                            massmaterialimporter.rb
                                            Mirror_31.rb
                                            move_to_origin.rb
                                            move_to_origin_and_center.rb
                                            moveit.rb
                                            new.txt
                                            nudge.rb
                                            numbered_grid.rb
                                            ocean_extension.rb
                                            Organizer.rb
                                            organizerEdit.log
                                            pageLayers.rb
                                            Paint_back_faces v2.0.rb
                                            parking.rb
                                            pathcopy.rb
                                            perp_line_plane.rb
                                            PipeAlongPath.rb
                                            plugins_help.rb
                                            plugins_help_TIG.rb
                                            pnts2mesh.rb
                                            points_cloud_triangulation.rb
                                            ProgressBar.rb.htm
                                            Projection Documentation.pdf
                                            Projection.pdf
                                            projection_extension.rb
                                            PurgeAll.rb
                                            push_pull_vector.rb
                                            PutOnLayer_bmw.rb
                                            PutOnLayer_ForPublicRelease.rb
                                            read_me.txt
                                            reglue.rb
                                            rename_comp_inst.rb
                                            repaint_face.rb
                                            repair_broken_lines.rb
                                            Roof.rb
                                            roofplanfollower.rb
                                            rot90.rb
                                            rps_texturewrite.rb
                                            scene_rename.rb
                                            sceneExporter.rb
                                            screw_21.rb
                                            script_loader.rb
                                            SectionCutFace.rb
                                            simplify.rb
                                            SimplifyContours.rb
                                            skin.rb
                                            SmustardOrganizerExcludeFolders.txt
                                            SoapSkinBubbleTools.rb
                                            Srub.rb
                                            stair_maker062.rb
                                            stitcher.rb
                                            stock_maker.rb
                                            stray_lines.rb
                                            sublend.rb
                                            taper_maker.rb
                                            Terrain Reshaper User guide.pdf
                                            terrain_reshaper.rb
                                            TextTag14.rb
                                            tf.rb
                                            toolbar.rb
                                            trim_extend.rb
                                            tt_cleanup.rb
                                            tt_solid_inspector.rb
                                            unfoldtool.rb
                                            unhide_all.htm
                                            unhide_all.rb
                                            utilities.rb
                                            utilities_10.rb
                                            vector.flat_angle.rb
                                            viewMemory.rb
                                            VolumeCalculator21.rb
                                            weld.rb
                                            Win32API.so
                                            WindowTools.rb
                                            ZLoader__OnSurface.rb
                                            zone.rb
                                            zoom_selection.rb
                                            Zorro.rb
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 65
                                            • 66
                                            • 17 / 66
