    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.5k Views 172 Watching
    • P
      Pierreden
      @robert111 said:
      andre51
      how to make leaves with this plugin plzzzzzzzzzzz
      i like you ivy very nice
      can you make tutu for your ivy setting plz
      Thats from the original standalone plugin foud here
      Leaves will soon be available in this plugin too, but isnt at the moment πŸ˜‰
      • OxerO
        Oxer
        I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
          The Tool class activate doesn't have arguments ( initialize can)
          def activate(view)
            puts view
          line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
          It could be
          def activate
            puts Sketchup.active_model.active_view
          with little use??
            andre51
            Hi Robert111
            Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
            Regards
            Andre
            • P
              Pierreden
              def activate(view)
              >   puts view
              > end
              It could be
              def activate
              > end
              with little use??
              Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
              • OxerO
                Oxer
                On mac the plugin still does not work, now the Ruby Console appears in blank.
                • FletchF
                  Fletch
                  Thanks for sharing this plugin. πŸ˜„ I have been waiting a while to see someone implement the ivy generator with SketchUp.
                  Is it supposed to work well with any units? If my units are inches, it seems to work ok. But if they are meters, not so much. 😞
                  Fletch
                    maxosmedia
                    Does not work on Mac
                      mukul.ar
                      This seems like the beginning of something big... glad to have caught on early..πŸ˜„ will definitely follow this post... all the best..!
                      My Works
                        andre51
                        Really like the plug-in and cant wait for further tweaking!
                        Thanks again!
                          robert111
                          thnaks andre51
                          i use fur with this plugin but i haven't nice leaf with fur
                          can you show your leaf setting with fur plugin plz
                            andre51
                            Hi Robert
                            I use a leaf component that came with the plants from Solo so I cannot share it here but you can find a lot of ivy on 3D Warehouse. Just load the component somewhere in the drawing and select "make from component" in fur plug-in - you'll see your component listed there. Hope this helps!
                            Cheers
                            • P
                              Pierreden
                              @Mac Users: Really sorry about the plugin not working. I have absolutely no clue what the issue is, but I will borrow a mac this weekend and see what i can work out πŸ˜‰
                              @Andre: Thank you! Those renders looks great. What plugin do you use? Im currently looking at the distribution of leaves, and that lookes great πŸ‘
                              I dont know when the next update will be released, but heres a little teaser of whats to come.
                              cheers
                              http://i.imgur.com/4R7V2.jpg
                              • kaluK
                                kalu
                                Hi Guys:
                                I read all the comments and when select the plugin and I create the Ivy there is not setup so where is the setup? Can I change something or just grow and grow and that's it?
                                I place an Image of the plugin installed:
                                I missing the "Plugins/SketchupIvy/setup.rb" Is an awesome plugin already see the near future.... Thank you for the great design and comments. πŸ‘
                                THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                  andre51
                                  Hi Pierreden
                                  I use the fur plug in to distribute the leaves.
                                  Cheers
                                  • kaluK
                                    kalu
                                    Can someone respond my question?...
                                    Thanks.
                                      mukul.ar
                                      Have you tried sending a PM to Pierreden...? he is best suited to answer your queries... Be a little patient... πŸ˜„
                                      My Works
                                      • GaieusG
                                        The forums (this topic) is even better as we can all learn from it.
                                        Indeed. The plugin is still in an early phase of coding and what we see is just a preliminary "proof of concept". Somewhere Pierre even wrote that he has not made the settings dialogue yet.
                                        (I am also eagerly looking forward to the development...)
                                        πŸ˜‰
                                        • P
                                          Pierreden
                                          Thanks.
                                          Im sorry for my late reply. I have uploaded a new version which includes a gui!
                                          @everyone: Realy hope version 0.3 solves some of yout issues. It feels both faster and more stable on my computer, but if/when you experience problems, bugsplats or bugs, please pm me or write here. I will answer you as quick as possible.
                                          Also, f you have any suggestions regarding further development i would love to here them! πŸ‘
                                          Regards
                                          Pierre
                                          • soloS
                                            Cool UI.
                                            One issue, if you close it you cannot open it again.
                                            • 36
                                            • 37
                                            • 3 / 37
