    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 511.0k Views 172 Watching
      @dave r said:
      It is an interesting plugin. Thank you. Like Alan, I don't see the red latent growth path. Most of the time orbiting doesn't help. Also, even with branching probability set to .99 I don't get any branches. If I have units set to Fractional as I normally do I get the following in the console.
      %(#FF0000)[nil
      Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/tool.rb:43:in onLButtonDown'
      C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/tool.rb:43]
      Line #43 in tool.rb should read something like this, so that the raytest can fail and not break things when there is no intersect...
      @iv = Si::Ivy.new(intersect[0], intersect[1].last.normal) **if intersect and intersect[1]**
      It should NOT be the result of 'units' settings - it's just an untrapped occurrence in the code when the raytest returns 'nil'.
        Well, you know how much I know about Ruby. Still, if I change the units to Decimal>Millimeters, the plugin works. If I change it to Fractional, it doesn't.
          BUT the error you published isn't caused by the units change ?
          Do you get any other errors...
          The way it's coded is quite convoluted but I see no issues with fractional sizes as these are [probably?] returned as lengths anyway ?
          • OxerO
            Oxer
            I work on Mac and i have probed to add the tool.rb to my Plugins Folder, when run the plugin this is the message in Ruby Console:
            Message Ruby Console
              @Oxer: plugins should not go in your User folder. They should be under the root folder.
              See this page for description: http://code.google.com/apis/sketchup/docs/loading.html
              /Library/Application Support/Google SketchUp [n]/SketchUp/plugins
                Oxer - the tool.rb file is to go into the Ivy subfolder, NOT into Plugins directly!
                  TIG, I shut down SketchUp and restarted it. It doesn't give any errors this time running in Fractional so I don't know why changing units affected the results. I didn't get any other error messages before. It still doesn't create branching and the red lines don't show up. Perhaps the author will refine the plugin further and I'll give it a try then. I've got too much other stuff to do for the moment.
                  • P
                    Pierreden
                    @Dave: Uploaded a new version in the Top post. Try that one πŸ‘
                    • L
                      Lobster
                      Replaced the tool as suggested,
                      Ruby Window output on activating plug in is
                      Error: #<ArgumentError: wrong number of arguments (0 for 1)>
                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in activate' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in select_tool'
                      When clicking to grow it is this
                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in add' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in getExtents'
                      /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in refresh' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in onLButtonDown'
                      Regards
                      Sam
                        C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:50: warning: parenthesize argument(s) for future version
                        C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:85: warning: parenthesize argument(s) for future version
                        (20.7643", 4.678738", 0")
                        #Sketchup::Face:0x8a963e0
                        Faces: 1
                        10 / Branches: 1 / Live Branches: 1 / 0.016
                        Nor red lines or branching either. 😞
                        • OxerO
                          Oxer
                          Thomthom, i have changed the plugin to the root /Library/Application Support/Google SketchUp [n/SketchUp/plugins] (generally i haven't problems with the plugins if i put them in the other root) and i replaced the tool.rb in the Ivy subfolder, but the plugin don't works, this is the new message in the Ruby Console:
                          • P
                            Pierreden
                            Sorry Guys! The file i updated 10 minutes ago was actually a downdate πŸ˜’ Sorry for the inconvenience. The new one should work.
                              robert111
                              andre51
                              how to make leaves with this plugin plzzzzzzzzzzz
                              i like you ivy very nice
                              can you make tutu for your ivy setting plz
                              • P
                                Pierreden
                                @robert111 said:
                                andre51
                                Thats from the original standalone plugin foud here
                                Leaves will soon be available in this plugin too, but isnt at the moment πŸ˜‰
                                • OxerO
                                  Oxer
                                  I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
                                    The Tool class activate doesn't have arguments ( initialize can)
                                    def activate(view)
                                      puts view
                                    line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
                                    It could be
                                    def activate
                                      puts Sketchup.active_model.active_view
                                    with little use??
                                      andre51
                                      Hi Robert111
                                      Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
                                      Regards
                                      Andre
                                      • P
                                        Pierreden
                                        def activate(view)
                                        >   puts view
                                        > end
                                        It could be
                                        def activate
                                        > end
                                        with little use??
                                        Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
                                        • OxerO
                                          Oxer
                                          On mac the plugin still does not work, now the Ruby Console appears in blank.
                                          • FletchF
                                            Fletch
                                            Thanks for sharing this plugin. πŸ˜„ I have been waiting a while to see someone implement the ivy generator with SketchUp.
                                            Is it supposed to work well with any units? If my units are inches, it seems to work ok. But if they are meters, not so much. 😞
                                            Fletch
                                            • 36
                                            • 37
                                            • 3 / 37
