    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 392.0k Views 172 Watching
      @pierreden said:
      @Dave: Uploaded a new version in the Top post. Try that one πŸ‘
      C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:50: warning: parenthesize argument(s) for future version
      C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:85: warning: parenthesize argument(s) for future version
      (20.7643", 4.678738", 0")
      #Sketchup::Face:0x8a963e0
      Faces: 1
      10 / Branches: 1 / Live Branches: 1 / 0.016
      Nor red lines or branching either. 😞
      • OxerO Offline
        Oxer
        Thomthom, i have changed the plugin to the root /Library/Application Support/Google SketchUp [n/SketchUp/plugins] (generally i haven't problems with the plugins if i put them in the other root) and i replaced the tool.rb in the Ivy subfolder, but the plugin don't works, this is the new message in the Ruby Console:
          Pierreden
          Sorry Guys! The file i updated 10 minutes ago was actually a downdate πŸ˜’ Sorry for the inconvenience. The new one should work.
            robert111
            andre51
            how to make leaves with this plugin plzzzzzzzzzzz
            i like you ivy very nice
            can you make tutu for your ivy setting plz
              Pierreden
              @robert111 said:
              andre51
              Thats from the original standalone plugin foud here
              Leaves will soon be available in this plugin too, but isnt at the moment πŸ˜‰
              • OxerO Offline
                Oxer
                I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
                  The Tool class activate doesn't have arguments ( initialize can)
                  def activate(view)
                    puts view
                  line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
                  It could be
                  def activate
                    puts Sketchup.active_model.active_view
                  with little use??
                    andre51
                    Hi Robert111
                    Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
                    Regards
                    Andre
                      Pierreden
                      def activate(view)
                      >   puts view
                      > end
                      It could be
                      def activate
                      > end
                      with little use??
                      Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
                      • OxerO Offline
                        Oxer
                        On mac the plugin still does not work, now the Ruby Console appears in blank.
                        • FletchF Offline
                          Fletch
                          Thanks for sharing this plugin. πŸ˜„ I have been waiting a while to see someone implement the ivy generator with SketchUp.
                          Is it supposed to work well with any units? If my units are inches, it seems to work ok. But if they are meters, not so much. 😞
                          Fletch
                            maxosmedia
                            Does not work on Mac
                              mukul.ar
                              This seems like the beginning of something big... glad to have caught on early..πŸ˜„ will definitely follow this post... all the best..!
                              My Works
                                andre51
                                Really like the plug-in and cant wait for further tweaking!
                                Thanks again!
                                  robert111
                                  thnaks andre51
                                  i use fur with this plugin but i haven't nice leaf with fur
                                  can you show your leaf setting with fur plugin plz
                                    andre51
                                    Hi Robert
                                    I use a leaf component that came with the plants from Solo so I cannot share it here but you can find a lot of ivy on 3D Warehouse. Just load the component somewhere in the drawing and select "make from component" in fur plug-in - you'll see your component listed there. Hope this helps!
                                    Cheers
                                      Pierreden
                                      @Mac Users: Really sorry about the plugin not working. I have absolutely no clue what the issue is, but I will borrow a mac this weekend and see what i can work out πŸ˜‰
                                      @Andre: Thank you! Those renders looks great. What plugin do you use? Im currently looking at the distribution of leaves, and that lookes great πŸ‘
                                      I dont know when the next update will be released, but heres a little teaser of whats to come.
                                      cheers
                                      http://i.imgur.com/4R7V2.jpg
                                      • kaluK Offline
                                        kalu
                                        Hi Guys:
                                        I read all the comments and when select the plugin and I create the Ivy there is not setup so where is the setup? Can I change something or just grow and grow and that's it?
                                        I place an Image of the plugin installed:
                                        I missing the "Plugins/SketchupIvy/setup.rb" Is an awesome plugin already see the near future.... Thank you for the great design and comments. πŸ‘
                                        THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                          andre51
                                          Hi Pierreden
                                          I use the fur plug in to distribute the leaves.
                                          Cheers
                                          • kaluK Offline
                                            kalu
                                            Can someone respond my question?...
                                            Thanks.
                                            • 36
                                            • 37
                                            • 3 / 37
