    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 510.9k Views 172 Watching
      It is an interesting plugin. Thank you. Like Alan, I don't see the red latent growth path. Most of the time orbiting doesn't help. Also, even with branching probability set to .99 I don't get any branches. If I have units set to Fractional as I normally do I get the following in the console.
      %(#FF0000)[nil
      Error: #<NoMethodError: undefined method []' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/tool.rb:43:in onLButtonDown'
      C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/tool.rb:43]
        To ensure that all of the model is included in the current drawn view within the Tool's class you have this method
        def getExtents
            bbox=Sketchup.active_model.bounds
            bbox.add(@ip.position)if @ip and @ip.valid?
            return bbox
        assuming that @ip is your input point etc
          %(#FF0000)[nil
          Line #43 in tool.rb should read something like this, so that the raytest can fail and not break things when there is no intersect...
          @iv = Si::Ivy.new(intersect[0], intersect[1].last.normal) **if intersect and intersect[1]**
          It should NOT be the result of 'units' settings - it's just an untrapped occurrence in the code when the raytest returns 'nil'.
            Well, you know how much I know about Ruby. Still, if I change the units to Decimal>Millimeters, the plugin works. If I change it to Fractional, it doesn't.
              BUT the error you published isn't caused by the units change ?
              Do you get any other errors...
              The way it's coded is quite convoluted but I see no issues with fractional sizes as these are [probably?] returned as lengths anyway ?
              • OxerO
                Oxer
                I work on Mac and i have probed to add the tool.rb to my Plugins Folder, when run the plugin this is the message in Ruby Console:
                Message Ruby Console
                  @Oxer: plugins should not go in your User folder. They should be under the root folder.
                  See this page for description: http://code.google.com/apis/sketchup/docs/loading.html
                  /Library/Application Support/Google SketchUp [n]/SketchUp/plugins
                    Oxer - the tool.rb file is to go into the Ivy subfolder, NOT into Plugins directly!
                      TIG, I shut down SketchUp and restarted it. It doesn't give any errors this time running in Fractional so I don't know why changing units affected the results. I didn't get any other error messages before. It still doesn't create branching and the red lines don't show up. Perhaps the author will refine the plugin further and I'll give it a try then. I've got too much other stuff to do for the moment.
                      • P
                        Pierreden
                        @Dave: Uploaded a new version in the Top post. Try that one πŸ‘
                        • L
                          Lobster
                          Replaced the tool as suggested,
                          Ruby Window output on activating plug in is
                          Error: #<ArgumentError: wrong number of arguments (0 for 1)>
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in activate' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in select_tool'
                          When clicking to grow it is this
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in add' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in getExtents'
                          /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in refresh' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in onLButtonDown'
                          Regards
                          Sam
                            C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:50: warning: parenthesize argument(s) for future version
                            C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:85: warning: parenthesize argument(s) for future version
                            (20.7643", 4.678738", 0")
                            #Sketchup::Face:0x8a963e0
                            Faces: 1
                            10 / Branches: 1 / Live Branches: 1 / 0.016
                            Nor red lines or branching either. 😞
                            • OxerO
                              Oxer
                              Thomthom, i have changed the plugin to the root /Library/Application Support/Google SketchUp [n/SketchUp/plugins] (generally i haven't problems with the plugins if i put them in the other root) and i replaced the tool.rb in the Ivy subfolder, but the plugin don't works, this is the new message in the Ruby Console:
                              • P
                                Pierreden
                                Sorry Guys! The file i updated 10 minutes ago was actually a downdate πŸ˜’ Sorry for the inconvenience. The new one should work.
                                  robert111
                                  andre51
                                  how to make leaves with this plugin plzzzzzzzzzzz
                                  i like you ivy very nice
                                  can you make tutu for your ivy setting plz
                                  • P
                                    Pierreden
                                    @robert111 said:
                                    andre51
                                    Thats from the original standalone plugin foud here
                                    Leaves will soon be available in this plugin too, but isnt at the moment πŸ˜‰
                                    • OxerO
                                      Oxer
                                      I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
                                        The Tool class activate doesn't have arguments ( initialize can)
                                        def activate(view)
                                          puts view
                                        line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
                                        It could be
                                        def activate
                                          puts Sketchup.active_model.active_view
                                        with little use??
                                          andre51
                                          Hi Robert111
                                          Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
                                          Regards
                                          Andre
                                          • P
                                            Pierreden
                                            def activate(view)
                                            >   puts view
                                            > end
                                            It could be
                                            def activate
                                            > end
                                            with little use??
                                            Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
                                            • 36
                                            • 37
                                            • 3 / 37
