    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.5k Views 172 Watching
    • P
      Pierreden
      @Dave: Uploaded a new version in the Top post. Try that one πŸ‘
      • L
        Lobster
        Replaced the tool as suggested,
        Ruby Window output on activating plug in is
        Error: #<ArgumentError: wrong number of arguments (0 for 1)>
        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in activate' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in select_tool'
        When clicking to grow it is this
        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in add' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in getExtents'
        /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in refresh' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in onLButtonDown'
        Regards
        Sam
          C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:50: warning: parenthesize argument(s) for future version
          C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:85: warning: parenthesize argument(s) for future version
          (20.7643", 4.678738", 0")
          #Sketchup::Face:0x8a963e0
          Faces: 1
          10 / Branches: 1 / Live Branches: 1 / 0.016
          Nor red lines or branching either. 😞
          • OxerO
            Oxer
            Thomthom, i have changed the plugin to the root /Library/Application Support/Google SketchUp [n/SketchUp/plugins] (generally i haven't problems with the plugins if i put them in the other root) and i replaced the tool.rb in the Ivy subfolder, but the plugin don't works, this is the new message in the Ruby Console:
            • P
              Pierreden
              Sorry Guys! The file i updated 10 minutes ago was actually a downdate πŸ˜’ Sorry for the inconvenience. The new one should work.
                robert111
                andre51
                how to make leaves with this plugin plzzzzzzzzzzz
                i like you ivy very nice
                can you make tutu for your ivy setting plz
                • P
                  Pierreden
                  @robert111 said:
                  andre51
                  Thats from the original standalone plugin foud here
                  Leaves will soon be available in this plugin too, but isnt at the moment πŸ˜‰
                  • OxerO
                    Oxer
                    I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
                      The Tool class activate doesn't have arguments ( initialize can)
                      def activate(view)
                        puts view
                      line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
                      It could be
                      def activate
                        puts Sketchup.active_model.active_view
                      with little use??
                        andre51
                        Hi Robert111
                        Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
                        Regards
                        Andre
                        • P
                          Pierreden
                          def activate(view)
                          >   puts view
                          > end
                          It could be
                          def activate
                          > end
                          with little use??
                          Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
                          • OxerO
                            Oxer
                            On mac the plugin still does not work, now the Ruby Console appears in blank.
                            • FletchF
                              Fletch
                              Thanks for sharing this plugin. πŸ˜„ I have been waiting a while to see someone implement the ivy generator with SketchUp.
                              Is it supposed to work well with any units? If my units are inches, it seems to work ok. But if they are meters, not so much. 😞
                              Fletch
                                maxosmedia
                                Does not work on Mac
                                  mukul.ar
                                  This seems like the beginning of something big... glad to have caught on early..πŸ˜„ will definitely follow this post... all the best..!
                                  My Works
                                    andre51
                                    Really like the plug-in and cant wait for further tweaking!
                                    Thanks again!
                                      robert111
                                      thnaks andre51
                                      i use fur with this plugin but i haven't nice leaf with fur
                                      can you show your leaf setting with fur plugin plz
                                        andre51
                                        Hi Robert
                                        I use a leaf component that came with the plants from Solo so I cannot share it here but you can find a lot of ivy on 3D Warehouse. Just load the component somewhere in the drawing and select "make from component" in fur plug-in - you'll see your component listed there. Hope this helps!
                                        Cheers
                                        • P
                                          Pierreden
                                          @Mac Users: Really sorry about the plugin not working. I have absolutely no clue what the issue is, but I will borrow a mac this weekend and see what i can work out πŸ˜‰
                                          @Andre: Thank you! Those renders looks great. What plugin do you use? Im currently looking at the distribution of leaves, and that lookes great πŸ‘
                                          I dont know when the next update will be released, but heres a little teaser of whats to come.
                                          cheers
                                          http://i.imgur.com/4R7V2.jpg
                                          • kaluK
                                            kalu
                                            Hi Guys:
                                            I read all the comments and when select the plugin and I create the Ivy there is not setup so where is the setup? Can I change something or just grow and grow and that's it?
                                            I place an Image of the plugin installed:
                                            I missing the "Plugins/SketchupIvy/setup.rb" Is an awesome plugin already see the near future.... Thank you for the great design and comments. πŸ‘
                                            THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                            • 36
                                            • 37
                                            • 3 / 37
