    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 450.2k Views 172 Watching
    • OxerO Offline
      Oxer
      I work on Mac and i have probed to add the tool.rb to my Plugins Folder, when run the plugin this is the message in Ruby Console:
      Message Ruby Console
        @Oxer: plugins should not go in your User folder. They should be under the root folder.
        See this page for description: http://code.google.com/apis/sketchup/docs/loading.html
        /Library/Application Support/Google SketchUp [n]/SketchUp/plugins
          Oxer - the tool.rb file is to go into the Ivy subfolder, NOT into Plugins directly!
            TIG, I shut down SketchUp and restarted it. It doesn't give any errors this time running in Fractional so I don't know why changing units affected the results. I didn't get any other error messages before. It still doesn't create branching and the red lines don't show up. Perhaps the author will refine the plugin further and I'll give it a try then. I've got too much other stuff to do for the moment.
              Pierreden
              @Dave: Uploaded a new version in the Top post. Try that one πŸ‘
                Lobster
                Replaced the tool as suggested,
                Ruby Window output on activating plug in is
                Error: #<ArgumentError: wrong number of arguments (0 for 1)>
                /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in activate' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in select_tool'
                When clicking to grow it is this
                /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in add' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in getExtents'
                /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in refresh' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in onLButtonDown'
                Regards
                Sam
                  C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:50: warning: parenthesize argument(s) for future version
                  C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:85: warning: parenthesize argument(s) for future version
                  (20.7643", 4.678738", 0")
                  #Sketchup::Face:0x8a963e0
                  Faces: 1
                  10 / Branches: 1 / Live Branches: 1 / 0.016
                  Nor red lines or branching either. 😞
                  • OxerO Offline
                    Oxer
                    Thomthom, i have changed the plugin to the root /Library/Application Support/Google SketchUp [n/SketchUp/plugins] (generally i haven't problems with the plugins if i put them in the other root) and i replaced the tool.rb in the Ivy subfolder, but the plugin don't works, this is the new message in the Ruby Console:
                      Pierreden
                      Sorry Guys! The file i updated 10 minutes ago was actually a downdate πŸ˜’ Sorry for the inconvenience. The new one should work.
                        robert111
                        andre51
                        how to make leaves with this plugin plzzzzzzzzzzz
                        i like you ivy very nice
                        can you make tutu for your ivy setting plz
                          Pierreden
                          @robert111 said:
                          andre51
                          Thats from the original standalone plugin foud here
                          Leaves will soon be available in this plugin too, but isnt at the moment πŸ˜‰
                          • OxerO Offline
                            Oxer
                            I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
                              The Tool class activate doesn't have arguments ( initialize can)
                              def activate(view)
                                puts view
                              line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
                              It could be
                              def activate
                                puts Sketchup.active_model.active_view
                              with little use??
                                andre51
                                Hi Robert111
                                Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
                                Regards
                                Andre
                                  Pierreden
                                  def activate(view)
                                  >   puts view
                                  > end
                                  It could be
                                  def activate
                                  > end
                                  with little use??
                                  Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
                                  • OxerO Offline
                                    Oxer
                                    On mac the plugin still does not work, now the Ruby Console appears in blank.
                                    • FletchF Offline
                                      Fletch
                                      Thanks for sharing this plugin. πŸ˜„ I have been waiting a while to see someone implement the ivy generator with SketchUp.
                                      Is it supposed to work well with any units? If my units are inches, it seems to work ok. But if they are meters, not so much. 😞
                                      Fletch
                                        maxosmedia
                                        Does not work on Mac
                                          mukul.ar
                                          This seems like the beginning of something big... glad to have caught on early..πŸ˜„ will definitely follow this post... all the best..!
                                          My Works
                                            andre51
                                            Really like the plug-in and cant wait for further tweaking!
                                            Thanks again!
                                            • 36
                                            • 37
                                            • 3 / 37
