    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 543.5k Views 172 Watching
      @Oxer: plugins should not go in your User folder. They should be under the root folder.
      See this page for description: http://code.google.com/apis/sketchup/docs/loading.html
      /Library/Application Support/Google SketchUp [n]/SketchUp/plugins
        Oxer - the tool.rb file is to go into the Ivy subfolder, NOT into Plugins directly!
          TIG, I shut down SketchUp and restarted it. It doesn't give any errors this time running in Fractional so I don't know why changing units affected the results. I didn't get any other error messages before. It still doesn't create branching and the red lines don't show up. Perhaps the author will refine the plugin further and I'll give it a try then. I've got too much other stuff to do for the moment.
          • P
            Pierreden
            @Dave: Uploaded a new version in the Top post. Try that one πŸ‘
            • L
              Lobster
              Replaced the tool as suggested,
              Ruby Window output on activating plug in is
              Error: #<ArgumentError: wrong number of arguments (0 for 1)>
              /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in activate' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:87:in select_tool'
              When clicking to grow it is this
              /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in add' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:15:in getExtents'
              /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in refresh' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchupIvy/tool.rb:71:in onLButtonDown'
              Regards
              Sam
                C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:50: warning: parenthesize argument(s) for future version
                C:/Program Files/Google/Google SketchUp 8/Plugins/SketchupIvy/node.rb:85: warning: parenthesize argument(s) for future version
                (20.7643", 4.678738", 0")
                #Sketchup::Face:0x8a963e0
                Faces: 1
                10 / Branches: 1 / Live Branches: 1 / 0.016
                Nor red lines or branching either. 😞
                • OxerO
                  Oxer
                  Thomthom, i have changed the plugin to the root /Library/Application Support/Google SketchUp [n/SketchUp/plugins] (generally i haven't problems with the plugins if i put them in the other root) and i replaced the tool.rb in the Ivy subfolder, but the plugin don't works, this is the new message in the Ruby Console:
                  • P
                    Pierreden
                    Sorry Guys! The file i updated 10 minutes ago was actually a downdate πŸ˜’ Sorry for the inconvenience. The new one should work.
                      robert111
                      andre51
                      how to make leaves with this plugin plzzzzzzzzzzz
                      i like you ivy very nice
                      can you make tutu for your ivy setting plz
                      • P
                        Pierreden
                        @robert111 said:
                        andre51
                        Thats from the original standalone plugin foud here
                        Leaves will soon be available in this plugin too, but isnt at the moment πŸ˜‰
                        • OxerO
                          Oxer
                          I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
                            The Tool class activate doesn't have arguments ( initialize can)
                            def activate(view)
                              puts view
                            line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
                            It could be
                            def activate
                              puts Sketchup.active_model.active_view
                            with little use??
                              andre51
                              Hi Robert111
                              Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
                              Regards
                              Andre
                              • P
                                Pierreden
                                def activate(view)
                                >   puts view
                                > end
                                It could be
                                def activate
                                > end
                                with little use??
                                Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
                                • OxerO
                                  Oxer
                                  On mac the plugin still does not work, now the Ruby Console appears in blank.
                                  • FletchF
                                    Fletch
                                    Thanks for sharing this plugin. πŸ˜„ I have been waiting a while to see someone implement the ivy generator with SketchUp.
                                    Is it supposed to work well with any units? If my units are inches, it seems to work ok. But if they are meters, not so much. 😞
                                    Fletch
                                      maxosmedia
                                      Does not work on Mac
                                        mukul.ar
                                        This seems like the beginning of something big... glad to have caught on early..πŸ˜„ will definitely follow this post... all the best..!
                                        My Works
                                          andre51
                                          Really like the plug-in and cant wait for further tweaking!
                                          Thanks again!
                                            robert111
                                            thnaks andre51
                                            i use fur with this plugin but i haven't nice leaf with fur
                                            can you show your leaf setting with fur plugin plz
                                            • 36
                                            • 37
                                            • 3 / 37
