    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 454.4k Views 172 Watching
      Pierreden
      Sorry Guys! The file i updated 10 minutes ago was actually a downdate πŸ˜’ Sorry for the inconvenience. The new one should work.
        robert111
        andre51
        how to make leaves with this plugin plzzzzzzzzzzz
        i like you ivy very nice
        can you make tutu for your ivy setting plz
          Pierreden
          @robert111 said:
          andre51
          Thats from the original standalone plugin foud here
          Leaves will soon be available in this plugin too, but isnt at the moment πŸ˜‰
          • OxerO Offline
            Oxer
            I have installed the last revision SketchupIvy_v.0.1.5 but the problem persists on Mac OSX
              The Tool class activate doesn't have arguments ( initialize can)
              def activate(view)
                puts view
              line#88 et al is superfluous and could be omitted in its entirety ? Why give it 'view' simply to print to the Console?
              It could be
              def activate
                puts Sketchup.active_model.active_view
              with little use??
                andre51
                Hi Robert111
                Just convert the lines to tubes, create an ivy leaf component and use the fur plugin - you wil need a bit of trail and error but it works ok.
                Regards
                Andre
                  Pierreden
                  def activate(view)
                  >   puts view
                  > end
                  It could be
                  def activate
                  > end
                  with little use??
                  Thank you!!! I couldnt for the love of anything find out whats wrong! I guess the activate method is fired on initialization. stupid me. Top Post attachment updated
                  • OxerO Offline
                    Oxer
                    On mac the plugin still does not work, now the Ruby Console appears in blank.
                    • FletchF Offline
                      Fletch
                      Thanks for sharing this plugin. πŸ˜„ I have been waiting a while to see someone implement the ivy generator with SketchUp.
                      Is it supposed to work well with any units? If my units are inches, it seems to work ok. But if they are meters, not so much. 😞
                      Fletch
                        maxosmedia
                        Does not work on Mac
                          mukul.ar
                          This seems like the beginning of something big... glad to have caught on early..πŸ˜„ will definitely follow this post... all the best..!
                          My Works
                            andre51
                            Really like the plug-in and cant wait for further tweaking!
                            Thanks again!
                              robert111
                              thnaks andre51
                              i use fur with this plugin but i haven't nice leaf with fur
                              can you show your leaf setting with fur plugin plz
                                andre51
                                Hi Robert
                                I use a leaf component that came with the plants from Solo so I cannot share it here but you can find a lot of ivy on 3D Warehouse. Just load the component somewhere in the drawing and select "make from component" in fur plug-in - you'll see your component listed there. Hope this helps!
                                Cheers
                                  Pierreden
                                  @Mac Users: Really sorry about the plugin not working. I have absolutely no clue what the issue is, but I will borrow a mac this weekend and see what i can work out πŸ˜‰
                                  @Andre: Thank you! Those renders looks great. What plugin do you use? Im currently looking at the distribution of leaves, and that lookes great πŸ‘
                                  I dont know when the next update will be released, but heres a little teaser of whats to come.
                                  cheers
                                  http://i.imgur.com/4R7V2.jpg
                                  • kaluK Offline
                                    kalu
                                    Hi Guys:
                                    I read all the comments and when select the plugin and I create the Ivy there is not setup so where is the setup? Can I change something or just grow and grow and that's it?
                                    I place an Image of the plugin installed:
                                    I missing the "Plugins/SketchupIvy/setup.rb" Is an awesome plugin already see the near future.... Thank you for the great design and comments. πŸ‘
                                    THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
                                      andre51
                                      Hi Pierreden
                                      I use the fur plug in to distribute the leaves.
                                      Cheers
                                      • kaluK Offline
                                        kalu
                                        Can someone respond my question?...
                                        Thanks.
                                          mukul.ar
                                          Have you tried sending a PM to Pierreden...? he is best suited to answer your queries... Be a little patient... πŸ˜„
                                          My Works
                                            The forums (this topic) is even better as we can all learn from it.
                                            Indeed. The plugin is still in an early phase of coding and what we see is just a preliminary "proof of concept". Somewhere Pierre even wrote that he has not made the settings dialogue yet.
                                            (I am also eagerly looking forward to the development...)
                                            πŸ˜‰
                                            • 36
                                            • 37
                                            • 3 / 37
