    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
      SketchUpNoobie
      NEW RELEASEbug fix - better respect of offset distance in case where the surface is composed of faces with sharp angles.
      This will be great! Thanks! πŸ˜„ Have a cookie. πŸ˜‰ And...er...a beer. πŸ˜• Great combination. 🀒
      SketchUpNoobie: the complete noob in all things SketchUp.
      • jeff hammondJ Offline
        nice!
        works very well on my test case (which previously failed with v1.5).
        thanks for the update!
          dedmin
          SketchUp 8, Win7 32 - freezing too.
            driven
            hope this helps.
            Hi Fredo,
            Jeff's file fails on 10.5.8 as well, I'll attach the txt file
              cool, thanks for testing fellas.
              • fredo6F Offline
                NEW RELEASE
                version 1.7a - 25 Apr 11: Fix a major bug of v1.6 which was causing a freeze of Sketchup in some situations.
                If you installed v1.6, It is strongly recommended to move to JPP 1.7
                See main post for download.
                  driven
                  hi Fredo,
                  works on Jeff's skp on 10.5.8 now...
                  cheers
                    works here now too.
                    thank you
                      hey fredo
                      i've come across an instance where v1.6 is freezing sketchup and 1.5 handles it just fine.. i'm not sure if the problem is in something i'm doing wrong, something mac specific, or what.
                      i'll attach the .skp (v8).. the two faces i'm having problems with are the ones painted orange.
                      thanks
                      [edit -- removed file]
                      [and maybe someone else can try this with jpp v1.6 on windows (or mac to see if it's repeatable for them as well)]
                        baiduaiya
                         thank you very much
                          [IMPORTANT Version 1.6 has a big bug, causing a freeze of Sketchup in some situations. If you installed it, please move to JPP v1.7, which fixes the problem.]
                          Indeed, I have just had to update JPP as I had freezing with a model. Many-manythanks, Fredo, for this excellent tool and the constant upgrades!
                          πŸ‘
                          • fredo6F Offline
                            NEW RELEASE
                            version 1.8a - 01 May 11: Better respect the offset distance in case where the surface is composed of faces with sharp angles. In V1.8, this works also when there is an imposed plane set by Ctrl-Arrow.
                              NEW RELEASE
                              πŸ‘ πŸ‘ πŸ˜„
                                Ben Ritter
                                Fredo6, thank you.
                                  The JPP_Dir_17 folder is required?
                                    I think not - as it contains nothing that's not already in the new 18 version ??
                                    V18 works OK for me without v17... πŸ˜•
                                      I got confused because the zip file contained the 1.7 files as well as the 1.8...
                                      • fredo6F Offline
                                        Tom,
                                        Are you sure? Which unzip program do you use?
                                        It is true that I took a copy of the 1.7 zip file, emptied it, and then insert the 1.8 files. With Winzip, there is no problem. But it may not be true with other unzip utilities.
                                          driven
                                          it's empty, but in there on the mac as well, Stuffit Expander...
                                          • massimoM Offline
                                            massimo Moderator
                                            I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
                                            Oh and πŸ‘ πŸ‘ Fredo. πŸ˜„
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 18 / 19
