    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
    • Y Offline
      yokaxi
      thanks
      • H Offline
        hero719
        β˜€ πŸ‘ thk u sure!! i'm beginner.
        • N Offline
          Napper
          I've been trying to extrude a wasching bowl by 12mm. The JPP crashes on me every time I do this no matter whether I try it on my XP machine at work or my Mac at home. Is this a bug, or too many faces?
          Kind regards,
          Napper
          This washing bowl crashes JPP
            Napper
            It's an awkward shape to JPP...
            I can't get a good result either πŸ˜•
            Here's an alternative method...
            As it's a solid you can use Jim Foltz's 'shell' @12mm, then temporarily hide the top of the original outer-shell, PushPull the top of the new solid inner-shell up ~50mm so it will pierce the outer-shell's top, intersect both groups' geometry together, and then erase the unwanted parts in them, explode the two groups together and re-group as one, smooth it... πŸ˜„WHB_Test2[TIGd].PNGWHB_Test2[TIGd].skp
            • N Offline
              Napper
              Hi TIG,
              this worked quite well, actually! I had to redo it, as I had given you the inner shell and needed an outer shell but that was good practice, actually... :smile: And along the way I got a new plugin, I had not been aware of as of yet. So, what I wanted to say is: THANK YOU!!! :smile:
              Napper
                JasonDoggart
                Hi - thanks for all your hard work! This is such a useful, well designed tool!
                • fredo6F Offline
                  NEW RELEASE
                  version 1.6 - 22 Apr 11: bug fix - better respect of offset distance in case where the surface is composed of faces with sharp angles.
                  See main post for download.
                  [Edit: I fixed the link to the download thread. TIG...]
                    SketchUpNoobie
                    NEW RELEASEbug fix - better respect of offset distance in case where the surface is composed of faces with sharp angles.
                    This will be great! Thanks! πŸ˜„ Have a cookie. πŸ˜‰ And...er...a beer. πŸ˜• Great combination. 🀒
                    SketchUpNoobie: the complete noob in all things SketchUp.
                    • jeff hammondJ Offline
                      nice!
                      works very well on my test case (which previously failed with v1.5).
                      thanks for the update!
                        dedmin
                        SketchUp 8, Win7 32 - freezing too.
                          driven
                          hope this helps.
                          Hi Fredo,
                          Jeff's file fails on 10.5.8 as well, I'll attach the txt file
                            cool, thanks for testing fellas.
                            • fredo6F Offline
                              NEW RELEASE
                              version 1.7a - 25 Apr 11: Fix a major bug of v1.6 which was causing a freeze of Sketchup in some situations.
                              If you installed v1.6, It is strongly recommended to move to JPP 1.7
                                driven
                                hi Fredo,
                                works on Jeff's skp on 10.5.8 now...
                                cheers
                                  works here now too.
                                  thank you
                                    hey fredo
                                    i've come across an instance where v1.6 is freezing sketchup and 1.5 handles it just fine.. i'm not sure if the problem is in something i'm doing wrong, something mac specific, or what.
                                    i'll attach the .skp (v8).. the two faces i'm having problems with are the ones painted orange.
                                    thanks
                                    [edit -- removed file]
                                    [and maybe someone else can try this with jpp v1.6 on windows (or mac to see if it's repeatable for them as well)]
                                      baiduaiya
                                       thank you very much
                                        [IMPORTANT Version 1.6 has a big bug, causing a freeze of Sketchup in some situations. If you installed it, please move to JPP v1.7, which fixes the problem.]
                                        Indeed, I have just had to update JPP as I had freezing with a model. Many-manythanks, Fredo, for this excellent tool and the constant upgrades!
                                        πŸ‘
                                        • fredo6F Offline
                                          NEW RELEASE
                                          version 1.8a - 01 May 11: Better respect the offset distance in case where the surface is composed of faces with sharp angles. In V1.8, this works also when there is an imposed plane set by Ctrl-Arrow.
                                            NEW RELEASE
                                            πŸ‘ πŸ‘ πŸ˜„
                                            • 11
                                            • 12
                                            • 18
                                            • 19
                                            • 10 / 19
