    Top 3 SU plugins
    80 Posts 40 Posters 23.0k Views 40 Watching
    • TIGT Online
      @thomthom said:
      @burkhard said:
      Delete Cons ( Seems I worked to much with Lines and points )
      It deletes construction lines and points? That's a native function...
      But the built-in one is brutal and removes all - some such as this erase all cpoints/clines in the current context only ?
      • TIGT Online
        My three most commonly used tools:
        Weld
        Make Face
        Mirror
        • mitcorbM Offline
          mitcorb
          Fredo PushPull--Joint,Vector,Normal
          Mirror Selection
          FredoScale,Taper,Bend
          • KrisidiousK Offline
            Krisidious
            Weld
            Curviloft
            Thom's Curve Select
            By: Kristoff Rand
              tfdesign
              This is a good thread, as I was also about to ask the same question- but for ten plugins(!).
              Three is a good number, but what still confuses me, and probably others too, who are new to SketchUp is why.
              Why do you use these plugins, and what advantages to they give you over the current set of tools, and what is your main objective, taking into account, your chosen subject? For eg, are you an architect? A product designer or just a general modeller? Why are these three so important?
              I've started to experiment with Fredo6's Bezierspline plugin, mainly because it is impossible to draw bezier curves by any other way in SketchUp, and bezier curves come in hand for many things, both architectural and product-wise.
              I'll probably also add Fredo6's Curviloft plugin too, because the creation of organic surfaces that morph from one shape to another can also have its use, especially when modelling Victorian rendering- such as plaster.
              One more only would be very hard to suggest, as many are so brilliant and useful!
              Tom
                Weld
                CutList
                BZ Spline
                  tfdesign
                  Why?
                    Weld: To weld line segments so they behave as single entities for selection purposes and to reduce the need to soften/smooth edges.
                    CutList: Nearly every project I draw these days is a plan for a piece of furniture or cabinets and my clients require cut lists so they can quote for materials. I could do it manually but Cut List takes only a couple of seconds.
                    BZ Spline: For drawing non-circular curves.
                      tfdesign
                      Cheers Dave 😄
                      • PixeroP Offline
                        Pixero
                        I dont know if my most used plugins are my favorites but anyway:
                        Put on layer (I use it ALL the time to keep my file organised.)
                        Weld (I've edited it so I have it under the right click menu)
                        Joint pushpull (Could also be Extrude edge by vector)
                        • gullfoG Offline
                          gullfo
                          my top 3:
                          House Builder (imperial and metric)
                          Extrusion Tools
                          Weld
                          Glenn
                          http://www.runnel.com
                            JuanV.Soler
                            2D Tools
                            Work Plane
                            Colour Edge
                            field of use : architecture
                              tfdesign
                              Wow Pilou! That's beautiful!
                              • EscapeArtistE Offline
                                EscapeArtist
                                Based on use:
                                Weld
                                Remove unused edges
                                BZ spline (all)
                                Based on coolest/usefulness (IMO)
                                SD&S
                                Curviloft
                                JPP
                                All of the above make SU easier and better to use.
                                  blajnov
                                  kate-art, it's not all... 😲 😒 ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
                                  • mitcorbM Offline
                                    mitcorb
                                    I already gave you three--for this week. I also like to see how well I can do some operations from scratch. However, I don't think Weld has a native substitute.
                                      The 3 more fun 😎 (for me 😒
                                      Grow by Tig perfect for iteration volumes with multiple size, Move, rotate
                                      Protrude by Jim Foltz funny automatic exotic generations
                                      Random Painter by Chris Fullmer for some joyous variations of colors
                                      3 in the same time 😄
                                        kate-art
                                        Great feedback guys - thanks. I find it interesting how everyone likes something different. This short thread has generated a list of 30+ plugins!
                                        Shaderlight delivers interactive, photorealistic rendering to Google SketchUp. Download it for FREE at http://www.shaderlight.com
                                          tfdesign
                                          Brilliant! Then I too will also go with these as well 😄
                                            DIEGO-RODRIGUEZ
                                            extrusion line
                                            mirror
                                            joint push pull
                                            • 2 / 4
