    Top 3 SU plugins
    80 Posts 40 Posters 23.0k Views 40 Watching
    • BurkhardB Offline
      Burkhard
      Round Corners
      CleanUp
      Delete Cons ( Seems I worked to much with Lines and points )
      http://www.ia-plus.de
        rv1974
        1.extrude line
        2.extrude along path
        3.mirror
          It deletes construction lines and points? That's a native function...
          • Chris FullmerC Offline
            @ely862me said:
            SDS
            JPP
            TOS
            To translate that - SubDivide and Smooth, Joint PushPull, and Tools On Surface.
            Mine are:
            Weld
            Make Faces
            Repeat Copy
              But the built-in one is brutal and removes all - some such as this erase all cpoints/clines in the current context only ?
                My three most commonly used tools:
                Weld
                Make Face
                Mirror
                • mitcorbM Offline
                  mitcorb
                  Fredo PushPull--Joint,Vector,Normal
                  Mirror Selection
                  FredoScale,Taper,Bend
                  • KrisidiousK Offline
                    Krisidious
                    Weld
                    Curviloft
                    Thom's Curve Select
                    By: Kristoff Rand
                      tfdesign
                      This is a good thread, as I was also about to ask the same question- but for ten plugins(!).
                      Three is a good number, but what still confuses me, and probably others too, who are new to SketchUp is why.
                      Why do you use these plugins, and what advantages to they give you over the current set of tools, and what is your main objective, taking into account, your chosen subject? For eg, are you an architect? A product designer or just a general modeller? Why are these three so important?
                      I've started to experiment with Fredo6's Bezierspline plugin, mainly because it is impossible to draw bezier curves by any other way in SketchUp, and bezier curves come in hand for many things, both architectural and product-wise.
                      I'll probably also add Fredo6's Curviloft plugin too, because the creation of organic surfaces that morph from one shape to another can also have its use, especially when modelling Victorian rendering- such as plaster.
                      One more only would be very hard to suggest, as many are so brilliant and useful!
                      Tom
                        Weld
                        CutList
                        BZ Spline
                          tfdesign
                          Why?
                            Weld: To weld line segments so they behave as single entities for selection purposes and to reduce the need to soften/smooth edges.
                            CutList: Nearly every project I draw these days is a plan for a piece of furniture or cabinets and my clients require cut lists so they can quote for materials. I could do it manually but Cut List takes only a couple of seconds.
                            BZ Spline: For drawing non-circular curves.
                              tfdesign
                              Cheers Dave 😄
                              • PixeroP Offline
                                Pixero
                                I dont know if my most used plugins are my favorites but anyway:
                                Put on layer (I use it ALL the time to keep my file organised.)
                                Weld (I've edited it so I have it under the right click menu)
                                Joint pushpull (Could also be Extrude edge by vector)
                                • gullfoG Offline
                                  gullfo
                                  my top 3:
                                  House Builder (imperial and metric)
                                  Extrusion Tools
                                  Weld
                                  Glenn
                                  http://www.runnel.com
                                    JuanV.Soler
                                    2D Tools
                                    Work Plane
                                    Colour Edge
                                    field of use : architecture
                                      tfdesign
                                      Wow Pilou! That's beautiful!
                                      • EscapeArtistE Offline
                                        EscapeArtist
                                        Based on use:
                                        Weld
                                        Remove unused edges
                                        BZ spline (all)
                                        Based on coolest/usefulness (IMO)
                                        SD&S
                                        Curviloft
                                        JPP
                                        All of the above make SU easier and better to use.
                                          blajnov
                                          kate-art, it's not all... 😲 😒 ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
                                          • mitcorbM Offline
                                            mitcorb
                                            I already gave you three--for this week. I also like to see how well I can do some operations from scratch. However, I don't think Weld has a native substitute.
                                            • 1 / 4
