    Top 3 SU plugins
    80 Posts 40 Posters 23.0k Views 40 Watching
    • charly2008C Offline
      charly2008
      • Curviloft
      • Extrusion Tools
      • Kerkythea Exporter
        Daniel S
        • Round Corners
        • Curviloft
        • SketchyPhysics
        • BurkhardB Offline
          Burkhard
          Round Corners
          CleanUp
          Delete Cons ( Seems I worked to much with Lines and points )
          http://www.ia-plus.de
            rv1974
            1.extrude line
            2.extrude along path
            3.mirror
              It deletes construction lines and points? That's a native function...
              • Chris FullmerC Offline
                @ely862me said:
                SDS
                JPP
                TOS
                To translate that - SubDivide and Smooth, Joint PushPull, and Tools On Surface.
                Mine are:
                Weld
                Make Faces
                Repeat Copy
                  But the built-in one is brutal and removes all - some such as this erase all cpoints/clines in the current context only ?
                    My three most commonly used tools:
                    Weld
                    Make Face
                    Mirror
                    • mitcorbM Offline
                      mitcorb
                      Fredo PushPull--Joint,Vector,Normal
                      Mirror Selection
                      FredoScale,Taper,Bend
                      • KrisidiousK Offline
                        Krisidious
                        Weld
                        Curviloft
                        Thom's Curve Select
                        By: Kristoff Rand
                          tfdesign
                          This is a good thread, as I was also about to ask the same question- but for ten plugins(!).
                          Three is a good number, but what still confuses me, and probably others too, who are new to SketchUp is why.
                          Why do you use these plugins, and what advantages to they give you over the current set of tools, and what is your main objective, taking into account, your chosen subject? For eg, are you an architect? A product designer or just a general modeller? Why are these three so important?
                          I've started to experiment with Fredo6's Bezierspline plugin, mainly because it is impossible to draw bezier curves by any other way in SketchUp, and bezier curves come in hand for many things, both architectural and product-wise.
                          I'll probably also add Fredo6's Curviloft plugin too, because the creation of organic surfaces that morph from one shape to another can also have its use, especially when modelling Victorian rendering- such as plaster.
                          One more only would be very hard to suggest, as many are so brilliant and useful!
                          Tom
                            Weld
                            CutList
                            BZ Spline
                              tfdesign
                              Why?
                                Weld: To weld line segments so they behave as single entities for selection purposes and to reduce the need to soften/smooth edges.
                                CutList: Nearly every project I draw these days is a plan for a piece of furniture or cabinets and my clients require cut lists so they can quote for materials. I could do it manually but Cut List takes only a couple of seconds.
                                BZ Spline: For drawing non-circular curves.
                                  tfdesign
                                  Cheers Dave 😄
                                  • PixeroP Offline
                                    Pixero
                                    I dont know if my most used plugins are my favorites but anyway:
                                    Put on layer (I use it ALL the time to keep my file organised.)
                                    Weld (I've edited it so I have it under the right click menu)
                                    Joint pushpull (Could also be Extrude edge by vector)
                                    • gullfoG Offline
                                      gullfo
                                      my top 3:
                                      House Builder (imperial and metric)
                                      Extrusion Tools
                                      Weld
                                      Glenn
                                      http://www.runnel.com
                                        JuanV.Soler
                                        2D Tools
                                        Work Plane
                                        Colour Edge
                                        field of use : architecture
                                          tfdesign
                                          Wow Pilou! That's beautiful!
                                          • EscapeArtistE Offline
                                            EscapeArtist
                                            Based on use:
                                            Weld
                                            Remove unused edges
                                            BZ spline (all)
                                            Based on coolest/usefulness (IMO)
                                            SD&S
                                            Curviloft
                                            JPP
                                            All of the above make SU easier and better to use.
                                            • 1 / 4
