    Top 3 SU plugins
    80 Posts 40 Posters 20.6k Views 40 Watching
      Weld: To weld line segments so they behave as single entities for selection purposes and to reduce the need to soften/smooth edges.
      CutList: Nearly every project I draw these days is a plan for a piece of furniture or cabinets and my clients require cut lists so they can quote for materials. I could do it manually but Cut List takes only a couple of seconds.
      BZ Spline: For drawing non-circular curves.
        tfdesign
        Cheers Dave 😄
        • PixeroP Offline
          Pixero
          I dont know if my most used plugins are my favorites but anyway:
          Put on layer (I use it ALL the time to keep my file organised.)
          Weld (I've edited it so I have it under the right click menu)
          Joint pushpull (Could also be Extrude edge by vector)
          • gullfoG Offline
            gullfo
            my top 3:
            House Builder (imperial and metric)
            Extrusion Tools
            Weld
            Glenn
            http://www.runnel.com
              JuanV.Soler
              2D Tools
              Work Plane
              Colour Edge
              field of use : architecture
                tfdesign
                Wow Pilou! That's beautiful!
                • EscapeArtistE Offline
                  EscapeArtist
                  Based on use:
                  Weld
                  Remove unused edges
                  BZ spline (all)
                  Based on coolest/usefulness (IMO)
                  SD&S
                  Curviloft
                  JPP
                  All of the above make SU easier and better to use.
                    blajnov
                    kate-art, it's not all... 😲 😒 ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
                    • mitcorbM Offline
                      mitcorb
                      I already gave you three--for this week. I also like to see how well I can do some operations from scratch. However, I don't think Weld has a native substitute.
                        The 3 more fun 😎 (for me 😒
                        Grow by Tig perfect for iteration volumes with multiple size, Move, rotate
                        Protrude by Jim Foltz funny automatic exotic generations
                        Random Painter by Chris Fullmer for some joyous variations of colors
                        3 in the same time 😄
                          kate-art
                          Great feedback guys - thanks. I find it interesting how everyone likes something different. This short thread has generated a list of 30+ plugins!
                          Shaderlight delivers interactive, photorealistic rendering to Google SketchUp. Download it for FREE at http://www.shaderlight.com
                            tfdesign
                            Brilliant! Then I too will also go with these as well 😄
                              DIEGO-RODRIGUEZ
                              extrusion line
                              mirror
                              joint push pull
                              • EdsonE Offline
                                Edson
                                mirror
                                podium
                                1001bit tools
                                http://www.mahfuz.arq.br
                                • H Offline
                                  haynesc
                                  I couldnt decide 3 so anyof the below :
                                  PurgeAll
                                  Make Faces
                                  Frontface
                                  Weld
                                  Default Layer Gemometry
                                  SceneExporter Pro
                                  Extrude Tools
                                  Curviloft
                                  Curvishear
                                  CD STANDARD & CD TOOLSET Toolbars
                                  Zorro
                                  Move to Orgin
                                  Remove Materials
                                  joint push pull
                                  1001 tools
                                  • daleD Offline
                                    dale
                                    TOS
                                    1001 bit Tools
                                    Joint Pushpull.....For work
                                    The one I use when I am playing SDS, Fur
                                    • Chris FullmerC Offline
                                      I totally agree on this one. It is invaluable to me. Move all geometry to layer 0 while keeping all groups, images, components on the layer they were on. Absolute must for clean modeling habits.
                                      • arquitectomaracuchoA Offline
                                        arquitectomaracucho
                                        Curviloft 😍
                                        1001 bit Tools
                                        joint push pull
                                        tools on surface
                                        • EdsonE Offline
                                          Edson
                                          I gather you mean to say "move all loose geometry, that is, not grouped or turned into a component".
                                            tfdesign
                                            Chris, why is that so important/ invaluable?
                                            • 2 / 4
