    Top 3 SU plugins
    80 Posts 40 Posters 21.1k Views 40 Watching
      Daniel S
      • Round Corners
      • Curviloft
      • SketchyPhysics
      • BurkhardB Offline
        Burkhard
        Round Corners
        CleanUp
        Delete Cons ( Seems I worked to much with Lines and points )
        [http://www.ia-plus.de(http://www.ia-plus.de)]
          rv1974
          1.extrude line
          2.extrude along path
          3.mirror
            It deletes construction lines and points? That's a native function...
            • Chris FullmerC Offline
              @ely862me said:
              SDS
              JPP
              TOS
              To translate that - SubDivide and Smooth, Joint PushPull, and Tools On Surface.
              Mine are:
              Weld
              Make Faces
              Repeat Copy
                But the built-in one is brutal and removes all - some such as this erase all cpoints/clines in the current context only ?
                  My three most commonly used tools:
                  Weld
                  Make Face
                  Mirror
                  • mitcorbM Offline
                    mitcorb
                    Fredo PushPull--Joint,Vector,Normal
                    Mirror Selection
                    FredoScale,Taper,Bend
                    • KrisidiousK Offline
                      Krisidious
                      Weld
                      Curviloft
                      Thom's Curve Select
                      By: Kristoff Rand
                        tfdesign
                        This is a good thread, as I was also about to ask the same question- but for ten plugins(!).
                        Three is a good number, but what still confuses me, and probably others too, who are new to SketchUp is why.
                        Why do you use these plugins, and what advantages to they give you over the current set of tools, and what is your main objective, taking into account, your chosen subject? For eg, are you an architect? A product designer or just a general modeller? Why are these three so important?
                        I've started to experiment with Fredo6's Bezierspline plugin, mainly because it is impossible to draw bezier curves by any other way in SketchUp, and bezier curves come in hand for many things, both architectural and product-wise.
                        I'll probably also add Fredo6's Curviloft plugin too, because the creation of organic surfaces that morph from one shape to another can also have its use, especially when modelling Victorian rendering- such as plaster.
                        One more only would be very hard to suggest, as many are so brilliant and useful!
                        Tom
                          Weld
                          CutList
                          BZ Spline
                            tfdesign
                            Why?
                              Weld: To weld line segments so they behave as single entities for selection purposes and to reduce the need to soften/smooth edges.
                              CutList: Nearly every project I draw these days is a plan for a piece of furniture or cabinets and my clients require cut lists so they can quote for materials. I could do it manually but Cut List takes only a couple of seconds.
                              BZ Spline: For drawing non-circular curves.
                                tfdesign
                                Cheers Dave 😄
                                • PixeroP Offline
                                  Pixero
                                  I dont know if my most used plugins are my favorites but anyway:
                                  Put on layer (I use it ALL the time to keep my file organised.)
                                  Weld (I've edited it so I have it under the right click menu)
                                  Joint pushpull (Could also be Extrude edge by vector)
                                  • gullfoG Offline
                                    gullfo
                                    my top 3:
                                    House Builder (imperial and metric)
                                    Extrusion Tools
                                    Weld
                                    Glenn
                                    http://www.runnel.com
                                      JuanV.Soler
                                      2D Tools
                                      Work Plane
                                      Colour Edge
                                      field of use : architecture
                                        tfdesign
                                        Wow Pilou! That's beautiful!
                                        • EscapeArtistE Offline
                                          EscapeArtist
                                          Based on use:
                                          Weld
                                          Remove unused edges
                                          BZ spline (all)
                                          Based on coolest/usefulness (IMO)
                                          SD&S
                                          Curviloft
                                          JPP
                                          All of the above make SU easier and better to use.
                                            blajnov
                                            kate-art, it's not all... 😲 😒 ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28782
                                            • 1 / 4
