    Top 3 SU plugins
    80 Posts 40 Posters 23.0k Views 40 Watching
    • ely862meE Offline
      ely862me
      SDS
      JPP
      TOS
      Elisei (sketchupper)
      Come and See EliseiDesign
      • charly2008C Offline
        charly2008
        • Curviloft
        • Extrusion Tools
        • Kerkythea Exporter
          Daniel S
          • Round Corners
          • Curviloft
          • SketchyPhysics
          • BurkhardB Offline
            Burkhard
            Round Corners
            CleanUp
            Delete Cons ( Seems I worked to much with Lines and points )
            http://www.ia-plus.de
              rv1974
              1.extrude line
              2.extrude along path
              3.mirror
                It deletes construction lines and points? That's a native function...
                • Chris FullmerC Offline
                  @ely862me said:
                  SDS
                  JPP
                  TOS
                  To translate that - SubDivide and Smooth, Joint PushPull, and Tools On Surface.
                  Mine are:
                  Weld
                  Make Faces
                  Repeat Copy
                    But the built-in one is brutal and removes all - some such as this erase all cpoints/clines in the current context only ?
                      My three most commonly used tools:
                      Weld
                      Make Face
                      Mirror
                      • mitcorbM Offline
                        mitcorb
                        Fredo PushPull--Joint,Vector,Normal
                        Mirror Selection
                        FredoScale,Taper,Bend
                        • KrisidiousK Offline
                          Krisidious
                          Weld
                          Curviloft
                          Thom's Curve Select
                          By: Kristoff Rand
                            tfdesign
                            This is a good thread, as I was also about to ask the same question- but for ten plugins(!).
                            Three is a good number, but what still confuses me, and probably others too, who are new to SketchUp is why.
                            Why do you use these plugins, and what advantages to they give you over the current set of tools, and what is your main objective, taking into account, your chosen subject? For eg, are you an architect? A product designer or just a general modeller? Why are these three so important?
                            I've started to experiment with Fredo6's Bezierspline plugin, mainly because it is impossible to draw bezier curves by any other way in SketchUp, and bezier curves come in hand for many things, both architectural and product-wise.
                            I'll probably also add Fredo6's Curviloft plugin too, because the creation of organic surfaces that morph from one shape to another can also have its use, especially when modelling Victorian rendering- such as plaster.
                            One more only would be very hard to suggest, as many are so brilliant and useful!
                            Tom
                              Weld
                              CutList
                              BZ Spline
                                tfdesign
                                Why?
                                  Weld: To weld line segments so they behave as single entities for selection purposes and to reduce the need to soften/smooth edges.
                                  CutList: Nearly every project I draw these days is a plan for a piece of furniture or cabinets and my clients require cut lists so they can quote for materials. I could do it manually but Cut List takes only a couple of seconds.
                                  BZ Spline: For drawing non-circular curves.
                                    tfdesign
                                    Cheers Dave 😄
                                    • PixeroP Offline
                                      Pixero
                                      I dont know if my most used plugins are my favorites but anyway:
                                      Put on layer (I use it ALL the time to keep my file organised.)
                                      Weld (I've edited it so I have it under the right click menu)
                                      Joint pushpull (Could also be Extrude edge by vector)
                                      • gullfoG Offline
                                        gullfo
                                        my top 3:
                                        House Builder (imperial and metric)
                                        Extrusion Tools
                                        Weld
                                        Glenn
                                        http://www.runnel.com
                                          JuanV.Soler
                                          2D Tools
                                          Work Plane
                                          Colour Edge
                                          field of use : architecture
                                            tfdesign
                                            Wow Pilou! That's beautiful!
                                            • 1 / 4
