    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • E Offline
      Efrado
      Please some advice,I was triying to reproduce the MOEBIUS thah Fredo did before ,but every time i got bugplash.
      what am i doing wrong?
      • Y Offline
        yokaxi
        thanks
        • charly2008C Offline
          charly2008
          Hello community,
          please show your ideas, everything what you can do with Curviloft.
          Charly
            SUFractal
            WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
              Window > Preferences > Extensions... activate it! 😉
                robert111
                charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
                thanks charly
                  charly2008
                  Hi Robert,
                  the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
                  Charly
                  Curviloft99.skp
                    robert111
                    thanks charly , and for the seconde image ( black one) ??????
                      charly2008
                      the black background is from Glöbals --> HDR-probe within Kerkythea.
                        charly2008
                        new model with different materials.
                        • majidM Offline
                          majid
                          first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
                            I believe that plug section is not yet finalized!
                            try 2 faces and path by Kirill 2008
                            • fredo6F Offline
                              Coudl you post the model, because there should be no problem with that case.
                              • mariochaM Offline
                                mariocha
                                I had a similar problem.
                                Solved by getting one face slightly out of the plane of the other.
                                If this can help. 😄
                                %(#008000)[Mario C.
                                • majidM Offline
                                  majid
                                  If this can help. 😄
                                  yes mate it workes for me too, nice trick 😉
                                  and , dear Fredo....thousands of thanx for your generoucity and helps on this forum..... we all thank you, and here is the simple model.
                                  co-planar faces question
                                    I have same result 😮
                                    and this
                                    don't works for me 😞
                                    bug_or_not.skp
                                      Introduce a 'vertical face' half way round the loop and do it in two steps ?
                                      • mariochaM Offline
                                        mariocha
                                        ...don't works for me ...
                                        Hum... just to be sure, one of the faces is not flat on the ground, right ?
                                        %(#008000)[Mario C.
                                          DIEGO-RODRIGUEZ
                                            Ah oK 😄
                                            But that is not normal 😉
                                            • 11
                                            • 65
                                            • 66
                                            • 9 / 66
