    1.3k Posts 300 Posters 3.2m Views 298 Watching
    • Y
      yokaxi
      thanks
      • charly2008C
        charly2008
        Hello community,
        please show your ideas, everything what you can do with Curviloft.
        Charly
          SUFractal
          WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
            Window > Preferences > Extensions... activate it! 😉
              robert111
              charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
              thanks charly
              • charly2008C
                charly2008
                Hi Robert,
                the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
                Charly
                Curviloft99.skp
                  robert111
                  thanks charly , and for the seconde image ( black one) ??????
                  • charly2008C
                    charly2008
                    the black background is from Glöbals --> HDR-probe within Kerkythea.
                    • charly2008C
                      charly2008
                      new model with different materials.
                      • majidM
                        majid
                        first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
                          I believe that plug section is not yet finalized!
                          try 2 faces and path by Kirill 2008
                          • fredo6F
                            Coudl you post the model, because there should be no problem with that case.
                            • mariochaM
                              mariocha
                              I had a similar problem.
                              Solved by getting one face slightly out of the plane of the other.
                              If this can help. 😄
                              %(#008000)[Mario C.
                              • majidM
                                majid
                                If this can help. 😄
                                yes mate it workes for me too, nice trick 😉
                                and , dear Fredo....thousands of thanx for your generoucity and helps on this forum..... we all thank you, and here is the simple model.
                                co-planar faces question
                                  I have same result 😮
                                  and this
                                  don't works for me 😞
                                  bug_or_not.skp
                                    Introduce a 'vertical face' half way round the loop and do it in two steps ?
                                    • mariochaM
                                      mariocha
                                      ...don't works for me ...
                                      Hum... just to be sure, one of the faces is not flat on the ground, right ?
                                      %(#008000)[Mario C.
                                        DIEGO-RODRIGUEZ
                                          Ah oK 😄
                                          But that is not normal 😉
                                          • fredo6F
                                            Ah oK 😄
                                            I cannot really say that this is normal 😆
                                            This is simply a small problem when the two faces are in parallel planes. It is part of the fixes I will release. The issue is just that the contours are connected in reverse directions.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 65
                                            • 66
                                            • 19 / 66
