    1.3k Posts 299 Posters 2.7m Views 297 Watching
      @sufractal said:
      WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
      Window > Preferences > Extensions... activate it! 😉
        robert111
        charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
        thanks charly
        • charly2008C Offline
          charly2008
          Hi Robert,
          the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
          Charly
          Curviloft99.skp
            robert111
            thanks charly , and for the seconde image ( black one) ??????
              charly2008
              the black background is from Glöbals --> HDR-probe within Kerkythea.
                charly2008
                new model with different materials.
                • majidM Offline
                  majid
                  first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
                    I believe that plug section is not yet finalized!
                    try 2 faces and path by Kirill 2008
                    • fredo6F Offline
                      Coudl you post the model, because there should be no problem with that case.
                      • mariochaM Offline
                        mariocha
                        I had a similar problem.
                        Solved by getting one face slightly out of the plane of the other.
                        If this can help. 😄
                        %(#008000)[Mario C.
                        • majidM Offline
                          majid
                          If this can help. 😄
                          yes mate it workes for me too, nice trick 😉
                          and , dear Fredo....thousands of thanx for your generoucity and helps on this forum..... we all thank you, and here is the simple model.
                          co-planar faces question
                            I have same result 😮
                            and this
                            don't works for me 😞
                            bug_or_not.skp
                              Introduce a 'vertical face' half way round the loop and do it in two steps ?
                              • mariochaM Offline
                                mariocha
                                ...don't works for me ...
                                Hum... just to be sure, one of the faces is not flat on the ground, right ?
                                %(#008000)[Mario C.
                                  DIEGO-RODRIGUEZ
                                    Ah oK 😄
                                    But that is not normal 😉
                                    • fredo6F Offline
                                      Ah oK 😄
                                      I cannot really say that this is normal 😆
                                      This is simply a small problem when the two faces are in parallel planes. It is part of the fixes I will release. The issue is just that the contours are connected in reverse directions.
                                        DIEGO-RODRIGUEZ
                                        Hi Fred.
                                        a question.
                                        is normal that generates the mesh outside the component or group that I'm working?
                                        • fredo6F Offline
                                          @diego-rodriguez said:
                                          Hi Fred.
                                          a question.
                                          It's part of the bug fixed but not yet released.
                                          This was already signaled. see that post
                                            charly2008
                                            again a new Object
                                            Charly
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 65
                                            • 66
                                            • 19 / 66
