    1.3k Posts 300 Posters 3.2m Views 298 Watching
      @blair said:
      Is there a way to make a contribution to Fredo through PayPal or something?
      Of course!
      ..\Plugins\CURVILOFT_Dir_10\Curviloft_donation.html >>> PayPal.com >> fredosix @ hotmail.com
      • E
        Efrado
        Please some advice,I was triying to reproduce the MOEBIUS thah Fredo did before ,but every time i got bugplash.
        what am i doing wrong?
        • Y
          yokaxi
          thanks
          • charly2008C
            charly2008
            Hello community,
            please show your ideas, everything what you can do with Curviloft.
            Charly
              SUFractal
              WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
                Window > Preferences > Extensions... activate it! 😉
                  robert111
                  charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
                  thanks charly
                  • charly2008C
                    charly2008
                    Hi Robert,
                    the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
                    Charly
                    Curviloft99.skp
                      robert111
                      thanks charly , and for the seconde image ( black one) ??????
                      • charly2008C
                        charly2008
                        the black background is from Glöbals --> HDR-probe within Kerkythea.
                        • charly2008C
                          charly2008
                          new model with different materials.
                          • majidM
                            majid
                            first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
                              I believe that plug section is not yet finalized!
                              try 2 faces and path by Kirill 2008
                              • fredo6F
                                Coudl you post the model, because there should be no problem with that case.
                                • mariochaM
                                  mariocha
                                  I had a similar problem.
                                  Solved by getting one face slightly out of the plane of the other.
                                  If this can help. 😄
                                  %(#008000)[Mario C.
                                  • majidM
                                    majid
                                    If this can help. 😄
                                    yes mate it workes for me too, nice trick 😉
                                    and , dear Fredo....thousands of thanx for your generoucity and helps on this forum..... we all thank you, and here is the simple model.
                                    co-planar faces question
                                      I have same result 😮
                                      and this
                                      don't works for me 😞
                                      bug_or_not.skp
                                        Introduce a 'vertical face' half way round the loop and do it in two steps ?
                                        • mariochaM
                                          mariocha
                                          ...don't works for me ...
                                          Hum... just to be sure, one of the faces is not flat on the ground, right ?
                                          %(#008000)[Mario C.
                                            DIEGO-RODRIGUEZ
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 65
                                            • 66
                                            • 19 / 66
