    1.3k Posts 300 Posters 3.2m Views 298 Watching
      robert111
      thanks charly , and for the seconde image ( black one) ??????
      • charly2008C
        charly2008
        the black background is from Glöbals --> HDR-probe within Kerkythea.
        • charly2008C
          charly2008
          new model with different materials.
          • majidM
            majid
            first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
              I believe that plug section is not yet finalized!
              try 2 faces and path by Kirill 2008
              • fredo6F
                Coudl you post the model, because there should be no problem with that case.
                • mariochaM
                  mariocha
                  I had a similar problem.
                  Solved by getting one face slightly out of the plane of the other.
                  If this can help. 😄
                  %(#008000)[Mario C.
                  • majidM
                    majid
                    If this can help. 😄
                    yes mate it workes for me too, nice trick 😉
                    and , dear Fredo....thousands of thanx for your generoucity and helps on this forum..... we all thank you, and here is the simple model.
                    co-planar faces question
                      I have same result 😮
                      and this
                      don't works for me 😞
                      bug_or_not.skp
                        Introduce a 'vertical face' half way round the loop and do it in two steps ?
                        • mariochaM
                          mariocha
                          ...don't works for me ...
                          Hum... just to be sure, one of the faces is not flat on the ground, right ?
                          %(#008000)[Mario C.
                            DIEGO-RODRIGUEZ
                              Ah oK 😄
                              But that is not normal 😉
                              • fredo6F
                                Ah oK 😄
                                I cannot really say that this is normal 😆
                                This is simply a small problem when the two faces are in parallel planes. It is part of the fixes I will release. The issue is just that the contours are connected in reverse directions.
                                  DIEGO-RODRIGUEZ
                                  Hi Fred.
                                  a question.
                                  is normal that generates the mesh outside the component or group that I'm working?
                                  • fredo6F
                                    @diego-rodriguez said:
                                    Hi Fred.
                                    a question.
                                    It's part of the bug fixed but not yet released.
                                    This was already signaled. see that post
                                    • charly2008C
                                      charly2008
                                      again a new Object
                                      Charly
                                      • mitcorbM
                                        mitcorb
                                        @Charly: Someone has probably already said this, but your Curviloft models remind me of high style jewelry in the tradition of Faberge, perhaps, or someone like him. I would have to guess you might actually work with jewelry or decorative art in some way. Again, I salute your creativity.
                                        The other possibility is that you are a very discerning and talented machinist.
                                        However, there are dentists who like to work with jewelry.
                                        Now don't let this all go to your head. We won't be able to do a thing with you 💚
                                        • charly2008C
                                          charly2008
                                          Hi mitcorb,
                                          at first many thanks for your nice comments. I'm just a retired mechanical engineer. I have nothing to do with jewelry. My thanks to Fredo and TIG for their wonderful plugins that allow me always to try new ideas. Curviloft inspired me again and again to construct new forms. It is not a great art, but only practice and a little visionary. In principle, everyone who deals with it can do it.
                                          Charly
                                            jbw007
                                            Hi Fredo,
                                            I've download your fantastic plugin, but I'm not able to use it. I get the toolbar and menu items, and I've created the curves that I want to work on. Nothing happens at all. I've check the video 10 times and can't see what's wrong. It's the only Plugin that I have installed, after a reinstall of SU. Nothing in the Ruby console, in fact the same problem that 'Rachmatrf' have in June. I've looked through the forum for the answer to him, but failed to find the solution. Can you help ?
                                            Regards
                                            Jens
                                            Running XP SP3, and SU8
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 65
                                            • 66
                                            • 19 / 66
