    1.3k Posts 300 Posters 3.3m Views 298 Watching
      SpookyChick1013
      it's not that they need to be vertical per se but the profile splines should be parallel to get your desired results.. it's just something i noticed with curviloft and the orthogonal settings.. (fwiw, in rhino, the profiles can be tilted like you have them and the lofted surface remains straight on the bottom/top_
      Ooooohhh-k...Now I get it. Still having my morning coffee, so it took a moment to get it. Thanks, now I understand what you meant.
      i redrew all the profiles using fredo's BezierSpline plugin.. it makes a smoother curve and evens out the segmentation..
      Downloading that plugin today! Looks like more options and less of a PITA than the native bezier stuff.
      here's a video showing the whole process.. i did this on a laptop using the trackpad so i apologize about the jumpy navigation etc..
      Excellent! Thank you for the tutorial and the time you spent on this.
      also - i copy/pasted your lines into my own template.. i noticed with yours that they are drawn upside down.. the solid blue axis line should be pointing up instead of down.. if you turn on sky or ground, you'll see what i'm saying + the navigation is weird (for me) in your file
      %(#0000BF)[OOOOOps! um, yeah...There was a reason I set it up like that. I was aware of that, but I just forgot to put it back the normal way way before copying the file. I guess I need to take better process notes as I'm working, and reread them occasionally. My apologies for that, Jeff; and also you Fredo, if you have taken a look at this model.
      Anyway, once again, thanks very much for your time and effort explaining things and helping me on this Jeff. It is greatly appreciated. 😄]
      https://kuromatsudriveyards.com
      Fo-su to tomo ni aran koto o...
      • O
        olbapxpablo
        @thomthom said:
        @olbapxpablo said:
        curviloft is not working for me.
        other plug-ins works fine except this one
        is there anyone can help?
        Can you be more specific please?
        No menus/toolbars?
        Error messages?
        Unexpected results?
        thanks sir
        theres menu and i can do the steps but theres no result or looks like nothing happen still on its original form
        and sometimes after i click on the shape 1,2 & 3 then click outside or anywhere to finalize the steps my SU8 turn to notresponding state
          @charly2008 said:
          Hi Thomas,
          i welded each line and below the result in Sketchup 8.
          Charly
          I just tried to weld - and I could not get it working.
          • charly2008C
            charly2008
            Hi Thomas,
            I tried it again (Without welding). Select the lines, each with double click and activate Curviloft. If the lines have changed the color, select the lines again and re-enable Curviloft. Then it works. I don't know why. Maybe Fredo can answer the question.
            Charly
              aaaaah!
              I so very nearly had it there. selecting the curves and extra time so it said 3 and 4 made it computer - but as it generated I got a BugSplat.
              Would you mind upload the mesh you got from that loft? I really need that patch.
              • charly2008C
                charly2008
                Here is the mesh
                CurviError1skp.skp
                  cheers!
                  • B
                    blair
                    Is there a way to make a contribution to Fredo through PayPAL or something?
                      @blair said:
                      Is there a way to make a contribution to Fredo through PayPal or something?
                      Of course!
                      ..\Plugins\CURVILOFT_Dir_10\Curviloft_donation.html >>> PayPal.com >> fredosix @ hotmail.com
                      • E
                        Efrado
                        Please some advice,I was triying to reproduce the MOEBIUS thah Fredo did before ,but every time i got bugplash.
                        what am i doing wrong?
                        • Y
                          yokaxi
                          thanks
                          • charly2008C
                            charly2008
                            Hello community,
                            please show your ideas, everything what you can do with Curviloft.
                            Charly
                              SUFractal
                              WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
                                Window > Preferences > Extensions... activate it! 😉
                                  robert111
                                  charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
                                  thanks charly
                                  • charly2008C
                                    charly2008
                                    Hi Robert,
                                    the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
                                    Charly
                                    Curviloft99.skp
                                      robert111
                                      thanks charly , and for the seconde image ( black one) ??????
                                      • charly2008C
                                        charly2008
                                        the black background is from Glöbals --> HDR-probe within Kerkythea.
                                        • charly2008C
                                          charly2008
                                          new model with different materials.
                                          • majidM
                                            majid
                                            first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 65
                                            • 66
                                            • 18 / 66
