    1.3k Posts 300 Posters 3.1m Views 298 Watching
      cheers!
      • B
        blair
        Is there a way to make a contribution to Fredo through PayPAL or something?
          @blair said:
          Is there a way to make a contribution to Fredo through PayPal or something?
          Of course!
          ..\Plugins\CURVILOFT_Dir_10\Curviloft_donation.html >>> PayPal.com >> fredosix @ hotmail.com
          • E
            Efrado
            Please some advice,I was triying to reproduce the MOEBIUS thah Fredo did before ,but every time i got bugplash.
            what am i doing wrong?
            • Y
              yokaxi
              thanks
              • charly2008C
                charly2008
                Hello community,
                please show your ideas, everything what you can do with Curviloft.
                Charly
                  SUFractal
                  WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
                    Window > Preferences > Extensions... activate it! 😉
                      robert111
                      charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
                      thanks charly
                      • charly2008C
                        charly2008
                        Hi Robert,
                        the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
                        Charly
                        Curviloft99.skp
                          robert111
                          thanks charly , and for the seconde image ( black one) ??????
                          • charly2008C
                            charly2008
                            the black background is from Glöbals --> HDR-probe within Kerkythea.
                            • charly2008C
                              charly2008
                              new model with different materials.
                              • majidM
                                majid
                                first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
                                  I believe that plug section is not yet finalized!
                                  try 2 faces and path by Kirill 2008
                                  • fredo6F
                                    Coudl you post the model, because there should be no problem with that case.
                                    • mariochaM
                                      mariocha
                                      I had a similar problem.
                                      Solved by getting one face slightly out of the plane of the other.
                                      If this can help. 😄
                                      %(#008000)[Mario C.
                                      • majidM
                                        majid
                                        If this can help. 😄
                                        yes mate it workes for me too, nice trick 😉
                                        and , dear Fredo....thousands of thanx for your generoucity and helps on this forum..... we all thank you, and here is the simple model.
                                        co-planar faces question
                                          I have same result 😮
                                          and this
                                          don't works for me 😞
                                          bug_or_not.skp
                                            Introduce a 'vertical face' half way round the loop and do it in two steps ?
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 65
                                            • 66
                                            • 19 / 66
