    1.3k Posts 299 Posters 2.5m Views 297 Watching
      blair
      Is there a way to make a contribution to Fredo through PayPAL or something?
        @blair said:
        Is there a way to make a contribution to Fredo through PayPal or something?
        Of course!
        ..\Plugins\CURVILOFT_Dir_10\Curviloft_donation.html >>> PayPal.com >> fredosix @ hotmail.com
        • E Offline
          Efrado
          Please some advice,I was triying to reproduce the MOEBIUS thah Fredo did before ,but every time i got bugplash.
          what am i doing wrong?
          • Y Offline
            yokaxi
            thanks
            • charly2008C Offline
              charly2008
              Hello community,
              please show your ideas, everything what you can do with Curviloft.
              Charly
                SUFractal
                WOW! This looks looks fantastic. I believe I have this plugin loaded correctly, however, I do not see any toolbars or tool selections in the drop-downs?
                  Window > Preferences > Extensions... activate it! 😉
                    robert111
                    charly2008 , this example is very nice modeling with curviloft , i like your modeli,g, but i need to make tuto for this example if you can plz
                    thanks charly
                      charly2008
                      Hi Robert,
                      the workflow is pretty simple. I started with a simple geometric shape. Then copied everything. I have attached the skp file. Here you can see exactly how it is composed.
                      Charly
                      Curviloft99.skp
                        robert111
                        thanks charly , and for the seconde image ( black one) ??????
                          charly2008
                          the black background is from Glöbals --> HDR-probe within Kerkythea.
                            charly2008
                            new model with different materials.
                            • majidM Offline
                              majid
                              first thanx again for incrediable plugin....really handy.still there is a silly question. I can't figur out how to make this result (as shown in attached picture) ? ( I devided the circle and rectangle to 2 half to reach the desired result)
                                I believe that plug section is not yet finalized!
                                try 2 faces and path by Kirill 2008
                                • fredo6F Offline
                                  Coudl you post the model, because there should be no problem with that case.
                                  • mariochaM Offline
                                    mariocha
                                    I had a similar problem.
                                    Solved by getting one face slightly out of the plane of the other.
                                    If this can help. 😄
                                    %(#008000)[Mario C.
                                    • majidM Offline
                                      majid
                                      If this can help. 😄
                                      yes mate it workes for me too, nice trick 😉
                                      and , dear Fredo....thousands of thanx for your generoucity and helps on this forum..... we all thank you, and here is the simple model.
                                      co-planar faces question
                                        I have same result 😮
                                        and this
                                        don't works for me 😞
                                        bug_or_not.skp
                                          Introduce a 'vertical face' half way round the loop and do it in two steps ?
                                          • mariochaM Offline
                                            mariocha
                                            ...don't works for me ...
                                            Hum... just to be sure, one of the faces is not flat on the ground, right ?
                                            %(#008000)[Mario C.
                                            • 65
                                            • 66
                                            • 4 / 66
