    1.3k Posts 299 Posters 2.5m Views 297 Watching
      @escapeartist said:
      Minor issue I've discovered, and perhaps it's caused by my improper application of the plugin. I get reversed surfaces between rails/curves that make up the object to be lofted. I wouldn't mind so much, except that the surface does not remain divided by the rails, so I have to flip a few hundred faces by hand for each reversed area using "view hidden geometry" to make the faces selectable. Example of the output below. Anything I can do or suggestions as to how to prevent this?
      [attachment=0:pvmj8oh0]<!-- ia0 -->seat.jpg<!-- ia0 -->[/attachment:pvmj8oh0]
      Thanks big time for the plugin, it's really put SU on a whole 'nuther level. I'm finally able to do some modeling I really didn't know how to do in SU before.
      It should orient faces to be all the same...
      BIT even then this isn't too problematical...
      Temporarily View > Hidden Lines 'On'.
      Edit the Group.
      Select one face that is correctly oriented, right-click 'Orient' - all connected faces as flipped to match it.
      Done!
      [Perhaps View > Hidden Lines 'Off' if desired]
      • EscapeArtistE Offline
        EscapeArtist
        Edit the Group.
        Done!
        Thanks for the reply. I suppose that this is one of those things in the "D'Oh! Thread" that I missed. 😳 Yet another tip that would have saved me tons of time had I known about it before!
        • fredo6F Offline
          As advised by Daniel and TIG, you should use Orient Face to get them all oriented the same way.
          It is on my list to improve the generation of geometry for Skinning so that all faces are oriented correctly. It is actually not so simple, because one portion of skin can be connected to more than one other.
            I'm sure you've already found it... but in my similar scripts they can 'orient' faces consistently using my 'orient_faces' method [that is published around here somewhere and incorporated in modified forms in these tools]. As long as the created edges have no more than two faces you can consistently 'orient' them all to match even if the mesh 'flips' at some points - they might ALL be made the wrong way round compared to what the user expects... but then a simple reverse fixes them all in one go [I also do tricks like assume the topmost face faces upwards and use that to orient the set from - but that's not foolproof either... open shells might concave OR convex!]
            • fredo6F Offline
              TIG,
              The main problem with have with the SU API is that there is no Bulk methods to work on a set of elements for Smoothing, Reversing, Orienting, etc.... (whereas these methods exist in the natural GUI). As a result, doing it by program results in long response time, even longer that to generate the basic mesh geometry. We could ask the SU Google Team to add these methods in a next version, but you know there is no guarantee.
              For face orientation, my plan is to calculate the orientation in the algorithm itself (based on the ordering of points in the Geom::PolygonMesh construction).
              For the time being, I consider this is not a critical issue for the user, because s/he can always orient, reverse and smoothen instantly the face mesh, even complex, via the native SU GUI (of course, Orient Face should be more known). I assume that users need Curviloft occasionally and do not need to generate 20 meshes by minutes.
                taekle
                Fredo6
                I did this with DC and loft by splines.
                After making transformed copies of only two profiles, then I launched loft by splines.
                Here is my other post which contains more images and information.
                http://forums.sketchucation.com/viewtopic.php?f=289&t=30749#p270943
                Thanks for your efforts I could go further in my DC investigation. 😄
                spiral by loft
                http://taekle.blogspot.com
                  Hi Fredo
                  I just tried the Skinning feature.
                  At first I thought it failed to create the mesh - but then I realised it had created it, just not in the current context. I was working on some curves inside a component with Hide Rest of Model enabled - so I did not see the mesh getting created.
                  • fredo6F Offline
                    @thomthom said:
                    Hi Fredo
                    Currently the mesh is created as a Group at the first level of the model. That's a small bug.
                    Anyway, I will probably improve this part, in particular the possibility to use existing groups, if you build the mesh piece by piece
                      It's quite straightforward to make your new mesh-group in the same 'context' as the selected curve edge[0], in the form entities=edge.parent.entities group=entities.add_group()
                      Then the 'group' for the new mesh will be in the same 'context' as the curve's 'edge'... 🤓
                      • fredo6F Offline
                        TIG,
                        The bug is simply that I used model.enntities instead of model.active_entities, which is the current working context.
                        I cannot rely on edges context, because Curviloft can actually 'borrow' contours from Edges that can be within different groups or components.
                        fredo
                          Got you...
                          So just add the active_ to entities and it works !!! 😒
                          Line#198 in CurviloftGeometry.rb
                          @top_group = @model.**active_**entities.add_group
                          • charly2008C Offline
                            charly2008
                            some further simple constructions with Curviloft. The last image show the basi construction.
                            Charly
                            Curviloft95 Basic Construction.skp
                              Cool geometric exploration ☀
                              • ken28875K Offline
                                ken28875
                                Wow, that's pretty cool. 👍
                                Who would think that Sketchup could do such a thing with a few click of the mouse.
                                Follow Your Dreams.
                                  d12dozr
                                  Amazing stuff, Charly 👍
                                  http://goo.gl/f7ooYh
                                    charly2008
                                    some new curviloft objects.
                                    Charly
                                    • ken28875K Offline
                                      ken28875
                                      Wow, this is really cool. 👍
                                      Could you please show the screenshots of the sketchup geos?
                                      Thank you, Sir.
                                      _KN
                                      Follow Your Dreams.
                                        robert111
                                        charly2008
                                        can you make juste one tutorial for yours nice jobs
                                          charly2008
                                          Hi Ken, hi Robert,
                                          at first a few screen shots from SketchUp.
                                          • mitcorbM Offline
                                            mitcorb
                                            You have a great imagination, and I assume your knowledge is less limited than many 😄 👍 👍
                                            I notice in the SKup captures that the geometry is coincident but not intersecting. I did not realize that a render app would tolerate this?
                                            By the way, which render app is it?
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 65
                                            • 66
                                            • 35 / 66
