    [Plugin] Automatic Face Reverser
    35 Posts 32 Posters 86.5k Views 32 Watching
      Dan
      Thank you very much, Didier!
      Much appreciated.
      Very useful script.
      • jim smithJ Offline
        jim smith
        Just wanted to add my thanks Didier - very handy tool to tidy up a model.
        "Out of clutter find simplicity,
        from discord find harmony,
        In the middle of difficulty lies opportunity"
        Albert Einstein
          remus
          have a 👍 from me as wel, ive been using this ruby quite a lot recently.
          • ___olo_ Offline
            ___olo
            thanks you 😍
            Xin chào nhau giữa con đường
            Mùa xuân phía trước, miên trường phía sau
              digby dart
              This is a big time saver and a joy to use. Thank you very much. 😄
                Tricky as usual! 👍
                  arcano
                  fantastic ruby ! Thanks a lot !
                    TeKnoel
                    Wow! This is going to be great! 😍
                      SU Reviewer
                      This is definitely a useful plugin. But I noticed that if you already have textures applied to a face and then reverse the faces, the plugin reverses the texture as well. I realize that reversing the faces is the whole point of the plugin but is there a way to ignore it if a texture is present or move the texture to the new side (so it stays in the same location)?
                      Thanks for your hard work! 👍
                      Living Einstein's dream through SketchUp.
                      "Imagination is a preview of life's coming attractions" - Albert Einstein
                      Joe Simhon ~ SketchUp Plugin Reviews
                      • Didier BurD Offline
                        Didier Bur
                        Hi SUReviewer,
                        Good point. On the to-do list...
                        DB
                          Ruturaj
                          Hello,
                          yes this plugin is very useful.......
                          Thank you Didier Bur 👍 👍 👍
                          Thanks,
                          Ruturaj
                          Thanks,
                          RuturaJ
                          • honoluludesktopH Offline
                            honoluludesktop
                            Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
                            From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
                              lenova
                              Thank you!
                              • O Offline
                                orjinalp
                                thanks...
                                  sijeljaaf
                                  Thank you so much but it doesn't work with my sketchup pro 8
                                    You have to explain how it doesn't work...
                                    Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
                                    Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
                                    • JVT_LTDJ Offline
                                      JVT_LTD
                                      Many thanks to this... Its truly functional...
                                      • U Offline
                                        unal
                                        teşekkürler:)
                                        • V Offline
                                          vaaron21
                                          @tig said:
                                          It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
                                            If you read the PDF file that came with the plugin you would see on the third page that this plugin shows only in the context menu. It doesn't appear in Plugins or any other the other menus.
