[Plugin] Automatic Face Reverser
Here is "yet another face reverser"...
This one tries to be automatic
PDF doc included.
Enjoy,Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Vbfr
ENGLISH version. Unzip in Plugins folder.
Didier, you're a true ruby-master..!!
Haven't tried if this works, yet - but if you've succeeded this will be helpfull to many...
I remember back at the "old" SU forum, Todd was preparing a similar ruby for more than a year without success... -
Thank you.
Thank you very much, Didier!
Much appreciated.
Very useful script. -
Just wanted to add my thanks Didier - very handy tool to tidy up a model.
have a from me as wel, ive been using this ruby quite a lot recently.
thanks you
This is a big time saver and a joy to use. Thank you very much.
Tricky as usual!
fantastic ruby ! Thanks a lot !
Wow! This is going to be great!
This is definitely a useful plugin. But I noticed that if you already have textures applied to a face and then reverse the faces, the plugin reverses the texture as well. I realize that reversing the faces is the whole point of the plugin but is there a way to ignore it if a texture is present or move the texture to the new side (so it stays in the same location)?
Thanks for your hard work!
Hi SUReviewer,
Good point. On the to-do list... -
Hello,
yes this plugin is very useful.......
Thank you Didier Bur
Thanks,
Ruturaj -
Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
Thank you!
thanks...
Thank you so much but it doesn't work with my sketchup pro 8
Thanks -
You have to explain how it doesn't work...
Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
