    [Plugin] Automatic Face Reverser
    35 Posts 32 Posters 84.5k Views 32 Watching
    • Didier BurD Offline
      Didier Bur
      Here is "yet another face reverser"...
      This one tries to be automatic 😍
      PDF doc included.
      Enjoy,
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Vbfr
      ENGLISH version. Unzip in Plugins folder.
      VERSION FRANCAISE. Dezipper dans le dossier Plugins.
      DB
      • FrederikF Offline
        Frederik
        Didier, you're a true ruby-master..!! 😄
        Haven't tried if this works, yet - but if you've succeeded this will be helpfull to many... 😉
        I remember back at the "old" SU forum, Todd was preparing a similar ruby for more than a year without success...
        Cheers
        Kim Frederik
        • CadFatherC Offline
          CadFather
          • boofredlayB Offline
            boofredlay
            Thank you.
              Dan
              Thank you very much, Didier!
              Much appreciated.
              Very useful script.
              • jim smithJ Offline
                jim smith
                Just wanted to add my thanks Didier - very handy tool to tidy up a model.
                "Out of clutter find simplicity,
                from discord find harmony,
                In the middle of difficulty lies opportunity"
                Albert Einstein
                  remus
                  have a 👍 from me as wel, ive been using this ruby quite a lot recently.
                  • ___olo_ Offline
                    ___olo
                    thanks you 😍
                    Xin chào nhau giữa con đường
                    Mùa xuân phía trước, miên trường phía sau
                      digby dart
                      This is a big time saver and a joy to use. Thank you very much. 😄
                        Tricky as usual! 👍
                          arcano
                          fantastic ruby ! Thanks a lot !
                            TeKnoel
                            Wow! This is going to be great! 😍
                              SU Reviewer
                              This is definitely a useful plugin. But I noticed that if you already have textures applied to a face and then reverse the faces, the plugin reverses the texture as well. I realize that reversing the faces is the whole point of the plugin but is there a way to ignore it if a texture is present or move the texture to the new side (so it stays in the same location)?
                              Thanks for your hard work! 👍
                              Living Einstein's dream through SketchUp.
                              "Imagination is a preview of life's coming attractions" - Albert Einstein
                              Joe Simhon ~ SketchUp Plugin Reviews
                                Didier Bur
                                Hi SUReviewer,
                                Good point. On the to-do list...
                                DB
                                  Ruturaj
                                  Hello,
                                  yes this plugin is very useful.......
                                  Thank you Didier Bur 👍 👍 👍
                                  Thanks,
                                  Ruturaj
                                  Thanks,
                                  RuturaJ
                                  • honoluludesktopH Offline
                                    honoluludesktop
                                    Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
                                    From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
                                      lenova
                                      Thank you!
                                      • O Offline
                                        orjinalp
                                        thanks...
                                          sijeljaaf
                                          Thank you so much but it doesn't work with my sketchup pro 8
                                          • TIGT Online
                                            You have to explain how it doesn't work...
                                            Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
                                            Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
