    [Plugin] Automatic Face Reverser
    35 Posts 32 Posters 86.5k Views 32 Watching
      Tricky as usual! πŸ‘
        arcano
        fantastic ruby ! Thanks a lot !
          TeKnoel
          Wow! This is going to be great! 😍
            SU Reviewer
            This is definitely a useful plugin. But I noticed that if you already have textures applied to a face and then reverse the faces, the plugin reverses the texture as well. I realize that reversing the faces is the whole point of the plugin but is there a way to ignore it if a texture is present or move the texture to the new side (so it stays in the same location)?
            Thanks for your hard work! πŸ‘
            Living Einstein's dream through SketchUp.
            "Imagination is a preview of life's coming attractions" - Albert Einstein
            Joe Simhon ~ SketchUp Plugin Reviews
            • Didier BurD Offline
              Didier Bur
              Hi SUReviewer,
              Good point. On the to-do list...
              DB
                Ruturaj
                Hello,
                yes this plugin is very useful.......
                Thank you Didier Bur πŸ‘ πŸ‘ πŸ‘
                Thanks,
                Ruturaj
                Thanks,
                RuturaJ
                • honoluludesktopH Offline
                  honoluludesktop
                  Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
                  From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
                    lenova
                    Thank you!
                    • O Offline
                      orjinalp
                      thanks...
                        sijeljaaf
                        Thank you so much but it doesn't work with my sketchup pro 8
                          You have to explain how it doesn't work...
                          Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
                          Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
                          • JVT_LTDJ Offline
                            JVT_LTD
                            Many thanks to this... Its truly functional...
                            • U Offline
                              unal
                              teşekkürler:)
                              • V Offline
                                vaaron21
                                @tig said:
                                It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
                                  If you read the PDF file that came with the plugin you would see on the third page that this plugin shows only in the context menu. It doesn't appear in Plugins or any other the other menus.
                                    jorgesalros
                                    Works fine, well done
                                    • F Offline
                                      function
                                      I'm not seeing the context menu in 2014... this plugin is great!
                                      • bazB Offline
                                        baz
                                        Me too
                                        • BoxB Offline
                                          Baz, Didiers plugins haven't been updated to work with SU2014 but some of them can be fixed. This is one of them. It's a simple edit.
                                          Tig explains how here.
                                          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=12354%26amp;start=60#p513679
                                            Didier has agreed that I might update some of his Plugins available from the PluginStore...
                                            Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Vbfr It is compatible with v2014 and v2015.
