    [Plugin] Automatic Face Reverser
    35 Posts 32 Posters 83.2k Views 32 Watching
      TeKnoel
      Wow! This is going to be great! 😍
        SU Reviewer
        This is definitely a useful plugin. But I noticed that if you already have textures applied to a face and then reverse the faces, the plugin reverses the texture as well. I realize that reversing the faces is the whole point of the plugin but is there a way to ignore it if a texture is present or move the texture to the new side (so it stays in the same location)?
        Thanks for your hard work! πŸ‘
        Living Einstein's dream through SketchUp.
        "Imagination is a preview of life's coming attractions" - Albert Einstein
        Joe Simhon ~ SketchUp Plugin Reviews
        • Didier BurD Offline
          Didier Bur
          Hi SUReviewer,
          Good point. On the to-do list...
          DB
            Ruturaj
            Hello,
            yes this plugin is very useful.......
            Thank you Didier Bur πŸ‘ πŸ‘ πŸ‘
            Thanks,
            Ruturaj
            Thanks,
            RuturaJ
            • honoluludesktopH Offline
              honoluludesktop
              Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
              From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
                lenova
                Thank you!
                • O Offline
                  orjinalp
                  thanks...
                    sijeljaaf
                    Thank you so much but it doesn't work with my sketchup pro 8
                      You have to explain how it doesn't work...
                      Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
                      Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
                      • JVT_LTDJ Offline
                        JVT_LTD
                        Many thanks to this... Its truly functional...
                        • U Offline
                          unal
                          teşekkürler:)
                          • V Offline
                            vaaron21
                            @tig said:
                            It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
                              If you read the PDF file that came with the plugin you would see on the third page that this plugin shows only in the context menu. It doesn't appear in Plugins or any other the other menus.
                                jorgesalros
                                Works fine, well done
                                • F Offline
                                  function
                                  I'm not seeing the context menu in 2014... this plugin is great!
                                  • bazB Offline
                                    baz
                                    Me too
                                    • BoxB Offline
                                      Baz, Didiers plugins haven't been updated to work with SU2014 but some of them can be fixed. This is one of them. It's a simple edit.
                                      Tig explains how here.
                                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=12354%26amp;start=60#p513679
                                        Didier has agreed that I might update some of his Plugins available from the PluginStore...
                                        Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Vbfr It is compatible with v2014 and v2015.
                                        • E Offline
                                          Emersonvip
                                          thanks! very good. 5 stars.
                                            m93a
                                            Automatic face reverser? Wonder how it works on a mobius strip...
                                            • 2 / 2
