    [Plugin] Automatic Face Reverser
    35 Posts 32 Posters 87.0k Views 32 Watching
    • Didier BurD
      Didier Bur
      Hi SUReviewer,
      Good point. On the to-do list...
      DB
        Ruturaj
        Hello,
        yes this plugin is very useful.......
        Thank you Didier Bur πŸ‘ πŸ‘ πŸ‘
        Thanks,
        Ruturaj
        Thanks,
        RuturaJ
        • honoluludesktopH
          honoluludesktop
          Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
          From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
          • L
            lenova
            Thank you!
            • O
              orjinalp
              thanks...
                sijeljaaf
                Thank you so much but it doesn't work with my sketchup pro 8
                  You have to explain how it doesn't work...
                  Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
                  Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
                  • JVT_LTDJ
                    JVT_LTD
                    Many thanks to this... Its truly functional...
                    • U
                      unal
                      teşekkürler:)
                      • V
                        vaaron21
                        @tig said:
                        It comes up in the plugin manager but it doesn't appear in the drop down menu for plugins.
                          If you read the PDF file that came with the plugin you would see on the third page that this plugin shows only in the context menu. It doesn't appear in Plugins or any other the other menus.
                            jorgesalros
                            Works fine, well done
                            • F
                              function
                              I'm not seeing the context menu in 2014... this plugin is great!
                              • bazB
                                baz
                                Me too
                                • BoxB
                                  Baz, Didiers plugins haven't been updated to work with SU2014 but some of them can be fixed. This is one of them. It's a simple edit.
                                  Tig explains how here.
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=12354%26amp;start=60#p513679
                                    Didier has agreed that I might update some of his Plugins available from the PluginStore...
                                    Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Vbfr It is compatible with v2014 and v2015.
                                    • E
                                      Emersonvip
                                      thanks! very good. 5 stars.
                                        m93a
                                        Automatic face reverser? Wonder how it works on a mobius strip...
                                        • boofredlayB
                                          boofredlay
                                          It would generate perpetual energy like the cat and toast in this video.
                                          • HornOxxH
                                            HornOxx
                                            Thanks for this Plugin πŸ‘
                                            Great video - i love this physics fun πŸ˜„ πŸ˜„
                                            never trust a skinny cook
                                            • 2 / 2
