    [Plugin] Automatic Face Reverser
    35 Posts 32 Posters 84.7k Views 32 Watching
    • FrederikF Offline
      Frederik
      Didier, you're a true ruby-master..!! 😄
      Haven't tried if this works, yet - but if you've succeeded this will be helpfull to many... 😉
      I remember back at the "old" SU forum, Todd was preparing a similar ruby for more than a year without success...
      Cheers
      Kim Frederik
      • CadFatherC Offline
        CadFather
        • boofredlayB Offline
          boofredlay
          Thank you.
            Dan
            Thank you very much, Didier!
            Much appreciated.
            Very useful script.
            • jim smithJ Offline
              jim smith
              Just wanted to add my thanks Didier - very handy tool to tidy up a model.
              "Out of clutter find simplicity,
              from discord find harmony,
              In the middle of difficulty lies opportunity"
              Albert Einstein
                remus
                have a 👍 from me as wel, ive been using this ruby quite a lot recently.
                • ___olo_ Offline
                  ___olo
                  thanks you 😍
                  Xin chào nhau giữa con đường
                  Mùa xuân phía trước, miên trường phía sau
                    digby dart
                    This is a big time saver and a joy to use. Thank you very much. 😄
                      Tricky as usual! 👍
                        arcano
                        fantastic ruby ! Thanks a lot !
                          TeKnoel
                          Wow! This is going to be great! 😍
                            SU Reviewer
                            This is definitely a useful plugin. But I noticed that if you already have textures applied to a face and then reverse the faces, the plugin reverses the texture as well. I realize that reversing the faces is the whole point of the plugin but is there a way to ignore it if a texture is present or move the texture to the new side (so it stays in the same location)?
                            Thanks for your hard work! 👍
                            Living Einstein's dream through SketchUp.
                            "Imagination is a preview of life's coming attractions" - Albert Einstein
                            Joe Simhon ~ SketchUp Plugin Reviews
                            • Didier BurD Offline
                              Didier Bur
                              Hi SUReviewer,
                              Good point. On the to-do list...
                              DB
                                Ruturaj
                                Hello,
                                yes this plugin is very useful.......
                                Thank you Didier Bur 👍 👍 👍
                                Thanks,
                                Ruturaj
                                Thanks,
                                RuturaJ
                                • honoluludesktopH Offline
                                  honoluludesktop
                                  Sigh.....I spent several weeks duplicating this plugin because I didn't do a good enough job searching for this one. Oh well, good practice programing.
                                  From the documentation, it will find faces inside components and groups, this is better then reverse_back_face, but not in interior views (reverse_back_face will). Maybe some one will come along and do both.
                                    lenova
                                    Thank you!
                                    • O Offline
                                      orjinalp
                                      thanks...
                                        sijeljaaf
                                        Thank you so much but it doesn't work with my sketchup pro 8
                                          You have to explain how it doesn't work...
                                          Does it download, install, add menu entires, any error messages [on screen or in the Ruby Console?], run as expected but not reverse faces, do it sometimes work, does it work but not work as you envisaged???
                                          Once we have a better idea we can think about how we can resolve the issue, clearly it works for lots of people so something must be awry with your setup...
                                          • JVT_LTDJ Offline
                                            JVT_LTD
                                            Many thanks to this... Its truly functional...
