    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • X Offline
      xrok1
      i knew i should have popped that before it got out of hand! ๐Ÿ˜ฒ
      who would have ever imagined fur for SU?????????????????????????????
      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        rickgraham
        @rickgraham said:
        @tak2hata said:
        Hi, Jeff and rick.
        I update Fur_en.rb
        The WebDialog has problem in Mac OSX.
        So I put another menu for the correspondence of this problem.
        The menu named "fur!(MAC)".
        Using InputBox Dialog.
        How in this?
        I cannot tell what the intended difference between the 1 - Linear and 2- Arch are. By the way, the Mac only shows 1,2,3,4 - I saw another persons screen shot which showed me what they were for.
        Rick
        • jeff hammondJ Offline
          @tak2hata said:
          Hi, Jeff and rick.
          I update Fur_en.rb
          How in this?
          yep, we're growing some fur now ๐Ÿ˜„
          thanks!
          • soloS Offline
            Was just a matter of time until someone posted hairy balls. ๐Ÿ’š
            • X Offline
              xrok1
              i can hear all the script writers now
              "Why the fook didn't i think of that? ๐Ÿ˜• , its so fookin simple too! ๐Ÿ˜ฒ"
              ๐Ÿคฃ
              awsome, simply awsome! ๐Ÿ˜„
                rickgraham
                ๐Ÿคฃ
                This is a banner day for me and SU.
                Rick
                • ken28875K Offline
                  ken28875
                  Wow...I am speechless...fur for Sketchup! ๐Ÿ˜ฎ ๐Ÿ˜ฒ
                  ๐Ÿ‘ ๐Ÿ‘
                  _KN
                  Follow Your Dreams.
                    Mandatory:
                      ark
                      Absolute fantastic
                      Somehow I can't seem to generate short hair?
                      I set the "Lenght" to 0.0001 but the hair doesn't seem to get shorter then approx. 50 mm!
                      It would be nice to be able to save presets!!!
                      Great job ๐Ÿ˜Ž
                      • soloS Offline
                        Teddy fur.
                        Which all but choked SU to death.
                          minguinhirigue
                          Really nice one I missed from a long time... Thanks.
                          • Mike LuceyM Offline
                            Mike Lucey
                            Thanks tak2hata,
                            I can see this plugin becoming a great favorite ๐Ÿ‘
                            Mike
                            • utilerU Offline
                              utiler
                              No way!!
                              Now I can see what a woman looks like with a beard.
                              Just Curious...
                              • W Offline
                                Whaat
                                Great plugin! Thanks for sharing!
                                • CadFatherC Offline
                                  CadFather
                                  Just when you think you've seen it all.. tak2hata comes along with another great idea...thanks! โ˜€
                                    CadFather
                                    yes please.. ๐Ÿ‘
                                      I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info from your plugin and translate it into the rendering program entities, without creating it inside SU.
                                      Oooh! Good idea. Keep all data as attributes per face. And use simple lines (in reduced numbers) to represent the fur.
                                      • N Offline
                                        notareal
                                        Would it be possible?
                                        Cheers
                                        Tomasz
                                        That would be great!
                                          tomasz
                                          Hi, Thanks a lot for such an interesting plugin!
                                          @tak2hata said:
                                          Creating Too Much Polygon is very slow.
                                          And to use code "entities.fill_from_mesh" must need blank Group.
                                          This Plugin executes each selected faces.
                                          Creating Group each new 800 polygons.
                                          so it parts.
                                          I have a request as a developer. Can you add an option to attach a fur parameters to a SU material as attributes. Multiple exporters to rendering programs could call your plugin to receive info on location and parameters of the fur. Instead of choking SU, an exporter would get the geometry info (EDIT: transformations of components) from your plugin and translate it into the rendering program entities, without creating it inside SU.
                                          Cheers
                                          Tomasz
                                          • olisheaO Offline
                                            olishea
                                            one of the best plugins around!!
                                            i'm making everything furry! ๐Ÿ˜Ž
                                            render cooking ๐Ÿ˜„
                                            oli
                                            • 32
                                            • 33
                                            • 2 / 33
