    Damn toolbars...
    31 Posts 15 Posters 5.5k Views 15 Watching
    • P
      Panga
      I don't know if this solution as already been suggested, but would it be possible ?
      This way we could have just a few toolbars...
        The only control we have over toolbars from the API is adding buttons and hide/show the toolbars. That's it. ๐Ÿ˜ž
        • P
          Panga
          And could it be done using a webdialog ?
            Not flyouts.
            With webdialogs we can create normal non-flyout menus, but you got this large window frame as well. that's why I was interseted in thsi guy that managed to dock SU's toolwindows to SU's viewport.
              dedmin
              Better with a second monitor
              • alexschreyerA
                alexschreyer Extension Creator
                From my days programming with Delphi, I remember that for a developer it is possible to just buy a new "toolbar system" and add it to the code. It is not too hard to do this since many components are out there. There is no real need to go with the default UI elements.
                And although I still haven't warmed up to the Office-ribbon in Revit, I would not mind the ribbon in SU if it kept everything in place.
                Cheers,
                Alex
                Author of "Architectural Design with SketchUp":
                http://sketchupfordesign.com/
                • B
                  bytor
                  Alex,
                  I know what you mean about the Revit Ribbons - but when you get used to where everything is (I still have to look for 4 or 5 items I commonly use) it becomes pretty productive. Something similar would be nice for SU - but I doubt you will see Google adopt such a MS flavor. I have to instruct and often support users @ work on SU, and it drives me crazy looking for toolbars in their perosnalized layouts.
                  Dean
                  Find the Cost of Freedom.....
                  • P
                    Panga
                    Humm another suggestion...Is that possible to insert a swf file in a webdialog ? I have some skills in AS3 that could allow me to create my own menu with flyouts...And is it possible to hide the window of a webdialog ?
                      A Webdialog is just an HTML document. So yes.
                      You won't be able to make flyouts that goes outside the webdialog window.
                      I take it you mean the window frame? That can't be done. ๐Ÿ˜ž
                      • P
                        Panga
                        Damn...everything is against us... ๐Ÿ˜›
                        EDIT : The better alternative I see, is to do the same thing that Fredo6 did with Tools on surface plugin where a "toolbar" appears at the top of main window (where we draw) with all the tools and options of the plugins...
                        This way, we could regroup tools and plugin by categories in order to have less toolbars displayed in SU.
                        EDIT : Or maybe doing something like in Blender, some contextual menu giving access to everything...but all those things should be develop by google again...
                        • ken28875K
                          ken28875
                          I agree with Panga. We need to find a way to have the plugins toolbars stay in place.
                          I used a lot of plugins for my work everyday and I keep on adding new ones. So it is very frustrating an annoying to have to put them back in order every time a new plugin is added that messes everything up.
                          Another thing too, is the toolbars will go crazy after we minimize the windows and come back to full size.
                          Hopefully someone will find a fix to these issues.
                          Thanks and have a terrific day!
                          _KN
                          http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/sketchup_plugins.jpg
                          http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/sketchup_plugins3.jpg
                          http://i593.photobucket.com/albums/tt12/ken28875/Sketchup/sketchup_plugins2.jpg
                          Follow Your Dreams.
                          • soloS
                            ๐Ÿ˜ฒ ๐Ÿ˜ฎ ๐Ÿ˜ฒ ๐Ÿ’š
                            Yikes, tooo much, my eyes hurt.
                            • K
                              Khai
                              how hard would it be to create a ruby that creates a single floating toolbar containing all the tools installed in one panel?
                              install a new ruby, run the panel ruby to add the new tool... the panel floating so there's no workspace muckup..
                              just pulling this outta the air so don't take to seriously if it's a bad idea ๐Ÿ˜‰
                              • soloS
                                Or have all toolbars hidden hitting f11 shows them and hides them again?
                                  remus
                                  I think that one goes in the 'nice in theory but doesnt work in practice' pile. The major flaw that comes to mind is scrambled ruby scripts which cant be modified in any way unless you can get hold of the original file, but then that rather defeats the point of scrambling it.
                                  • P
                                    Panga
                                    I'm becoming crazy...after three days of work under SU, I'm afraid of minimizing any window...whatever the program I'm using, I'm juste thinking in my head "Don't do that you idiot !! You'll have to reorganize all your toolbars !!"...but then I realize that I'm not in SU and I can breathe freely...please Google...do something for me, I'm sick !!
                                      Jim
                                      It's certainly possible to replace most toolbars with a single window. I have taken to using a horrible, hacked-up, hand-coded WebDialog to replace all my Toolbars.
                                      I think a4chitect's Launchit has a lot of potential.
                                      • demD
                                        dem
                                        It was really annoying. so I make a toolbox with tabs + remake standard panels
                                        http://a2.inf.ua/IMG/toolbox.png
                                        https://lh3.googleusercontent.com/-fjBpssNdQ_w/VMlBZQmmcCI/AAAAAAAACrY/sHsk-BPXWU4/w326-h233-no/toolbox.gif
                                        • C
                                          cadmunkey
                                          Sweet!!! ๐Ÿ‘
                                            slbaumgartner
                                            Pretty slick @dem! Could you say some more about how you did that? Thanks.
