    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • COSEDIMARCOC Offline
      COSEDIMARCO
      @Fredo6
      New Italian translation is ready.
      You should add a string for "Donation...". The translation is "Donazioni...".
      Ps. My nickname is "COSEDIMARCO" and not "Marco Cosedi". πŸ˜„ it means " Things of Marco" in Italian.
      Italian translation for the new version
      [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
      • fredo6F Offline
        @massimo said:
        Fredo, some problems with this new version. Draw a rectangle, pushpull it then stretch. Use the bend tool. It doesn't works properly anymore.
        Massimo,
        This is not really a bug of FreeScale (and not of the version 2.0e), but a problem of Selection.
        When you exit the Stretch, only the edges are selected, not the faces.
        Then applying the Bend would only operate on these selected edges.
        You can try by deselecting All after stretch, before using Bend.
        This is why I recommend to enclose the geometry in a group (or component), because with geometry at native level, it is very difficult in Ruby to maintain properly the selection for faces (due to the fact that SU changes the object Ids when faces are deformed).
        • massimoM Offline
          massimo Moderator
          Ok, thanks. That works.
          Massimo
          • daikuD Offline
            daiku
            Confirming that stretch to target now works correctly. Excellent work, as always, Fredo. CB.
            Clark Bremer
            http://www.northernlightstimberframing.com
            • fredo6F Offline
              NEW VERSION 2.0f NOW RELEASED
              It fixes remaining issues for Mac compatibility of web dialog boxes and includes the full translation in Italian by COSEDIMARCOhttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
              You also need to download LibFredo6 3.1f
              • jeff hammondJ Offline
                hey Fred,
                just confirming that the latest release (f) is working fine and all the mac implementations are A-OK
                many thanks ❗
                  mkelly
                  I'm new to the forum, were is the link to the downloads?
                  Mkelly
                  • Chris FullmerC Offline
                    The link is at the bottom of the first post in this thread.
                      spjonesuk
                      Im so sorry to ask but how do i dowload this freescale I cant see link to download?
                        The link is at the bottom of the very first post.
                        I feel like a broken record player.
                        • david_hD Offline
                          david_h
                          Record Player . . .??? What's that? πŸ˜„
                          • romboutR Offline
                            rombout
                            I cant download libfredo6 3.1f proberly it gives of a file of 6kb. Tried libfredo6 3.1e but nothing happens.
                            Oke got it to work... Lets play with it
                            • CadFatherC Offline
                              CadFather
                              Hi Fredo
                              what are the chances i can remove the separators from the icons toolbar?
                                CadFather
                                Thank you Fredo - class act (as always) πŸ˜„
                                  silver_shadow
                                  Hi Fredo
                                  I like your tool. I want to know if you can re make the stretch tool so that you if stretch 4 or more objects, it calculates the spaces between and re position all if them and not only have one cut face but several depending the amount of objects between it
                                  pretty please.
                                  Like if you do a palacade fence, you can stretch it and all those poles will be re spaced.
                                  • fredo6F Offline
                                    @silver_shadow said:
                                    Hi Fredo
                                    pretty please.
                                    I thought about that of course. There is no major geometrical issues except the GUI to help you decide, because in some instances, it won't do what you wish it would do.
                                    By the way, what you describe is pretty much what Dynamic Components have been made for.
                                    • W Offline
                                      watkins
                                      Dear Fredo,
                                      Further to a previous post, what settings should I use to remove the blank icon boxes from the tool bar, or are these unused boxes earmarked for future tool?
                                      A fantastic and generous contribution to the SU community. Thank you.
                                      Kind regards,
                                      Bob
                                      • romboutR Offline
                                        rombout
                                        Hi fredo... I had it working. But it stopped today. It wont show anymore. I tried downloading the 31f today and the link worked, only it is still not working. I dont know what happened. I thought of a different ruby but that was not the cause. It was working on my pc and wanted it on my imac. I got this error that it only worked with 31 and not 30. Tonight i wanted to work with it on the pc but it didnt show up anymore. I just copied the files from the pluggin folder to a mem stick
                                        • fredo6F Offline
                                          In general, for installation and upgrades, just unzip the files provided (select All and extract, to make sure you transfer the folder hierarchy) and answer YES to any prompt dialog box to replace existing files.
                                          Do not worry with previous versions. By unzipping the files, it will replace the ones that have to be replaced. Also never rename or move yourself the files outside of their folder.
                                          Finally, it may help if you tell me whether you:
                                          • get a message at Sketchup startup
                                          • see the menus and toolbar
                                          • get errors at run time
                                            and anything that may guide me to help you
                                          • romboutR Offline
                                            rombout
                                            well ad first i had this error on the mac that i had to upgrade from 30 > 31. Did that and it worked... aslo upgraded on the pc but it doesnt work now!!! ad first it worked with the libfredo 30e but now it doesnt! so any suggestions any one πŸ‘Ώ
                                            i dont see any menu's both of them no freescale and no libfredo settings
                                            • 49
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 56
                                            • 57
                                            • 51 / 57
