    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
    • massimoM Offline
      massimo Moderator
      Ok, thanks. That works.
      Massimo
      • daikuD Offline
        daiku
        Confirming that stretch to target now works correctly. Excellent work, as always, Fredo. CB.
        Clark Bremer
        http://www.northernlightstimberframing.com
        • fredo6F Offline
          NEW VERSION 2.0f NOW RELEASED
          It fixes remaining issues for Mac compatibility of web dialog boxes and includes the full translation in Italian by COSEDIMARCOhttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
          You also need to download LibFredo6 3.1f
          • jeff hammondJ Offline
            hey Fred,
            just confirming that the latest release (f) is working fine and all the mac implementations are A-OK
            many thanks ❗
              mkelly
              I'm new to the forum, were is the link to the downloads?
              Mkelly
              • Chris FullmerC Offline
                The link is at the bottom of the first post in this thread.
                  spjonesuk
                  Im so sorry to ask but how do i dowload this freescale I cant see link to download?
                    The link is at the bottom of the very first post.
                    I feel like a broken record player.
                    • david_hD Offline
                      david_h
                      Record Player . . .??? What's that? πŸ˜„
                      • romboutR Offline
                        rombout
                        I cant download libfredo6 3.1f proberly it gives of a file of 6kb. Tried libfredo6 3.1e but nothing happens.
                        Oke got it to work... Lets play with it
                        • CadFatherC Offline
                          CadFather
                          Hi Fredo
                          what are the chances i can remove the separators from the icons toolbar?
                            CadFather
                            Thank you Fredo - class act (as always) πŸ˜„
                              silver_shadow
                              Hi Fredo
                              I like your tool. I want to know if you can re make the stretch tool so that you if stretch 4 or more objects, it calculates the spaces between and re position all if them and not only have one cut face but several depending the amount of objects between it
                              pretty please.
                              Like if you do a palacade fence, you can stretch it and all those poles will be re spaced.
                              • fredo6F Offline
                                @silver_shadow said:
                                Hi Fredo
                                pretty please.
                                I thought about that of course. There is no major geometrical issues except the GUI to help you decide, because in some instances, it won't do what you wish it would do.
                                By the way, what you describe is pretty much what Dynamic Components have been made for.
                                • W Offline
                                  watkins
                                  Dear Fredo,
                                  Further to a previous post, what settings should I use to remove the blank icon boxes from the tool bar, or are these unused boxes earmarked for future tool?
                                  A fantastic and generous contribution to the SU community. Thank you.
                                  Kind regards,
                                  Bob
                                  • romboutR Offline
                                    rombout
                                    Hi fredo... I had it working. But it stopped today. It wont show anymore. I tried downloading the 31f today and the link worked, only it is still not working. I dont know what happened. I thought of a different ruby but that was not the cause. It was working on my pc and wanted it on my imac. I got this error that it only worked with 31 and not 30. Tonight i wanted to work with it on the pc but it didnt show up anymore. I just copied the files from the pluggin folder to a mem stick
                                    • fredo6F Offline
                                      In general, for installation and upgrades, just unzip the files provided (select All and extract, to make sure you transfer the folder hierarchy) and answer YES to any prompt dialog box to replace existing files.
                                      Do not worry with previous versions. By unzipping the files, it will replace the ones that have to be replaced. Also never rename or move yourself the files outside of their folder.
                                      Finally, it may help if you tell me whether you:
                                      • get a message at Sketchup startup
                                      • see the menus and toolbar
                                      • get errors at run time
                                        and anything that may guide me to help you
                                      • romboutR Offline
                                        rombout
                                        well ad first i had this error on the mac that i had to upgrade from 30 > 31. Did that and it worked... aslo upgraded on the pc but it doesnt work now!!! ad first it worked with the libfredo 30e but now it doesnt! so any suggestions any one πŸ‘Ώ
                                        i dont see any menu's both of them no freescale and no libfredo settings
                                        • fredo6F Offline
                                          Maybe you should refer to the following post, which indicates the exact footprint of the plugin in the Sketchup directory.
                                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=158341#p158225
                                            steelers05
                                            I am running the most recent version on a pc and all of the tools work except the bend tool....half the time it wont even activate when I click the icon and when it does work, it only rotates the object and doesnt bend it. Any ideas what I could be doing wrong?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 58
                                            • 59
                                            • 14 / 59
