    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
    • jeff hammondJ
      DO they icons png's belong in their own subfolder?
      they should be in a folder called 'IMAGES_Standard' which is inside the 'FREESCALE_Dir_20' folder.
      if you want daniel's icons, they will be in a folder called 'IMAGES_DanielS' which goes in the freescale folder and you activate them via the parameters dialog.
      • david_hD
        david_h
        Success!!! Thanks a lot.
        D
          Matt666
          Hi Fredo!
          I just tried your new version (v2.0d), but it seems to bug when I want to move some points...
          • Procedure:
          • Start scale tool
          • Select a cube
          • Try to move a corner (with one of your points). Impossible to move any point.* Error message in the ruby console:Sans titre 1.jpg πŸ˜‰
          Frenglish at its best !
          My scripts
          • fredo6F
            Matt,
            I don't know what this is, as I cannot reproduce it on my machine.
            Just in case, I slighlty modified the code around the "round" function.
            Can you try it, and tell if you can reproduce the bug.
            to drop in FREESCALE_Dir_20 folder
            • fredo6F
              NEW VERSION 2.0e NOW RELEASED
              It fixes a bug recently found for Stretch in Target mode.
              See details in main post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
              You also need to download LibFredo6 3.1e
              • C
                Click Draw
                Fredo6,
                Was twist just added?
                Thanks,
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                • fredo6F
                  Jeff
                  No, it was in the first release 2.0a.
                  Do you have any issue with the tool?
                  • massimoM
                    massimo Moderator
                    Fredo, some problems with this new version. Draw a rectangle, pushpull it then stretch. Use the bend tool. It doesn't works properly anymore.
                    • utilerU
                      utiler
                      Incredible, Fredo!!!!!
                      Just Curious...
                      • COSEDIMARCOC
                        COSEDIMARCO
                        @Fredo6
                        New Italian translation is ready.
                        You should add a string for "Donation...". The translation is "Donazioni...".
                        Ps. My nickname is "COSEDIMARCO" and not "Marco Cosedi". πŸ˜„ it means " Things of Marco" in Italian.
                        Italian translation for the new version
                        [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                        • fredo6F
                          Massimo,
                          This is not really a bug of FreeScale (and not of the version 2.0e), but a problem of Selection.
                          When you exit the Stretch, only the edges are selected, not the faces.
                          Then applying the Bend would only operate on these selected edges.
                          You can try by deselecting All after stretch, before using Bend.
                          This is why I recommend to enclose the geometry in a group (or component), because with geometry at native level, it is very difficult in Ruby to maintain properly the selection for faces (due to the fact that SU changes the object Ids when faces are deformed).
                          • massimoM
                            massimo Moderator
                            Ok, thanks. That works.
                            Massimo
                            • daikuD
                              daiku
                              Confirming that stretch to target now works correctly. Excellent work, as always, Fredo. CB.
                              Clark Bremer
                              http://www.northernlightstimberframing.com
                              • fredo6F
                                NEW VERSION 2.0f NOW RELEASED
                                It fixes remaining issues for Mac compatibility of web dialog boxes and includes the full translation in Italian by COSEDIMARCOhttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                                You also need to download LibFredo6 3.1f
                                • jeff hammondJ
                                  hey Fred,
                                  just confirming that the latest release (f) is working fine and all the mac implementations are A-OK
                                  many thanks ❗
                                    mkelly
                                    I'm new to the forum, were is the link to the downloads?
                                    Mkelly
                                    • Chris FullmerC
                                      The link is at the bottom of the first post in this thread.
                                        spjonesuk
                                        Im so sorry to ask but how do i dowload this freescale I cant see link to download?
                                        • Chris FullmerC
                                          The link is at the bottom of the very first post.
                                          I feel like a broken record player.
                                          • david_hD
                                            david_h
                                            Record Player . . .??? What's that? πŸ˜„
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 58
                                            • 59
                                            • 13 / 59
