    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.2k Posts 346 Posters 2.9m Views 344 Watching
    • Chris FullmerC Offline
      The link is at the bottom of the very first post.
      I feel like a broken record player.
      • david_hD Offline
        david_h
        Record Player . . .??? What's that? πŸ˜„
        • romboutR Offline
          rombout
          I cant download libfredo6 3.1f proberly it gives of a file of 6kb. Tried libfredo6 3.1e but nothing happens.
          Oke got it to work... Lets play with it
          • CadFatherC Offline
            CadFather
            Hi Fredo
            what are the chances i can remove the separators from the icons toolbar?
              CadFather
              Thank you Fredo - class act (as always) πŸ˜„
                silver_shadow
                Hi Fredo
                I like your tool. I want to know if you can re make the stretch tool so that you if stretch 4 or more objects, it calculates the spaces between and re position all if them and not only have one cut face but several depending the amount of objects between it
                pretty please.
                Like if you do a palacade fence, you can stretch it and all those poles will be re spaced.
                • fredo6F Offline
                  @silver_shadow said:
                  Hi Fredo
                  pretty please.
                  I thought about that of course. There is no major geometrical issues except the GUI to help you decide, because in some instances, it won't do what you wish it would do.
                  By the way, what you describe is pretty much what Dynamic Components have been made for.
                  • W Offline
                    watkins
                    Dear Fredo,
                    Further to a previous post, what settings should I use to remove the blank icon boxes from the tool bar, or are these unused boxes earmarked for future tool?
                    A fantastic and generous contribution to the SU community. Thank you.
                    Kind regards,
                    Bob
                    • romboutR Offline
                      rombout
                      Hi fredo... I had it working. But it stopped today. It wont show anymore. I tried downloading the 31f today and the link worked, only it is still not working. I dont know what happened. I thought of a different ruby but that was not the cause. It was working on my pc and wanted it on my imac. I got this error that it only worked with 31 and not 30. Tonight i wanted to work with it on the pc but it didnt show up anymore. I just copied the files from the pluggin folder to a mem stick
                      • fredo6F Offline
                        In general, for installation and upgrades, just unzip the files provided (select All and extract, to make sure you transfer the folder hierarchy) and answer YES to any prompt dialog box to replace existing files.
                        Do not worry with previous versions. By unzipping the files, it will replace the ones that have to be replaced. Also never rename or move yourself the files outside of their folder.
                        Finally, it may help if you tell me whether you:
                        • get a message at Sketchup startup
                        • see the menus and toolbar
                        • get errors at run time
                          and anything that may guide me to help you
                        • romboutR Offline
                          rombout
                          well ad first i had this error on the mac that i had to upgrade from 30 > 31. Did that and it worked... aslo upgraded on the pc but it doesnt work now!!! ad first it worked with the libfredo 30e but now it doesnt! so any suggestions any one πŸ‘Ώ
                          i dont see any menu's both of them no freescale and no libfredo settings
                          • fredo6F Offline
                            Maybe you should refer to the following post, which indicates the exact footprint of the plugin in the Sketchup directory.
                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=158341#p158225
                              steelers05
                              I am running the most recent version on a pc and all of the tools work except the bend tool....half the time it wont even activate when I click the icon and when it does work, it only rotates the object and doesnt bend it. Any ideas what I could be doing wrong?
                                CadFather
                                Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
                                it's not a big deal though - whenever you stumble upon it..
                                • fredo6F Offline
                                  Two remarks
                                  • For the rotation (instead of bend), you need to activate the slicer (toggle F4). This creates intermediate points and make the bending smoother.
                                  • Before you do any transformation, make sure that your current selection is correct. If you move directly from one tool to another one like Bend, then all geometry at model level may not be selected. This is why it's always better to encapsulate the geometry within groups.
                                    CadFather
                                    Thanks Fredo.. strange, it doesn't work - tried changing the toolbar name..
                                    it doesn't matter - shall i try to find the separators in the files themselves or would i just waste time?
                                    • fredo6F Offline
                                      Strange. It works for me. Do you at least see the option in the Default Parameters dialog box?
                                      Please do not change the code. You won't find where the separators are (I am even lost myself).
                                        CadFather
                                        sorry Fredo, should have been clearer - the update does remove the separators.. so the toolbar looks great - it just doesn't work! : )
                                        ..don't worry about it Fredo, i'll leave it as it is.. i will try and find out if there's some clashing etc.. (Thanks)
                                        • fredo6F Offline
                                          Is it the whole set of tools not working?
                                          Did you try with the version attached in my previous post, just in case?
                                          I'd better know, because I checked that 44 people have downloaded the file.
                                          • fredo6F Offline
                                            @cadfather said:
                                            yes, the whole toolset stops - with both versions,
                                            i also tried with an empty plugins folder as below, same result..
                                            I suggest you then reinstall the standard version 2.0f (and 3.1f for LibFredo6, we never know). I need to investigate.
                                            By the way, when you say 'Stops' what does that mean. For instance, if you open the Ruby console, do you see any message when launching the tools?
                                            PS: Nice icon for the folders!
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 57
                                            • 58
                                            • 14 / 58
