    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
      mkelly
      I'm new to the forum, were is the link to the downloads?
      Mkelly
      • Chris FullmerC
        The link is at the bottom of the first post in this thread.
          spjonesuk
          Im so sorry to ask but how do i dowload this freescale I cant see link to download?
          • Chris FullmerC
            The link is at the bottom of the very first post.
            I feel like a broken record player.
            • david_hD
              david_h
              Record Player . . .??? What's that? πŸ˜„
              • romboutR
                rombout
                I cant download libfredo6 3.1f proberly it gives of a file of 6kb. Tried libfredo6 3.1e but nothing happens.
                Oke got it to work... Lets play with it
                • CadFatherC
                  CadFather
                  Hi Fredo
                  what are the chances i can remove the separators from the icons toolbar?
                  • CadFatherC
                    CadFather
                    Thank you Fredo - class act (as always) πŸ˜„
                      silver_shadow
                      Hi Fredo
                      I like your tool. I want to know if you can re make the stretch tool so that you if stretch 4 or more objects, it calculates the spaces between and re position all if them and not only have one cut face but several depending the amount of objects between it
                      pretty please.
                      Like if you do a palacade fence, you can stretch it and all those poles will be re spaced.
                      • fredo6F
                        @silver_shadow said:
                        Hi Fredo
                        pretty please.
                        I thought about that of course. There is no major geometrical issues except the GUI to help you decide, because in some instances, it won't do what you wish it would do.
                        By the way, what you describe is pretty much what Dynamic Components have been made for.
                        • W
                          watkins
                          Dear Fredo,
                          Further to a previous post, what settings should I use to remove the blank icon boxes from the tool bar, or are these unused boxes earmarked for future tool?
                          A fantastic and generous contribution to the SU community. Thank you.
                          Kind regards,
                          Bob
                          • romboutR
                            rombout
                            Hi fredo... I had it working. But it stopped today. It wont show anymore. I tried downloading the 31f today and the link worked, only it is still not working. I dont know what happened. I thought of a different ruby but that was not the cause. It was working on my pc and wanted it on my imac. I got this error that it only worked with 31 and not 30. Tonight i wanted to work with it on the pc but it didnt show up anymore. I just copied the files from the pluggin folder to a mem stick
                            • fredo6F
                              In general, for installation and upgrades, just unzip the files provided (select All and extract, to make sure you transfer the folder hierarchy) and answer YES to any prompt dialog box to replace existing files.
                              Do not worry with previous versions. By unzipping the files, it will replace the ones that have to be replaced. Also never rename or move yourself the files outside of their folder.
                              Finally, it may help if you tell me whether you:
                              • get a message at Sketchup startup
                              • see the menus and toolbar
                              • get errors at run time
                                and anything that may guide me to help you
                              • romboutR
                                rombout
                                well ad first i had this error on the mac that i had to upgrade from 30 > 31. Did that and it worked... aslo upgraded on the pc but it doesnt work now!!! ad first it worked with the libfredo 30e but now it doesnt! so any suggestions any one πŸ‘Ώ
                                i dont see any menu's both of them no freescale and no libfredo settings
                                • fredo6F
                                  Maybe you should refer to the following post, which indicates the exact footprint of the plugin in the Sketchup directory.
                                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=158341#p158225
                                    steelers05
                                    I am running the most recent version on a pc and all of the tools work except the bend tool....half the time it wont even activate when I click the icon and when it does work, it only rotates the object and doesnt bend it. Any ideas what I could be doing wrong?
                                    • CadFatherC
                                      CadFather
                                      Hi Fredo - just to let you know, after replacing the file 'FreeScale_Common.rb' the tool stops working
                                      it's not a big deal though - whenever you stumble upon it..
                                      • fredo6F
                                        Two remarks
                                        • For the rotation (instead of bend), you need to activate the slicer (toggle F4). This creates intermediate points and make the bending smoother.
                                        • Before you do any transformation, make sure that your current selection is correct. If you move directly from one tool to another one like Bend, then all geometry at model level may not be selected. This is why it's always better to encapsulate the geometry within groups.
                                        • CadFatherC
                                          CadFather
                                          Thanks Fredo.. strange, it doesn't work - tried changing the toolbar name..
                                          it doesn't matter - shall i try to find the separators in the files themselves or would i just waste time?
                                          • fredo6F
                                            Strange. It works for me. Do you at least see the option in the Default Parameters dialog box?
                                            Please do not change the code. You won't find where the separators are (I am even lost myself).
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 58
                                            • 59
                                            • 14 / 59
