    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      @click draw said:
      Was twist just added?
      Jeff
      No, it was in the first release 2.0a.
      Do you have any issue with the tool?
      • massimoM
        massimo Moderator
        Fredo, some problems with this new version. Draw a rectangle, pushpull it then stretch. Use the bend tool. It doesn't works properly anymore.
        • utilerU
          utiler
          Incredible, Fredo!!!!!
          Just Curious...
          • COSEDIMARCOC
            COSEDIMARCO
            @Fredo6
            New Italian translation is ready.
            You should add a string for "Donation...". The translation is "Donazioni...".
            Ps. My nickname is "COSEDIMARCO" and not "Marco Cosedi". πŸ˜„ it means " Things of Marco" in Italian.
            Italian translation for the new version
            [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
            • fredo6F
              Massimo,
              This is not really a bug of FreeScale (and not of the version 2.0e), but a problem of Selection.
              When you exit the Stretch, only the edges are selected, not the faces.
              Then applying the Bend would only operate on these selected edges.
              You can try by deselecting All after stretch, before using Bend.
              This is why I recommend to enclose the geometry in a group (or component), because with geometry at native level, it is very difficult in Ruby to maintain properly the selection for faces (due to the fact that SU changes the object Ids when faces are deformed).
              • massimoM
                massimo Moderator
                Ok, thanks. That works.
                Massimo
                • daikuD
                  daiku
                  Confirming that stretch to target now works correctly. Excellent work, as always, Fredo. CB.
                  Clark Bremer
                  http://www.northernlightstimberframing.com
                  • fredo6F
                    NEW VERSION 2.0f NOW RELEASED
                    It fixes remaining issues for Mac compatibility of web dialog boxes and includes the full translation in Italian by COSEDIMARCOhttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                    You also need to download LibFredo6 3.1f
                    • jeff hammondJ
                      hey Fred,
                      just confirming that the latest release (f) is working fine and all the mac implementations are A-OK
                      many thanks ❗
                        mkelly
                        I'm new to the forum, were is the link to the downloads?
                        Mkelly
                        • Chris FullmerC
                          The link is at the bottom of the first post in this thread.
                            spjonesuk
                            Im so sorry to ask but how do i dowload this freescale I cant see link to download?
                            • Chris FullmerC
                              The link is at the bottom of the very first post.
                              I feel like a broken record player.
                              • david_hD
                                david_h
                                Record Player . . .??? What's that? πŸ˜„
                                • romboutR
                                  rombout
                                  I cant download libfredo6 3.1f proberly it gives of a file of 6kb. Tried libfredo6 3.1e but nothing happens.
                                  Oke got it to work... Lets play with it
                                  • CadFatherC
                                    CadFather
                                    Hi Fredo
                                    what are the chances i can remove the separators from the icons toolbar?
                                    • CadFatherC
                                      CadFather
                                      Thank you Fredo - class act (as always) πŸ˜„
                                        silver_shadow
                                        Hi Fredo
                                        I like your tool. I want to know if you can re make the stretch tool so that you if stretch 4 or more objects, it calculates the spaces between and re position all if them and not only have one cut face but several depending the amount of objects between it
                                        pretty please.
                                        Like if you do a palacade fence, you can stretch it and all those poles will be re spaced.
                                        • fredo6F
                                          @silver_shadow said:
                                          Hi Fredo
                                          pretty please.
                                          I thought about that of course. There is no major geometrical issues except the GUI to help you decide, because in some instances, it won't do what you wish it would do.
                                          By the way, what you describe is pretty much what Dynamic Components have been made for.
                                          • W
                                            watkins
                                            Dear Fredo,
                                            Further to a previous post, what settings should I use to remove the blank icon boxes from the tool bar, or are these unused boxes earmarked for future tool?
                                            A fantastic and generous contribution to the SU community. Thank you.
                                            Kind regards,
                                            Bob
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 58
                                            • 59
                                            • 14 / 59
