    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.3m Views 345 Watching
    • massimoM
      massimo Moderator
      Fredo, some problems with this new version. Draw a rectangle, pushpull it then stretch. Use the bend tool. It doesn't works properly anymore.
      • utilerU
        utiler
        Incredible, Fredo!!!!!
        Just Curious...
        • COSEDIMARCOC
          COSEDIMARCO
          @Fredo6
          New Italian translation is ready.
          You should add a string for "Donation...". The translation is "Donazioni...".
          Ps. My nickname is "COSEDIMARCO" and not "Marco Cosedi". πŸ˜„ it means " Things of Marco" in Italian.
          Italian translation for the new version
          [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
          • fredo6F
            Massimo,
            This is not really a bug of FreeScale (and not of the version 2.0e), but a problem of Selection.
            When you exit the Stretch, only the edges are selected, not the faces.
            Then applying the Bend would only operate on these selected edges.
            You can try by deselecting All after stretch, before using Bend.
            This is why I recommend to enclose the geometry in a group (or component), because with geometry at native level, it is very difficult in Ruby to maintain properly the selection for faces (due to the fact that SU changes the object Ids when faces are deformed).
            • massimoM
              massimo Moderator
              Ok, thanks. That works.
              Massimo
              • daikuD
                daiku
                Confirming that stretch to target now works correctly. Excellent work, as always, Fredo. CB.
                Clark Bremer
                http://www.northernlightstimberframing.com
                • fredo6F
                  NEW VERSION 2.0f NOW RELEASED
                  It fixes remaining issues for Mac compatibility of web dialog boxes and includes the full translation in Italian by COSEDIMARCOhttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a#p144180
                  You also need to download LibFredo6 3.1f
                  • jeff hammondJ
                    hey Fred,
                    just confirming that the latest release (f) is working fine and all the mac implementations are A-OK
                    many thanks ❗
                      mkelly
                      I'm new to the forum, were is the link to the downloads?
                      Mkelly
                      • Chris FullmerC
                        The link is at the bottom of the first post in this thread.
                          spjonesuk
                          Im so sorry to ask but how do i dowload this freescale I cant see link to download?
                          • Chris FullmerC
                            The link is at the bottom of the very first post.
                            I feel like a broken record player.
                            • david_hD
                              david_h
                              Record Player . . .??? What's that? πŸ˜„
                              • romboutR
                                rombout
                                I cant download libfredo6 3.1f proberly it gives of a file of 6kb. Tried libfredo6 3.1e but nothing happens.
                                Oke got it to work... Lets play with it
                                • CadFatherC
                                  CadFather
                                  Hi Fredo
                                  what are the chances i can remove the separators from the icons toolbar?
                                  • CadFatherC
                                    CadFather
                                    Thank you Fredo - class act (as always) πŸ˜„
                                      silver_shadow
                                      Hi Fredo
                                      I like your tool. I want to know if you can re make the stretch tool so that you if stretch 4 or more objects, it calculates the spaces between and re position all if them and not only have one cut face but several depending the amount of objects between it
                                      pretty please.
                                      Like if you do a palacade fence, you can stretch it and all those poles will be re spaced.
                                      • fredo6F
                                        @silver_shadow said:
                                        Hi Fredo
                                        pretty please.
                                        I thought about that of course. There is no major geometrical issues except the GUI to help you decide, because in some instances, it won't do what you wish it would do.
                                        By the way, what you describe is pretty much what Dynamic Components have been made for.
                                        • W
                                          watkins
                                          Dear Fredo,
                                          Further to a previous post, what settings should I use to remove the blank icon boxes from the tool bar, or are these unused boxes earmarked for future tool?
                                          A fantastic and generous contribution to the SU community. Thank you.
                                          Kind regards,
                                          Bob
                                          • romboutR
                                            rombout
                                            Hi fredo... I had it working. But it stopped today. It wont show anymore. I tried downloading the 31f today and the link worked, only it is still not working. I dont know what happened. I thought of a different ruby but that was not the cause. It was working on my pc and wanted it on my imac. I got this error that it only worked with 31 and not 30. Tonight i wanted to work with it on the pc but it didnt show up anymore. I just copied the files from the pluggin folder to a mem stick
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 58
                                            • 59
                                            • 14 / 59
