    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 484.9k Views 153 Watching
      sepo
      Nice one Chris. Will the updated version be any different than previous and will it work with SU6?
        REGIS
        Thanks a lot CPhilips, I really enjoy your plugin.
        cheers
          CPhillips
          I just tried it out under SU7 (free version) and it seems to work ok. How is it failing for you?
            REGIS
            Hi the FFD menu doesn't appear in contextual menu.
            cheers
              CPhillips
              Are you sure you installed it in the right place. Should be in the plugins folder.
              Can anyone else confirm it does or doesn't work with SU7?
                johnsenior1973
                FFD isn't appearing for me in SU7.
                It's probably my fault for trying to copy the plugins straight from 6 to 7 though.
                  johnsenior1973
                  Downloaded it again and installed it. It's working for me now.
                    REGIS
                    downloaded and installed in google sketchup 7 plugins folder.
                    Doesn't work
                    cheers
                      REGIS
                      It works fine now.
                      Thanks a lot.
                      cheers
                      • ToboboT Offline
                        Tobobo
                        Chris,
                        I can't get it to work.
                        I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
                        I've posted the model so you can have a look and tell what i'm doing wrong.
                        Thanks in advance.
                        Netting.skp
                        Toby
                        Philippians 4:13
                          REGIS
                          Hi Tobobo
                          It's due to the hidden geometry.
                          Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
                          Just create the group and choose your FFD setting.
                          curtain.skp
                          cheers
                          Edit
                          After some FFD
                          curtainFFDv6.skp
                          cheers
                          • ToboboT Offline
                            Tobobo
                            Thanks REGIS
                            I'll have to think of another way to deform the netting.
                            Toby
                            Philippians 4:13
                              REGIS
                              Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
                              Cheers
                                SKELL
                                I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
                                Thanks,
                                -Tony
                                  One possibility
                                  Draw a rectangle
                                  Pull it with Ctrl any time you want
                                  Select all (triple click)
                                  Move it one time + CTRL = Copy
                                  Type "10*" (or more) = Multiple
                                  Group it
                                  Select group Right Click / FFD
                                  Edit the goup "FFD"
                                  Move points
                                  Et voilà 😉
                                  rec.skp
                                    michaelland
                                    Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                                    Michael Xie
                                      BTM
                                      Thanks,
                                      -Tony
                                      There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                                        Yes but will be any effect on the subdivide of a simple rectangle!!!
                                        Nothing will arrive when you will move a point of the FFD!
                                        Seems the only easy methode is draw a rectangle with the Sandbox 😄
                                          jonorman
                                          Hi..
                                          I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
                                          can anyone else confirm this ?? Btw, FFD is a brilliant script. 👍
                                            GJV
                                            woooaaaa
                                            amazing plugin
                                            just what I needed
                                            thanx a lot 😄 !!!!
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
