    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 540.5k Views 153 Watching
      REGIS
      Hi the FFD menu doesn't appear in contextual menu.
      cheers
      • C
        CPhillips
        Are you sure you installed it in the right place. Should be in the plugins folder.
        Can anyone else confirm it does or doesn't work with SU7?
          johnsenior1973
          FFD isn't appearing for me in SU7.
          It's probably my fault for trying to copy the plugins straight from 6 to 7 though.
            johnsenior1973
            Downloaded it again and installed it. It's working for me now.
              REGIS
              downloaded and installed in google sketchup 7 plugins folder.
              Doesn't work
              cheers
                REGIS
                It works fine now.
                Thanks a lot.
                cheers
                • ToboboT
                  Tobobo
                  Chris,
                  I can't get it to work.
                  I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
                  I've posted the model so you can have a look and tell what i'm doing wrong.
                  Thanks in advance.
                  Netting.skp
                  Toby
                  Philippians 4:13
                    REGIS
                    Hi Tobobo
                    It's due to the hidden geometry.
                    Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
                    Just create the group and choose your FFD setting.
                    curtain.skp
                    cheers
                    Edit
                    After some FFD
                    curtainFFDv6.skp
                    cheers
                    • ToboboT
                      Tobobo
                      Thanks REGIS
                      I'll have to think of another way to deform the netting.
                      Toby
                      Philippians 4:13
                        REGIS
                        Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
                        Cheers
                          SKELL
                          I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
                          Thanks,
                          -Tony
                            One possibility
                            Draw a rectangle
                            Pull it with Ctrl any time you want
                            Select all (triple click)
                            Move it one time + CTRL = Copy
                            Type "10*" (or more) = Multiple
                            Group it
                            Select group Right Click / FFD
                            Edit the goup "FFD"
                            Move points
                            Et voilà 😉
                            rec.skp
                              michaelland
                              Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                              Michael Xie
                              • B
                                BTM
                                Thanks,
                                -Tony
                                There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                                  Yes but will be any effect on the subdivide of a simple rectangle!!!
                                  Nothing will arrive when you will move a point of the FFD!
                                  Seems the only easy methode is draw a rectangle with the Sandbox 😄
                                    jonorman
                                    Hi..
                                    I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
                                    can anyone else confirm this ?? Btw, FFD is a brilliant script. 👍
                                    • G
                                      GJV
                                      woooaaaa
                                      amazing plugin
                                      just what I needed
                                      thanx a lot 😄 !!!!
                                        Dee256
                                        Works nice! But "transformations reset" needs sometimes before FFD starts.
                                        • I
                                          ideas_arte
                                          .. thanks a million!
                                          really useful too 👍
                                          • N
                                            niarfe
                                            this looks like a wonderful ruby!!!
                                            too bad it's not working for me, it doesn't do anything, and when I try undoing it beaks my geometry apart!
                                            would have loved to use it 😞
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
