    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 480.4k Views 153 Watching
      kwistenbiebel
      @remus said:
      If youve got the latest version you shouldnt need the update option, it should do it automatically.
      Not always. as a matter of fact I would vote to get the 'update' button re-instated, just for the cases the auto-update doesn't work.
        CPhillips
        Yeah, the update menu option was removed when I figured out how to auto update. Ill remove it from the post.
        I can put it back. But I would rather fix the bug that keeps auto updating from working. Can you send me a model that the FFD doesn't auto update I might be able to figure it out.
          andrew1184
          Wonderful plugin, thank you very much. If I do anything useful I'll try to upload it . . .
            aby
            cheer man u are rockin
            for base users like me ur genius
            go on
              REGIS
              Hi CPhillips, it appears that your very great plugin doesn't work within google sketchup 7.
              Any idea ?
              Thanks in advance
              cheers
                CPhillips
                I'll post an updated version tonight.
                  sepo
                  Nice one Chris. Will the updated version be any different than previous and will it work with SU6?
                    REGIS
                    Thanks a lot CPhilips, I really enjoy your plugin.
                    cheers
                      CPhillips
                      I just tried it out under SU7 (free version) and it seems to work ok. How is it failing for you?
                        REGIS
                        Hi the FFD menu doesn't appear in contextual menu.
                        cheers
                          CPhillips
                          Are you sure you installed it in the right place. Should be in the plugins folder.
                          Can anyone else confirm it does or doesn't work with SU7?
                            johnsenior1973
                            FFD isn't appearing for me in SU7.
                            It's probably my fault for trying to copy the plugins straight from 6 to 7 though.
                              johnsenior1973
                              Downloaded it again and installed it. It's working for me now.
                                REGIS
                                downloaded and installed in google sketchup 7 plugins folder.
                                Doesn't work
                                cheers
                                  REGIS
                                  It works fine now.
                                  Thanks a lot.
                                  cheers
                                  • ToboboT Offline
                                    Tobobo
                                    Chris,
                                    I can't get it to work.
                                    I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
                                    I've posted the model so you can have a look and tell what i'm doing wrong.
                                    Thanks in advance.
                                    Netting.skp
                                    Toby
                                    Philippians 4:13
                                      REGIS
                                      Hi Tobobo
                                      It's due to the hidden geometry.
                                      Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
                                      Just create the group and choose your FFD setting.
                                      curtain.skp
                                      cheers
                                      Edit
                                      After some FFD
                                      curtainFFDv6.skp
                                      cheers
                                      • ToboboT Offline
                                        Tobobo
                                        Thanks REGIS
                                        I'll have to think of another way to deform the netting.
                                        Toby
                                        Philippians 4:13
                                          REGIS
                                          Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
                                          Cheers
                                            SKELL
                                            I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
                                            Thanks,
                                            -Tony
                                            • 11
                                            • 20
                                            • 21
                                            • 9 / 21
