    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 465.5k Views 153 Watching
      aby
      cheer man u are rockin
      for base users like me ur genius
      go on
        REGIS
        Hi CPhillips, it appears that your very great plugin doesn't work within google sketchup 7.
        Any idea ?
        Thanks in advance
        cheers
          CPhillips
          I'll post an updated version tonight.
            sepo
            Nice one Chris. Will the updated version be any different than previous and will it work with SU6?
              REGIS
              Thanks a lot CPhilips, I really enjoy your plugin.
              cheers
                CPhillips
                I just tried it out under SU7 (free version) and it seems to work ok. How is it failing for you?
                  REGIS
                  Hi the FFD menu doesn't appear in contextual menu.
                  cheers
                    CPhillips
                    Are you sure you installed it in the right place. Should be in the plugins folder.
                    Can anyone else confirm it does or doesn't work with SU7?
                      johnsenior1973
                      FFD isn't appearing for me in SU7.
                      It's probably my fault for trying to copy the plugins straight from 6 to 7 though.
                        johnsenior1973
                        Downloaded it again and installed it. It's working for me now.
                          REGIS
                          downloaded and installed in google sketchup 7 plugins folder.
                          Doesn't work
                          cheers
                            REGIS
                            It works fine now.
                            Thanks a lot.
                            cheers
                            • ToboboT Offline
                              Tobobo
                              Chris,
                              I can't get it to work.
                              I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
                              I've posted the model so you can have a look and tell what i'm doing wrong.
                              Thanks in advance.
                              Netting.skp
                              Toby
                              Philippians 4:13
                                REGIS
                                Hi Tobobo
                                It's due to the hidden geometry.
                                Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
                                Just create the group and choose your FFD setting.
                                curtain.skp
                                cheers
                                Edit
                                After some FFD
                                curtainFFDv6.skp
                                cheers
                                • ToboboT Offline
                                  Tobobo
                                  Thanks REGIS
                                  I'll have to think of another way to deform the netting.
                                  Toby
                                  Philippians 4:13
                                    REGIS
                                    Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
                                    Cheers
                                      SKELL
                                      I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
                                      Thanks,
                                      -Tony
                                        One possibility
                                        Draw a rectangle
                                        Pull it with Ctrl any time you want
                                        Select all (triple click)
                                        Move it one time + CTRL = Copy
                                        Type "10*" (or more) = Multiple
                                        Group it
                                        Select group Right Click / FFD
                                        Edit the goup "FFD"
                                        Move points
                                        Et voilà 😉
                                        rec.skp
                                          michaelland
                                          Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                                          Michael Xie
                                            BTM
                                            Thanks,
                                            -Tony
                                            There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                                            • 11
                                            • 20
                                            • 21
                                            • 9 / 21
