    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 540.6k Views 153 Watching
    • ToboboT
      Tobobo
      Chris,
      I can't get it to work.
      I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
      I've posted the model so you can have a look and tell what i'm doing wrong.
      Thanks in advance.
      Netting.skp
      Toby
      Philippians 4:13
        REGIS
        Hi Tobobo
        It's due to the hidden geometry.
        Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
        Just create the group and choose your FFD setting.
        curtain.skp
        cheers
        Edit
        After some FFD
        curtainFFDv6.skp
        cheers
        • ToboboT
          Tobobo
          Thanks REGIS
          I'll have to think of another way to deform the netting.
          Toby
          Philippians 4:13
            REGIS
            Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
            Cheers
              SKELL
              I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
              Thanks,
              -Tony
                One possibility
                Draw a rectangle
                Pull it with Ctrl any time you want
                Select all (triple click)
                Move it one time + CTRL = Copy
                Type "10*" (or more) = Multiple
                Group it
                Select group Right Click / FFD
                Edit the goup "FFD"
                Move points
                Et voilà 😉
                rec.skp
                  michaelland
                  Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                  Michael Xie
                  • B
                    BTM
                    Thanks,
                    -Tony
                    There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                      Yes but will be any effect on the subdivide of a simple rectangle!!!
                      Nothing will arrive when you will move a point of the FFD!
                      Seems the only easy methode is draw a rectangle with the Sandbox 😄
                        jonorman
                        Hi..
                        I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
                        can anyone else confirm this ?? Btw, FFD is a brilliant script. 👍
                        • G
                          GJV
                          woooaaaa
                          amazing plugin
                          just what I needed
                          thanx a lot 😄 !!!!
                            Dee256
                            Works nice! But "transformations reset" needs sometimes before FFD starts.
                            • I
                              ideas_arte
                              .. thanks a million!
                              really useful too 👍
                              • N
                                niarfe
                                this looks like a wonderful ruby!!!
                                too bad it's not working for me, it doesn't do anything, and when I try undoing it beaks my geometry apart!
                                would have loved to use it 😞
                                • Chris FullmerC
                                  Its not over yet. If its not working, then its installed wrong or your using it wrong. Or you have version 4 of SU 😄
                                  Could you provide a better description of what its doing wrong? Perhaps screenshots, maybe a video. Just give us some more detail and we'll get it working for you.
                                    sprezzaturon
                                    I'm running Sketchup 7 and just added your FFD tool. I can move points but there is no 'update FFD' option when I'm finished. Is FFD not compatible with Sketchup 7?
                                      remus
                                      The shape should update automatically, you might have to give it a bit of time, though.
                                      If that doesnt work delete the control points, explode the group, regroup and try again.
                                        sprezzaturon
                                        After waiting on a 2.4 GHz dual core XP system, nothing changed. I've just installed FFD on my computer (2.1 GHz dual core) and created a circle so I could elongate one point. Nothing. This is disappointing.
                                          remus
                                          Have you tried it on 3d geometry? i think it can work on 2d things, but ive never gotten the hang of it.
                                          • H
                                            hasan
                                            @cphillips said:
                                            I can't get this script to work. Nothing happens.
                                            I create a sphere, group it, right-click and do 3x3 FFD, enter the new group with Construction Points, move some to another position, exit the group, right-click the sphere group and choose Update FFD. Nothing happens.
                                            Can you open the ruby console and see if it is printing any errors?
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
